Old Sep 29, 2011, 08:02 PM
Rob Glover
Rob Glover
Guest
n/a Posts
Re: Re: F3J Flight Matrix Calculations
Yes maybe. It's an opportunity to shape the event. As a rulebook event it would possibly gain participants in new venues.
It's a great event, and part of evolution, which we need.
Rob Glover
On Sep 29, 2011, at 19:55, "Jim Monaco" <jimsoars@earthlink.net> wrote:
> No I haven’t Rob – but that should be possible. Is there a benefit for that?
> Jim
> From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of Rob Glover
> Sent: Thursday, September 29, 2011 6:50 PM
> To: rcse@googlegroups.com
> Subject: Re: [RCSE] Re: F3J Flight Matrix Calculations
> Jim -
> Have you given any thought to submitting J with winches rules to AMA for consideration as a rulebook event?
> Thanks for the good work
> Rob Glover
> On Sep 29, 2011, at 15:26, "Jim Monaco" <jimsoars@earthlink.net> wrote:
> Thanks for this pointer. I downloaded the program and I can probably make it work. I generated a matrix from the test data that he has in there and the STDDEV is much smaller than the ones I was seeing. Now the magic is to export the registration and team data from my DB, reformat it to import into his DB, run the matrix and then export his data and reformat it to import back into my program… Then I’ll run my stats and see if it still looks as good…
> Piece of cake… J
> Jim
> From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of mike@themapsmith.com
> Sent: Thursday, September 29, 2011 12:05 PM
> Subject: RE: [RCSE] Re: F3J Flight Matrix Calculations
> And F3J comps as well. It will work for you Jim.
> Mike
> -------- Original Message --------
> Subject: [RCSE] Re: F3J Flight Matrix Calculations
> From: Don Harban <misterharban@cox.net>
> Date: Thu, September 29, 2011 11:00 am
> To: RCSE <rcse@googlegroups.com>
> Go to gliderscore.com. I just shook the synapses loose and remembered
> the site. The program is already set up to generate the matrices you
> described and to specifically score F3K comps.
> I've been evaluating it for other uses and will publish an article
> about it soon.
> Happy Landings,
> Don
> On Sep 29, 12:40 pm, Don Harban <misterhar...@cox.net> wrote:
> > I've been looking at a glider scoring program developed by an Aussie
> > and widely used for nearly every kind of comp there and in Europe. I
> > am on the road right now, and cannot remember the source. But it has
> > Avery sophisticated matrix routine which appears to be effective for
> > nearly any number of contestants and flight groups. It is a complete
> > scoring program, facilitating such things as throw outs, reflies and,
> > of course frequency conflicts.
> > It will generate flight matrices, score cards and round-by-round
> > results. It will score teams and resolve team conflicts within
> > rounds. It is a stand alone, not requiring excel or anything like
> > that.
> > In dealing with matrices it will not only create the matrices, but it
> > will furnish a ton of statistical information on the matrices that it
> > forms and allow unlimited retries (with statistical breakdowns) until
> > you are satisfied.
> > If you are interested I will furnish more information when I get home.
> > Happy Landings,
> > Don
> > On Sep 29, 12:22 pm, <m...@themapsmith.com> wrote:
> > > Jim, try gliderscore here... http://absupply.net/hafele-29002701-...cabinet-hanger...
> > > Joe Wurts says it does a pretty good job of getting a non random, evenly distributed flight matrix developed. He says that it uses a program similar to one he designed to do just what you are attempting to do. Goal should be to get each pilot to fly against other pilots an even amount of times. So the software has to check for previous pilot matches and throw out recurrances.
> > > Hope this helps. You could contact Joe directly, but I only have his RCGroups contact.
> > > Cheers,
> > > Mike
> > > Subject: [RCSE] F3J Flight Matrix Calculations
> > > From: "Jim Monaco" <jimso...@earthlink.net>
> > > Date: Thu, September 29, 2011 10:15 am
> > > To: <rcse@googlegroups.com>As many of you know I regularly run F3J events and handle all the matrix and scoring tasks. In the past I have always generated the flight matrix using a random assignment and rarely have any complaints. However, I am now looking at generating the fairest possible matrix for the US F3J Team Selections and have run a number of tests and often see anomalies in the matrix where a pilot flies against another an inordinate number of times or very few times. I ain't the sharpest pencil in the box, so I could use some suggestions on how to improve the matrix from some of the smart math people in the group. I am a programmer so if I understand the algorithm I can program it.. :)
> > > Here are the constraints:
> > > 1. There are 10 teams
> > > 2. Each team consists of 4 pilots (if there are less than 4 pilots a BYE will fill the empty slots).
> > > 3. Each pilot will fly once in a round (so there are 4 groups in a round)
> > > 4. Pilots on the same team are protected and will never fly against another team member.
> > > 5. We will schedule 24 total rounds in the matrix
> > > Here is what I have attempted so far:
> > > 1. Pure random – for each round I process each team. On each team every pilot has a fixed pilot number between 1 and 4 (including BYES). I then compute a random sequence of the position numbers 1-4 and assign the flight group based on that sequence. Repeat for each team. When all teams have been computed for a round I go on to compute the next round.
> > > 2. Random with statistical preference – I do the above, but I calculate a factor to use in determining the variance in the matrix and run 1000 trials and select the one with the least variance. To do this I compute and record how many time each pilot flies against the other pilots. For each pilot I compute the standard deviation of these numbers. I then add all the pilots standard deviations together and compute the average standard deviation for the entire matrix. I pick the matrix that generates the lowest standard deviation in 1000 trials. Generally I see a minimum standard deviation of about 1.28. Some individual matrix SDs are 1.9 or so.
> > > read more »
> You received this message because you are subscribed to the Google Groups "RCSE" group.
> To post to this group, send email to rcse@googlegroups.com.
> To unsubscribe from this group, send email to rcse+unsubscribe@googlegroups.com.
> For more options, visit this group at http://groups.google.com/group/rcse?hl=en.
Old Sep 29, 2011, 08:08 PM
Rob Glover
Rob Glover
Guest
n/a Posts
Cool. Holler if I can help or aid and abet.
Rob Glover
On Sep 29, 2011, at 20:08, "Jim Monaco" <jimsoars@earthlink.net> wrote:
> I’d be happy to give it a shot…
> Jim
> Sent: Thursday, September 29, 2011 7:03 PM
> Rob Glover
> Jim
> Jim -
> Rob Glover
> Piece of cake… J
> Jim
> Mike
> about it soon.
> Happy Landings,
> Don
> > that.
> > you are satisfied.
> > Happy Landings,
> > Don
> > > Cheers,
> > > Mike
> > > read more »
Jim Monaco
Jim Monaco
Guest
n/a Posts
RE: Re: F3J Flight Matrix Calculations
I'd be happy to give it a shot.
Jim
Glover
Rob Glover
No I haven't Rob - but that should be possible. Is there a benefit for
that?
Jim
Glover
Jim -
Rob Glover
back into my program. Then I'll run my stats and see if it still looks as
good.
Piece of cake. J
Jim
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
recurrances.
RCGroups contact.
> > Cheers,
> > Mike
round)
> > 1. Pure random - for each round I process each team. On each team
> > 2. Random with statistical preference - I do the above, but I
> > read more >
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
Old Sep 29, 2011, 08:25 PM
Jerry Miller
Jerry Miller
Guest
n/a Posts
If you do Jim, give it another name, not F3J, make it F3W, F3J is for human
tow. Just my 2 cents.
Jerry
On Thu, Sep 29, 2011 at 6:08 PM, Jim Monaco <jimsoars@earthlink.net> wrote:
> I’d be happy to give it a shot…****
> *Jim*
> *From:* rcse@googlegroups.com [mailto:rcse@googlegroups.com] *On Behalf Of
> *Rob Glover
> *Sent:* Thursday, September 29, 2011 7:03 PM
> *To:* rcse@googlegroups.com
> *Subject:* Re: [RCSE] Re: F3J Flight Matrix Calculations****
> would possibly gain participants in new venues. ****
> Rob Glover****
> On Sep 29, 2011, at 19:55, "Jim Monaco" <jimsoars@earthlink.net> wrote:***
> that?****
> *Jim*****
> *Rob Glover
> *Sent:* Thursday, September 29, 2011 6:50 PM
> Jim -****
> consideration as a rulebook event?****
> Rob Glover****
> On Sep 29, 2011, at 15:26, "Jim Monaco" <jimsoars@earthlink.net> wrote:***
> good… ****
> Piece of cake… J****
> *Jim*****
> *mike@themapsmith.com
> *Sent:* Thursday, September 29, 2011 12:05 PM
> *Subject:* RE: [RCSE] Re: F3J Flight Matrix Calculations****
> And F3J comps as well. It will work for you Jim.****
> Mike ****
> about it soon.
> Happy Landings,
> Don
> > that.
> > you are satisfied.
> > Happy Landings,
> > Don
> out recurrances.
> > > Cheers,
> > > Mike
> round)
> > > read more »
> "RCSE" group.
> http://groups.google.com/group/rcse?hl=en.****
> "RCSE" group.
> "RCSE" group.
> "RCSE" group.
> "RCSE" group.
> "RCSE" group.
> "RCSE" group.
*Jerry Miller*
Medford, OR
Old Sep 29, 2011, 08:43 PM
Jim Monaco
Jim Monaco
Guest
n/a Posts
Totally with you. J
Jim
Jerry Miller
Sent: Thursday, September 29, 2011 7:26 PM
Jerry
Jim
Glover
Rob Glover
that?
Jim
Glover
Jim -
Rob Glover
good.
Piece of cake. J
Jim
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
recurrances.
RCGroups contact.
> > Cheers,
> > Mike
round)
> > read more >
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
<mailto:rcse%2Bunsubscribe@googlegroups.com> .
Jerry Miller
Medford, OR
"RCSE" group.
Old Sep 30, 2011, 10:02 AM
Buzz Averill
Buzz Averill
Guest
n/a Posts
Jim,
For what it's worth I agree with Mr. Glover J needs winches.
Buzz Averill
From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of Jim
Monaco
Sent: Thursday, September 29, 2011 7:08 PM
Jim
Glover
Rob Glover
that?
Jim
Glover
Jim -
Rob Glover
good.
Piece of cake. J
Jim
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
recurrances.
RCGroups contact.
> > Cheers,
> > Mike
round)
> > read more >
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
Discussion F3J Flight Matrix Generation jimsoars Multi Task F3X 27 Oct 06, 2011 08:26 AM
Help! Problems with Plettenburg calculations Flyextreme High Performance 9 Sep 12, 2011 07:54 AM
Discussion Battery calculations split_s Batteries and Chargers 4 Sep 05, 2011 11:33 PM
Build Log 90mm Matrix Video Added! Test flight complete. fh64_lucky Electric Ducted Fan Jet Talk 224 Nov 01, 2010 10:24 AM
