Old Sep 29, 2011, 12:15 PM
Jim Monaco
Jim Monaco
Guest
n/a Posts
F3J Flight Matrix Calculations
As many of you know I regularly run F3J events and handle all the matrix and
scoring tasks. In the past I have always generated the flight matrix using
a random assignment and rarely have any complaints. However, I am now
looking at generating the fairest possible matrix for the US F3J Team
Selections and have run a number of tests and often see anomalies in the
matrix where a pilot flies against another an inordinate number of times or
very few times. I ain't the sharpest pencil in the box, so I could use some
suggestions on how to improve the matrix from some of the smart math people
in the group. I am a programmer so if I understand the algorithm I can
program it.. :)
Here are the constraints:
1. There are 10 teams
2. Each team consists of 4 pilots (if there are less than 4 pilots a
BYE will fill the empty slots).
3. Each pilot will fly once in a round (so there are 4 groups in a
round)
4. Pilots on the same team are protected and will never fly against
another team member.
5. We will schedule 24 total rounds in the matrix
Here is what I have attempted so far:
1. Pure random - for each round I process each team. On each team
every pilot has a fixed pilot number between 1 and 4 (including BYES). I
then compute a random sequence of the position numbers 1-4 and assign the
flight group based on that sequence. Repeat for each team. When all teams
have been computed for a round I go on to compute the next round.
2. Random with statistical preference - I do the above, but I
calculate a factor to use in determining the variance in the matrix and run
1000 trials and select the one with the least variance. To do this I
compute and record how many time each pilot flies against the other pilots.
For each pilot I compute the standard deviation of these numbers. I then
add all the pilots standard deviations together and compute the average
standard deviation for the entire matrix. I pick the matrix that generates
the lowest standard deviation in 1000 trials. Generally I see a minimum
standard deviation of about 1.28. Some individual matrix SDs are 1.9 or so.
3. Random with statistical preference and permutiations - for this
approach I calculate all the possible permutations of the sequence 1-4.
Then for each team I generate a random sequence of those permutations
(1-24). I then assign the group position for each pilot in a round based on
that teams random set of permutations. I then do the same as #2 and
calculate the minimum SD of all the matrixes and select the lowest.
Interestingly this approach was nearly identical in minimum SD as the #2
approach.
It just feels to me like there should be a better way to get a more even
distribution - I'm hoping one of you math heads out there can help me
improve the matrix.
If not - it is what it is and I did my best.
Jim
You received this message because you are subscribed to the Google Groups "RCSE" group.
To post to this group, send email to rcse@googlegroups.com.
To unsubscribe from this group, send email to rcse+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/rcse?hl=en.
Old Sep 29, 2011, 12:22 PM
Dave Jensen
Dave Jensen
Guest
n/a Posts
Re: F3J Flight Matrix Calculations
Nevermind on the when/where.... I just remembered it's next month in
FL.
> matrix and scoring tasks. In the past I have always generated the
> flight matrix using a random assignment and rarely have any
> complaints. However, I am now looking at generating the fairest
> possible matrix for the US F3J Team Selections and have run a number
> of tests and often see anomalies in the matrix where a pilot flies
> against another an inordinate number of times or very few times. I
> ain't the sharpest pencil in the box, so I could use some suggestions
> on how to improve the matrix from some of the smart math people in
> the
> program it.. :)
> round)
> BYES).
> I then compute a random sequence of the position numbers 1-4 and
> assign the flight group based on that sequence. Repeat for each team.
> When all teams have been computed for a round I go on to compute the
> next round.
> and run 1000 trials and select the one with the least variance. To do
> this I compute and record how many time each pilot flies against the
> other pilots. For each pilot I compute the standard deviation of
> these
> numbers. I then add all the pilots standard deviations together and
> compute the average standard deviation for the entire matrix. I pick
> the matrix that generates the lowest standard deviation in 1000
> trials. Generally I see a minimum standard deviation of about 1.28.
> 1-4. Then for each team I generate a random sequence of those
> permutations (1-24). I then assign the group position for each pilot
> in a round based on that teams random set of permutations. I then do
> the same as #2 and calculate the minimum SD of all the matrixes and
> select the lowest. Interestingly this approach was nearly identical
> in
> minimum SD as the #2 approach.
> even distribution - I'm hoping one of you math heads out there can
> help me improve the matrix…
> If not - it is what it is and I did my best…
> Jim
mike@themapsmith.com
Guest
n/a Posts
RE: F3J Flight Matrix Calculations
Jim, try gliderscore here... http://absupply.net/hafele-29002701-...uspension.aspx
Joe Wurts says it does a pretty good job of getting a non random, evenly distributed flight matrix developed. He says that it uses a program similar to one he designed to do just what you are attempting to do. Goal should be to get each pilot to fly against other pilots an even amount of times. So the software has to check for previous pilot matches and throw out recurrances.
Hope this helps. You could contact Joe directly, but I only have his RCGroups contact.
Cheers,
-------- Original Message --------
Subject: [RCSE] F3J Flight Matrix Calculations
Date: Thu, September 29, 2011 10:15 am
To: <rcse@googlegroups.com>
#wmQuoteWrapper /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;}
#wmQuoteWrapper @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;}
#wmQuoteWrapper /* Style Definitions */ p.MsoNormal, #wmQuoteWrapper li.MsoNormal, #wmQuoteWrapper div.MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:11.0pt; font-family:"Calibri","sans-serif";}
#wmQuoteWrapper a:link, #wmQuoteWrapper span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;}
#wmQuoteWrapper a:visited, #wmQuoteWrapper span.MsoHyperlinkFollowed {mso-style-priority:99; color:purple; text-decoration:underline;}
#wmQuoteWrapper p.MsoPlainText, #wmQuoteWrapper li.MsoPlainText, #wmQuoteWrapper div.MsoPlainText {mso-style-priority:99; mso-style-link:"Plain Text Char"; margin:0in; margin-bottom:.0001pt; font-size:11.0pt; font-family:"Calibri","sans-serif";}
#wmQuoteWrapper span.PlainTextChar {mso-style-name:"Plain Text Char"; mso-style-priority:99; mso-style-link:"Plain Text"; font-family:"Calibri","sans-serif";}
#wmQuoteWrapper .MsoChpDefault {mso-style-type:export-only; font-family:"Calibri","sans-serif";}
#wmQuoteWrapper @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in;}
#wmQuoteWrapper div.WordSection1 {page:WordSection1;}
#wmQuoteWrapper /* List Definitions */ @list l0 {mso-list-id:358509765; mso-list-type:hybrid; mso-list-template-ids:453537062 67698703 67698713 67698715 67698703 67698713 67698715 67698703 67698713 67698715;}
#wmQuoteWrapper @list l0:level1 {mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l0:level2 {mso-level-number-format:alpha-lower; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l0:level3 {mso-level-number-format:roman-lower; mso-level-tab-stop:none; mso-level-number-position:right; text-indent:-9.0pt;}
#wmQuoteWrapper @list l0:level4 {mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l0:level5 {mso-level-number-format:alpha-lower; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l0:level6 {mso-level-number-format:roman-lower; mso-level-tab-stop:none; mso-level-number-position:right; text-indent:-9.0pt;}
#wmQuoteWrapper @list l0:level7 {mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l0:level8 {mso-level-number-format:alpha-lower; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l0:level9 {mso-level-number-format:roman-lower; mso-level-tab-stop:none; mso-level-number-position:right; text-indent:-9.0pt;}
#wmQuoteWrapper @list l1 {mso-list-id:388187824; mso-list-type:hybrid; mso-list-template-ids:832891552 67698703 67698713 67698715 67698703 67698713 67698715 67698703 67698713 67698715;}
#wmQuoteWrapper @list l1:level1 {mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l1:level2 {mso-level-number-format:alpha-lower; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l1:level3 {mso-level-number-format:roman-lower; mso-level-tab-stop:none; mso-level-number-position:right; text-indent:-9.0pt;}
#wmQuoteWrapper @list l1:level4 {mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l1:level5 {mso-level-number-format:alpha-lower; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l1:level6 {mso-level-number-format:roman-lower; mso-level-tab-stop:none; mso-level-number-position:right; text-indent:-9.0pt;}
#wmQuoteWrapper @list l1:level7 {mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l1:level8 {mso-level-number-format:alpha-lower; mso-level-tab-stop:none; mso-level-number-position:left; text-indent:-.25in;}
#wmQuoteWrapper @list l1:level9 {mso-level-number-format:roman-lower; mso-level-tab-stop:none; mso-level-number-position:right; text-indent:-9.0pt;}
#wmQuoteWrapper ol {margin-bottom:0in;}
#wmQuoteWrapper ul {margin-bottom:0in;}
As many of you know I regularly run F3J events and handle all the matrix and scoring tasks. In the past I have always generated the flight matrix using a random assignment and rarely have any complaints. However, I am now looking at generating the fairest possible matrix for the US F3J Team Selections and have run a number of tests and often see anomalies in the matrix where a pilot flies against another an inordinate number of times or very few times. I ain't the sharpest pencil in the box, so I could use some suggestions on how to improve the matrix from some of the smart math people in the group. I am a programmer so if I understand the algorithm I can program it.. :)
2. Each team consists of 4 pilots (if there are less than 4 pilots a BYE will fill the empty slots).
3. Each pilot will fly once in a round (so there are 4 groups in a round)
4. Pilots on the same team are protected and will never fly against another team member.
1. Pure random – for each round I process each team. On each team every pilot has a fixed pilot number between 1 and 4 (including BYES). I then compute a random sequence of the position numbers 1-4 and assign the flight group based on that sequence. Repeat for each team. When all teams have been computed for a round I go on to compute the next round.
2. Random with statistical preference – I do the above, but I calculate a factor to use in determining the variance in the matrix and run 1000 trials and select the one with the least variance. To do this I compute and record how many time each pilot flies against the other pilots. For each pilot I compute the standard deviation of these numbers. I then add all the pilots standard deviations together and compute the average standard deviation for the entire matrix. I pick the matrix that generates the lowest standard deviation in 1000 trials. Generally I see a minimum standard deviation of about 1.28. Some individual matrix SDs are 1.9 or so.
3. Random with statistical preference and permutiations – for this approach I calculate all the possible permutations of the sequence 1-4. Then for each team I generate a random sequence of those permutations (1-24). I then assign the group position for each pilot in a round based on that teams random set of permutations. I then do the same as #2 and calculate the minimum SD of all the matrixes and select the lowest. Interestingly this approach was nearly identical in minimum SD as the #2 approach.
It just feels to me like there should be a better way to get a more even distribution – I’m hoping one of you math heads out there can help me improve the matrix…
If not – it is what it is and I did my best…
Jim
Old Sep 29, 2011, 12:32 PM
Jim Monaco
Jim Monaco
Guest
n/a Posts
Thanks Mike
That is a really cool cabinet hanger link. J
Yes - I have a web based scoring system so I need to get a matrix that I can
do something with to import into my program.
I'll google it and see if it might produce something I can use.
I don't have Joes private email any more - maybe he will see this and chime
in.
Jim
Jim
From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of
Sent: Thursday, September 29, 2011 11:23 AM
To: Jim Monaco
Cc: rcse@googlegroups.com
Subject: RE: [RCSE] F3J Flight Matrix Calculations
<http://absupply.net/hafele-29002701-...t-hangerwall-r
ail-suspension.aspx>
http://absupply.net/hafele-29002701-...-hangerwall-ra
il-suspension.aspx
recurrances.
RCGroups contact.
Cheers,
From: "Jim Monaco" < <mailto:jimsoars@earthlink.net> jimsoars@earthlink.net>
To: < <mailto:rcse@googlegroups.com> rcse@googlegroups.com>
program it.. :)
round)
approach.
improve the matrix.
Jim
"RCSE" group.
To post to this group, send email to <mailto:rcse@googlegroups.com>
<mailto:rcse+unsubscribe@googlegroups.com>
<http://groups.google.com/group/rcse?hl=en>
"RCSE" group.
Old Sep 29, 2011, 12:40 PM
Don Harban
Don Harban
Guest
n/a Posts
I've been looking at a glider scoring program developed by an Aussie
and widely used for nearly every kind of comp there and in Europe. I
am on the road right now, and cannot remember the source. But it has
Avery sophisticated matrix routine which appears to be effective for
nearly any number of contestants and flight groups. It is a complete
scoring program, facilitating such things as throw outs, reflies and,
of course frequency conflicts.
It will generate flight matrices, score cards and round-by-round
results. It will score teams and resolve team conflicts within
rounds. It is a stand alone, not requiring excel or anything like
that.
In dealing with matrices it will not only create the matrices, but it
will furnish a ton of statistical information on the matrices that it
forms and allow unlimited retries (with statistical breakdowns) until
you are satisfied.
If you are interested I will furnish more information when I get home.
Happy Landings,
Don
> Cheers,
> Mike
> From: "Jim Monaco" <jimsoars@earthlink.net>
> To: <rcse@googlegroups.com>As many of you know I regularly run F3J events and handle all the matrix and scoring tasks.  In the past I have always generated the flight matrix using a random assignment and rarely have any complaints.  However, I am now looking at generating the fairest possible matrix for the US F3J Team Selections and have run a number of tests and often see anomalies in the matrix where a pilot flies against another an inordinate number of times or very few times.  I ain't the sharpest pencil in the box, so I could use some suggestions on how to improve the matrix from some of the smart math people in the group.  I am a programmer so if I understand the algorithm I can program it.. :)
> read more »
Old Sep 29, 2011, 01:00 PM
Don Harban
Don Harban
Guest
n/a Posts
Go to gliderscore.com. I just shook the synapses loose and remembered
the site. The program is already set up to generate the matrices you
described and to specifically score F3K comps.
I've been evaluating it for other uses and will publish an article
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
> > Jim, try gliderscore here... http://absupply.net/hafele-29002701-...cabinet-hanger...
> > Cheers,
> > Mike
> > From: "Jim Monaco" <jimso...@earthlink.net>
> > read more »
Old Sep 29, 2011, 01:04 PM
Guest
n/a Posts
http://www.gliderscore.com/CompF3J.aspx
Doh! Now you know what I am working on....
Here is the link. I do think that you can import the matrix into your program once it is developed in gliderscore. Check it out and perhaps contact Oleg Golovidov, or Jerry on that web site.
Date: Thu, September 29, 2011 10:32 am
#wmQuoteWrapper /* Font Definitions */ @font-face {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;}
#wmQuoteWrapper @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;}
#wmQuoteWrapper @font-face {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;}
#wmQuoteWrapper @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;}
#wmQuoteWrapper /* Style Definitions */ p.MsoNormal, #wmQuoteWrapper li.MsoNormal, #wmQuoteWrapper div.MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman","serif";}
#wmQuoteWrapper p.MsoPlainText, #wmQuoteWrapper li.MsoPlainText, #wmQuoteWrapper div.MsoPlainText {mso-style-priority:99; mso-style-link:"Plain Text Char"; mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; font-size:12.0pt; font-family:"Times New Roman","serif";}
#wmQuoteWrapper p {mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; font-size:12.0pt; font-family:"Times New Roman","serif";}
#wmQuoteWrapper p.msochpdefault, #wmQuoteWrapper li.msochpdefault, #wmQuoteWrapper div.msochpdefault {mso-style-name:msochpdefault; mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; font-size:12.0pt; font-family:"Times New Roman","serif";}
#wmQuoteWrapper span.plaintextchar0 {mso-style-name:plaintextchar;}
#wmQuoteWrapper span.EmailStyle22 {mso-style-type:personal-reply; font-family:"Calibri","sans-serif"; color:#1F497D;}
#wmQuoteWrapper .MsoChpDefault {mso-style-type:export-only; font-size:10.0pt;}
Thanks Mike
That is a really cool cabinet hanger link… J
Yes – I have a web based scoring system so I need to get a matrix that I can do something with to import into my program.
I’ll google it and see if it might produce something I can use.
I don’t have Joes private email any more – maybe he will see this and chime in…
 rcse@googlegroups.com [mailto:rcse@googlegroups.com] mike@themapsmith.com
 Jim Monaco
Cheers,
Jim
Old Sep 29, 2011, 01:05 PM
Guest
n/a Posts
RE: Re: F3J Flight Matrix Calculations
And F3J comps as well. It will work for you Jim.
Subject: [RCSE] Re: F3J Flight Matrix Calculations
Date: Thu, September 29, 2011 11:00 am
To: RCSE <rcse@googlegroups.com>
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
> > Cheers,
> > Mike
> > read more »
Old Sep 29, 2011, 03:15 PM
Buzz Averill
Buzz Averill
Guest
n/a Posts
Jim, I have asked Dan Tandberg if he might be able to help
From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of Jim
Monaco
Sent: Thursday, September 29, 2011 11:16 AM
To: rcse@googlegroups.com
program it.. :)
round)
approach.
improve the matrix.
Jim
"RCSE" group.
Old Sep 29, 2011, 03:26 PM
Jim Monaco
Jim Monaco
Guest
n/a Posts
Thanks for this pointer. I downloaded the program and I can probably make
it work. I generated a matrix from the test data that he has in there and
the STDDEV is much smaller than the ones I was seeing. Now the magic is to
export the registration and team data from my DB, reformat it to import into
his DB, run the matrix and then export his data and reformat it to import
back into my program. Then I'll run my stats and see if it still looks as
good.
Piece of cake. J
Jim
Sent: Thursday, September 29, 2011 12:05 PM
Subject: RE: [RCSE] Re: F3J Flight Matrix Calculations
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
recurrances.
RCGroups contact.
> > Cheers,
> > Mike
round)
> > read more >
"RCSE" group.
"RCSE" group.
Old Sep 29, 2011, 04:35 PM
Guest
n/a Posts
I've told you this before Jim, but another "You Rock" couldn't hurt.
You Rock!
Date: Thu, September 29, 2011 1:26 pm
#wmQuoteWrapper span.EmailStyle18 {mso-style-type:personal-reply; font-family:"Calibri","sans-serif"; color:#1F497D;}
Thanks for this pointer. I downloaded the program and I can probably make it work. I generated a matrix from the test data that he has in there and the STDDEV is much smaller than the ones I was seeing. Now the magic is to export the registration and team data from my DB, reformat it to import into his DB, run the matrix and then export his data and reformat it to import back into my program… Then I’ll run my stats and see if it still looks as good…
Piece of cake… J
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
> > Cheers,
> > Mike
> > read more »
Old Sep 29, 2011, 07:50 PM
Rob Glover
Rob Glover
Guest
n/a Posts
Re: Re: F3J Flight Matrix Calculations
Jim -
Have you given any thought to submitting J with winches rules to AMA for consideration as a rulebook event?
Thanks for the good work
Rob Glover
> Piece of cake… J
> Jim
> From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of mike@themapsmith.com
> Mike
> From: Don Harban <misterharban@cox.net>
> about it soon.
> Happy Landings,
> Don
> > that.
> > you are satisfied.
> > Happy Landings,
> > Don
> > > Cheers,
> > > Mike
> > > read more »
Rob Glover
Rob Glover
Guest
n/a Posts
Bubba says Amen!
Rob Glover
> You Rock!
> Mike
> Piece of cake… J
> Jim
> Mike
> about it soon.
> Happy Landings,
> Don
> > that.
> > you are satisfied.
> > Happy Landings,
> > Don
> > > Cheers,
> > > Mike
> > > read more »
Old Sep 29, 2011, 07:55 PM
Jim Monaco
Jim Monaco
Guest
n/a Posts
Thanks guys - I just want the events to be the best they can be. J
Jim
From: rcse@googlegroups.com [mailto:rcse@googlegroups.com] On Behalf Of Rob
Glover
Sent: Thursday, September 29, 2011 6:51 PM
Subject: Re: [RCSE] Re: F3J Flight Matrix Calculations
Bubba says Amen!
Rob Glover
You Rock!
good.
Piece of cake. J
Jim
From: <mailto:rcse@googlegroups.com> rcse@googlegroups.com [
<mailto:rcse@googlegroups.com> mailto:rcse@googlegroups.com] On Behalf Of
<mailto:mike@themapsmith.com> mike@themapsmith.com
To: <mailto:rcse@googlegroups.com> rcse@googlegroups.com
From: Don Harban < <mailto:misterharban@cox.net> misterharban@cox.net>
To: RCSE < <mailto:rcse@googlegroups.com> rcse@googlegroups.com>
Go to <http://gliderscore.com> gliderscore.com. I just shook the synapses
about it soon.
Happy Landings,
Don
On Sep 29, 12:40 pm, Don Harban < <mailto:misterhar...@cox.net>
> that.
> you are satisfied.
> Happy Landings,
> Don
> On Sep 29, 12:22 pm, < <mailto:m...@themapsmith.com> m...@themapsmith.com>
<http://absupply.net/hafele-29002701-left-screw-mounted-cabinet-hanger>
recurrances.
RCGroups contact.
> > Cheers,
> > Mike
> > From: "Jim Monaco" < <mailto:jimso...@earthlink.net>
> > To: < <mailto:rcse@googlegroups.com> rcse@googlegroups.com>As many of
round)
> > read more >
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
Jim Monaco
Jim Monaco
Guest
n/a Posts
No I haven't Rob - but that should be possible. Is there a benefit for
that?
Jim
Glover
Sent: Thursday, September 29, 2011 6:50 PM
Jim -
Rob Glover
good.
Piece of cake. J
Jim
about it soon.
Happy Landings,
Don
> that.
> you are satisfied.
> Happy Landings,
> Don
recurrances.
RCGroups contact.
> > Cheers,
> > Mike
round)
> > read more >
"RCSE" group.
"RCSE" group.
"RCSE" group.
"RCSE" group.
Discussion F3J Flight Matrix Generation jimsoars Multi Task F3X 27 Oct 06, 2011 08:26 AM
Help! Problems with Plettenburg calculations Flyextreme High Performance 9 Sep 12, 2011 07:54 AM
Discussion Battery calculations split_s Batteries and Chargers 4 Sep 05, 2011 11:33 PM
Build Log 90mm Matrix Video Added! Test flight complete. fh64_lucky Electric Ducted Fan Jet Talk 224 Nov 01, 2010 10:24 AM
