Old Oct 24, 2001, 09:00 PM
ericslundy is offline
Find More Posts by ericslundy
Burns Lake B.C canada
Joined Jan 2001
charging 8 cells from a 7 cell charger?
i have an mrc brain charger which is meant for 6-7 cells and i want to put an 8 cell pack in place of the 7 cells that i currently use. Is there a simple way of charging 8 cells from a 6/7 cell peak detection charger and keep the peak detection working or is it a lost cause?
ericslundy is offline Find More Posts by ericslundy
Old Oct 24, 2001, 09:38 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If you use a 13.8V power supply and it stays at that level until the pack peaks, there's a chance the pack will be charged. Not very reliable, however. You're better off buying a new charger.
..a
Old Oct 25, 2001, 06:42 AM
plinse is offline
Find More Posts by plinse
plinse's Avatar
Baden Baden, Germany
Joined Feb 2001
The chargers which are limited on something like 7 cells can not increase the input voltage and 7 is the number of cells which can be charged even from a quite empty car baterie. Such chargers just control the current and if you want to charge more cells you just have to make sure, that the input voltage is high enough, 8 cells is usually no problem. But the input voltage should not exceed the highest voltage the charger can handle (usually 15V but check that out before trying )
Eike
plinse is offline Find More Posts by plinse
Old Oct 26, 2001, 12:58 AM
tekochip is offline
Find More Posts by tekochip
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
A higher input voltage may not work. The current pump in switching regulators usualy has a maximum voltage setting, and your charger may have this clamped at a 7 cell level. Also a peak charger is looking for a decrease in voltage somewhere around 1.6mV per cell (I've seen 1.2mV to 2mV), and with more cells you may get false peaks at high charge rates.
The best thing to do is measure it, and then give it a try.
tekochip is offline Find More Posts by tekochip
will a 7 cell charger charge 8 cells? 60ndown Batteries and Chargers 4 Oct 19, 2004 06:04 PM
8 batteries with a 7 cell charger gnirwin Batteries and Chargers 11 Oct 01, 2004 09:14 PM
making 8 cells from 7 daron Batteries and Chargers 4 Feb 13, 2004 10:13 PM
Will my 4-7 cell charger, charge my 8 cell 500AR pack??? AlexP Power Systems 4 Jul 25, 2001 03:48 AM
Will my 4-7 cell charger, charge my 8 cell 500AR pack??? AlexP Foamies (Kits) 1 Jul 23, 2001 07:23 PM
