Old Sep 29, 2011, 05:15 AM
alexvan is offline
Find More Posts by alexvan
alexvan's Avatar
Italy, Lazio, Rome
Joined Aug 2011
Help!
[Recorder Beta] Voltage on Temp B & Limit on OSD
I use the last beta of data recorder and configured the Temp B for voltage monitoring. I correctly see the voltage on the OSD, but it isn't displayed correctly on the instruments of the Data Recorder. I see a wrong value.
An other question: i'm configuring an alarmo fro lower limit on a specific parameter on OSD. There are two fields separate by a comma. I suppose that they are used for inputting a decimal value. Correct? But I'm not able to modify the second value: it shows 0 and I'm not able to change it.
Many thanks.
Regards.
Alessandro
alexvan is offline Find More Posts by alexvan
Old Oct 03, 2011, 08:03 AM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
Hi Alessandro,
Re the Voltage B monitoring...
Thats normal behavior for the PC instruments monitoring. The PC instruments haven't been coded up to display the Temp B as a voltage.
For the Alarm, what is the parameter you are trying to configure? Yes you should be able to put a . decimal value in that field but the parameter may not be appropriate for . values, eg number of Satelites.
cheers
Geoff
garris2 is offline Find More Posts by garris2
Help! No voltage showing on OSD JZSlenker Hoverfly Technologies 2 Sep 25, 2011 08:48 PM
Discussion APM2.0 beta Remzibi OSD diymuppet UAV - Unmanned Aerial Vehicles 7 Jul 03, 2011 04:44 PM
Discussion How to show negative Temp on the OSD reinhardfreh Eagle Tree Systems 1 Dec 01, 2010 12:19 AM
can you safely limit voltage drain on a lipo? crudpuppy Batteries and Chargers 13 Dec 10, 2004 09:19 AM
I need to limit min voltage on lipo motorhead Batteries and Chargers 10 Feb 26, 2004 08:54 AM
