Old Jan 17, 2012, 08:28 PM
I'm new here
timecop's Avatar
Joined Dec 2010
ya, same method as standard esc. throttle max power up, beep, go down, etc.
timecop is offline Find More Posts by timecop
Old Jan 17, 2012, 09:21 PM
United States, FL, Maitland
Joined Apr 2011
Code:
 Directory of C:\Users\Chris\Desktop
Wed 01/04/2012  09:33 AM             5,856 tgy.hex
               1 File(s)          5,856 bytes
               0 Dir(s)   9,127,268,352 bytes free
C:\Users\Chris\Desktop>avrdude -c usbasp -p m8 -U flash:w:tgy.hex
avrdude: warning: cannot set sck period. please check for usbasp firmware update
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9307
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: current erase-rewrite cycle count is -50462977 (if being tracked)
avrdude: erasing chip
avrdude: reading input file "tgy.hex"
avrdude: input file tgy.hex auto detected as Intel Hex
avrdude: writing flash (2068 bytes):
Writing | ################################################## | 100% 1.39s
avrdude: 2068 bytes of flash written
avrdude: verifying flash memory against tgy.hex:
avrdude: load data flash data from input file tgy.hex:
avrdude: input file tgy.hex contains 2068 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.81s
avrdude: verifying ...
avrdude: 2068 bytes of flash verified
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
<3 it worked! i used the hobbywing wiring layout(reverse of 10A rctimer layout).
that is the pin layout for my usbasp
http://www.ebay.com/itm/USBASP-USBIS...item564571ffe4
best $4 i everspent. took 1 month to arrive though.
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Jan 18, 2012, 02:22 AM
Joined Apr 2011
http://www.youtube.com/watch?v=dV5IE...ature=youtu.be
time to make the flashing tool.
Old Jan 18, 2012, 03:03 AM
larsm's Avatar
Germany, NRW, Münster
Joined May 2011
Originally Posted by Zombee View Post
Has anyone tried Flashing their HK BLUE SERIES 20A? i got 5 of them and planning on flashing 1 of them and if i see a good difference i will flash all of them, i will put some pictures of the board soon.
look here: ESC Specs For Simonk FW Flash and here
I already flashed 1 of them. It makes a huge difference. It is more quiet, the delay is much less, the motor start is better, the acceleration is much faster. I will try to make a Video today.
larsm is offline Find More Posts by larsm
Old Jan 18, 2012, 03:34 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Seriously?
I ordered one. Waited for 58 days, seller told me that sent me another programmer. So far - 19 days, not even single programmer (and first item i lost buying on ebay).
I guess, bad luck. Will try to buy from another seller.
Sorry for offtopic ;-)
ABLomas is offline Find More Posts by ABLomas
Old Jan 18, 2012, 03:49 AM
noppita's Avatar
Joined Jul 2009
when you want to test the motor like that, it is more safe to hold the copter from the bottom of the copter right?
and try out the EPP1045 rather than 3 blades prop,. you will see a big different.
noppita is offline Find More Posts by noppita
Old Jan 18, 2012, 03:54 AM
Joined Apr 2011
my copter is totally screwed up. which way turns pot to 0? all the way counter clockwise?
Old Jan 18, 2012, 03:56 AM
I'm new here
timecop's Avatar
Joined Dec 2010
That depends on your kkboard ,lol/
its either one way or another.
Old Jan 18, 2012, 04:02 AM
Joined Dec 2006
Originally Posted by timecop View Post
Should be standard tgy. I've flashed 18/20A version, 25/30A should be just more fets and identical pinout.
thanks. can i also check that i do not need to update the fuse settings (from the updated first page)? our escs do not have an ext osc, can/will it still run at 16mhz (looking at the tgy.inc file specifying F_CPU)?
thanks again!
noobee is offline Find More Posts by noobee
Old Jan 18, 2012, 04:33 AM
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Yeah, don't bother with the fuses unless it doesn't work. If you don't touch it, it will run at ~16MHz via OSCCAL adjustment. If you really want, you can change F_CPU to 8MHz and it will run at that speed instead; however, it normally expects either internal RC oscillator which it sets to ~16MHz, or an external 16MHz oscillator, since those are the most common types.
simonk is offline Find More Posts by simonk
Old Jan 18, 2012, 04:35 AM
Joined Apr 2011
omg i went to reset throttle and esc was armed. thumb bleeding blood errywhere, 3 broken props
face was not hit. other hand is above my head to stop bleeding
sliced thru thumb.
Old Jan 18, 2012, 04:37 AM
Joined Apr 2011
someone tell me detail how wires and sht should go. i went by the manual
Old Jan 18, 2012, 04:40 AM
Joined Apr 2011
motor 1 CW
motor 2 ccw
motor 3 cw
motor 4 ccw
nothing reversed on tx
xcopter 4.7 flashed. set throttle range already
Old Jan 18, 2012, 04:41 AM
I'm new here
timecop's Avatar
Joined Dec 2010
sliced thru thumb.
pics or it didn't happen.
Code:
; M1,CW     M3,CCW
; M2,CCW    M4,CW
Old Jan 18, 2012, 04:47 AM
Joined Apr 2011
how can i reset gyro settings
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
