Old Dec 29, 2011, 02:26 PM
autobotix is offline
Find More Posts by autobotix
Canada, ON, Toronto
Originally Posted by pug398 View Post
Paul, I am not doing anything special. Just made up ten hexes with a stop time 10uS difference. Was surprised a 50uS difference could have such a big effect on start time but mine did. Haven't done any files for new release waiting to hear back if it helped others with same esc I use or it may be nothing to it and I just got lucky. If you want to give it a try the files use a stop time between 1000uS and 1090uS. Flash any starting close with 1050 and then adjust to them.
Hmm another computer attack. Hope you guys got your AV turned up this is getting quite frequent
That was the info I needed
thanks, I am appreciative
Paul
autobotix is offline Find More Posts by autobotix
Old Dec 29, 2011, 02:32 PM
Canada, ON, Toronto
Am I correct to say this does not effecting the osc speed of the mpu.
What you are doing is adjusting the startup point of the esc BASED on the differences in the internal mpu speed.
am I correct?
Paul
Old Dec 29, 2011, 02:57 PM
larsm is offline
Find More Posts by larsm
larsm's Avatar
Germany, NRW, Münster
Joined May 2011
Originally Posted by alll View Post
Could you explain the theory behind this? (out of curiosity)
The motors get electric pules at 8 kHz or 16 kHz. 8 kHz is a very ugly tone. 16 kHz is above the frequency most people are able to hear.
larsm is offline Find More Posts by larsm
Old Dec 29, 2011, 02:58 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
It's just the frequency at which the controller PWMs (http://en.wikipedia.org/wiki/Pulse-width_modulation) the output phases in order to control the average voltage and thus speed. Faster than about 16kHz makes it out of audible range for most humans, preventing insanity. Most power supplies, etc., switch at ~20kHz. With a motor, too low a frequency / too long an interval will saturate the motor core (particularly with small motors), causing excessive current and turning it into the equivalent of voltage across a resistor. Too high/short an interval makes back-EMF sense more noisy and heats up the FETs and motor a bit more because of more on-off switching and (de)magnetization.
simonk is offline Find More Posts by simonk
Old Dec 29, 2011, 03:31 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
And the "tik", ... "tak"..."tik", "tak" of the original firmware(s), where does this come from?
alll is offline Find More Posts by alll
Old Dec 29, 2011, 03:57 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Correct. Kind of hit and miss but the 10uS steps seem to be close enough. I fixed the top end at 1900uS but the offset can be added to it
am I correct?
Paul
pug398 is offline Find More Posts by pug398
Old Dec 29, 2011, 05:49 PM
lamzis27 is offline
Find More Posts by lamzis27
Joined Mar 2011
To the esc guru's,
i really want to take advantage of flashing my esc's if i can, and why not, if it will increase performance on my hexa and quad im all for it. i posted previously about my plush 25 on my hexa and was bummed that i couldnt flash them because of sil. well my questions are:
1. its seems all plush series now have SIL any news on SIL programming in future?
2. the rctimer 20a is good to go for flashing?
3. a recommendation of esc for a hexa handling 350w motors, between the eRC 25A or HobbyKing 30A BlueSeries Brushless Speed Controller?
i have 3 types of esc on my flying machines.
plush 10a , plush 25a, rctimer 20a
lamzis27 is offline Find More Posts by lamzis27
Old Dec 29, 2011, 06:29 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
yes rctimer is good. i just bought 4 20a from them
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Dec 29, 2011, 09:13 PM
flashervn is offline
Find More Posts by flashervn
Joined Sep 2011
The internal oscillator are probably off a little between them causing start time to be a few tens of microseconds different. If you flashed them with tgy.hex I have a set of hexes that have a 10uS step between them you are welcome to try AYOR.
Pug, may I have that set of tgy hex? Thanks. How are they working on your Rctimers? Mine is 40A and I cannot to get them to start at the same time with DJI
flashervn is offline Find More Posts by flashervn
Old Dec 29, 2011, 09:21 PM
Joined Sep 2011
Not sure about your 20As but my 40As do not have ext crystal.
Old Dec 29, 2011, 09:37 PM
pia32 is offline
Find More Posts by pia32
Joined Jan 2011
I successfully flashed my Red Brick 25a ESC from HobbyKing
http://www.hobbyking.com/hobbyking/s...dProduct=18003
pia32 is offline Find More Posts by pia32
Old Dec 29, 2011, 09:41 PM
pug398 is offline
VA
Joined Nov 2009
Mine are DYS30A but look the same from what I see. They wouldn't start same on three different controllers but have been fine since flashing. I think it was said a calibration routine was going to be worked on so it may be moot point before long.
Old Dec 29, 2011, 10:44 PM
c2po is offline
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Originally Posted by Farmer_Joe View Post
Did any one manage to reflash 10A ESC from http://www.goodluckbuy.com/index.php...oduct_id=62146 it could be the same as this... http://www.himodel.com/electric/HiMo...pe_GX-10A.html
No, I put aside that one from goodluckbuy since the ATmega chip on it is much smaller that on the picture (0.5mm between pins, I guess that is called QFN/MLF packaging) and I cannot easily connect the wires to flash it.
On himodel ESC - picture can be (and it is) completely different from what they actually sell, and I've ordered from them and of course received SIL based...
UPD: now said that I'm not 100% sure if that SIL based was actually from himodel... I bought them recently from so many different places so I might those with goodluckbuy ones.
c2po is offline Find More Posts by c2po
Old Dec 30, 2011, 03:06 AM
Joined Apr 2011
http://www.hobbypartz.com/60p-dy-103...resccombo.html
DYNAM / DETRUM ESC 18A at least uses atmega8
http://www.ebay.com/sch/i.html?_trkp...&_sop=15&_sc=1
searching ebay or sites for either dynam or detrum esc yield similar results. dynam = detrum.
Old Dec 30, 2011, 03:09 AM
Joined Apr 2011
individual:
$9.70 18A
http://www.hobbypartz.com/60p-dye-1001-18a-esc.html
$10.50 25A
http://www.hobbypartz.com/60p-dye-1002-25a-esc.html
$11 30A
http://www.hobbypartz.com/60p-dye-1003-30a-esc.html
$13.38 40A
http://www.hobbypartz.com/60p-dye-1004-40a-esc.html
$26 2x40A
http://www.hobbypartz.com/60p-dye-40a-x-2-esc.html
$17.98 50A
http://www.hobbypartz.com/60p-dye-1017-50a-esc.html
$26 70A
http://www.hobbypartz.com/60p-dye-1018-70a-esc.html
i guess the bigger you get, the more efficient and cooler it will run.
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 03:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 10:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 10:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 03:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 03:31 PM
