Canada, BC, North Vancouver
Joined Dec 2010
One on each board, or just one on one board? And did it start at all first or did it immediately pop and then try to start?Also, when it fried, did you have to reset it (eg: locked up), or did it beep and work again after throttle reset (eg: brownout detection), or did it not even notice and just keep working except for the broken fet? Which build did you use? I have fried a single FET on three 18A plush boards back over the summer, but always after water exposure or some weird crash, never on the bench, and nothing recent. Yeah, it can usually start and work with the one fet blown, but timing is hard and it sounds pretty bad. I just hope there is nothing lingering that my bench supply's current limiting is covering up. |
So I armed my copter, this gave out a 1150ms signal, it did not turn smoothly right away so I disarmed, signal goes back to 1000ms. I armed again and that's when the FET poped but the motor kept spinning a little before I disarmed. I then wired all 4 ESCs. And all would spin really badly and getting the motor and ESC hot in just a mattter of seconds. I used the tgy.hex file I linked on the first post, not the one you uploaded a few days ago. I had none of this on my 30A esc and they are still working fine. I know 10A was pushing it a little for my motors but I don't think barely spinning on the bench with no prop on would draw 12+A ![]() Thanks simon |
Joined Dec 2010
In a couple days I will flash my RCT 18A and see how it goes... tigar, there is a newer tgy.hex compiled by simon a few days ago. I will most likely try this one on one of the 18A to see how it goes. I am also using the old tgy.hex in my RCT 30A and they work great! |
Here are the command lines I used: Code:
avrdude -c avrispmkII -P usb -p m8 -U flash:w:tgy.hex avrdude -c avrispmkII -P usb -p m8 -U lfuse:w:0x84:m avrdude -c avrispmkII -P usb -p m8 -U hfuse:w:0xd9:m |
| Thread Tools | |
| Discussion Rctimer 30A esc cutting out with KK board | Efliernz | Multirotor Talk | 2 | May 26, 2011 02:20 PM |
| Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors | pwu_1 | Aircraft - General - Miscellaneous (FS/W) | 2 | Jan 18, 2011 09:58 PM |
| Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! | planebldr | Aircraft - Electric - Power Systems (FS/W) | 4 | May 25, 2010 09:54 PM |
| Discussion RCTimer 30A Programmable ESC | hunter7193 | Power Systems | 8 | Jan 02, 2010 02:27 PM |
| For Sale Several New ESC's - 10a, 20a, 30a - Reduced | Callen9345 | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 20, 2009 02:31 PM |
