Old Apr 26, 2013, 07:48 AM
ChuckAdams is offline
Find More Posts by ChuckAdams
ChuckAdams's Avatar
Troy, MI
Originally Posted by WendoNZ View Post
What firmware did you flash it/them with? That side looks identical but pics of the other side would be useful
I used the kkMulticopter Flash Tool utility V0.70. The settings I used were:
Programmer: Usbasp
Port: USB
Baud rate: 19200
Firmware: BS N-Fet V2012-09-30
Have attached a picture of both sides of the ESC. Looks like the same number of components as the picture in the beginning of the thread.
When flashing the firmware everything went well. Got the successful message and everything looked good.
ChuckAdams is offline Find More Posts by ChuckAdams
Old Apr 27, 2013, 01:55 PM
wkorosec is offline
Find More Posts by wkorosec
Wolfgang
wkorosec's Avatar
St. Gallen, Switzerland
Joined Jun 2004
simonk firmware for fixed wing acro planes ?
Hi,
my name is Wolfgang, I am flying fixed-wing acro planes (F3A). I had serious problems with the acro-brake of my esc - looking for a solution I found simon's outstanding firmware and this thread.
A few words to explain the requirements:
An efficient "acro-brake" lets an electric motor behave like a combustion engine during vertical dives (gas=idle). The motor produces just enough torque to reduce (brake) the rotation speed of the propeller which reduces the speed of the diving plane by induced drag. (I hope the explanation is clear - more or less)
A working acro-brake seems to be the holy grail of esc-firmware developers. High-End products from Jeti and Kontronik for example can handle that, but they are very expensive.
Did somebody already use the simonk firmware for acrobatic planes ?
It would be great to use open-source firmware for this kind of problem !
F5B speed enthusiasts already had a similar idea - they want to modify cheap esc for their purposes:
http://www.rcgroups.com/forums/showt...ht=simonk+200a
Best regards & many thanks for your help,
Wolfgang
wkorosec is offline Find More Posts by wkorosec
Old Apr 27, 2013, 02:10 PM
ABLomas is online now
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
I suggest you to try slow BRAKE_SPEED (1-2) + COMP_PWM.
Doubt you will get such result, probably aditional circuit is needed... But that should at least produce result somewhere near wanted (prop won't stop, it will spin from incoming air, but still braking).
ABLomas is online now Find More Posts by ABLomas
Old Apr 27, 2013, 03:17 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
Originally Posted by ChuckAdams View Post
Does anyone know if Hobby King made any changes to their F-30A ESC? I flashed three of them for a Tri and they all flashed fine. When I put a battery on them the magic smoke came out almost immediately.
When I remove the shrink wrap the first component that connects to the red motor wire is fried. Thought it may have been a short the first time, but on the second run it fried a motor as well.
Used the latest software off the site with the kkmultiflashtool.
I have six of these same ESC's running in a hexcopter that I made last year and they work great. Not sure why they keep frying this time.
Definitely still bs_nfet. I would think a short to the frame perhaps or a bad motor with ashort inside it, on the up side, all the FETs are the same on that side so you should be able to get one of them working again by transplanting a good FET from the second fried one
WendoNZ is offline Find More Posts by WendoNZ
Old Apr 27, 2013, 05:33 PM
ham4864 is offline
Find More Posts by ham4864
United States
Joined Dec 2012
simonK flashing List of people
I am looking for a list of people who flash esc's to simonK.
I will not attempt this myself.
ham4864 is offline Find More Posts by ham4864
Old Apr 27, 2013, 09:48 PM
ChuckAdams's Avatar
Troy, MI
I kind of thought the same thing when the first one fried, so I took extra care on insulating my connections on the second and third one. I have taken the motor that the third ESC fried on and have run it on a good RCTimer ESC that I had, and it ran just fine.
I think the next step for me is to try flashing with an older version of the BS NFET firmware. Probably the 6/2012 one.
Old Apr 28, 2013, 03:59 AM
hollgi is offline
Find More Posts by hollgi
hollgi's Avatar
Joined Sep 2012
Sorry newbie here!
I have read now quite a bit in this and other threads but my question remains.
I want to flash a HK 30A blue using kk flash tool, hobby king usbasp tool and adapter.
I want to use the speedies on a hexacopter.
Do I load the version with boot loader activated or without?
Guess I don't really understand what the boot loader is/ does.
Thanks!
hollgi is offline Find More Posts by hollgi
Old Apr 28, 2013, 02:38 PM
WendoNZ is offline
Joined Dec 2012
The bootloader doesn't affect the operation at all, it simply allows you to update the firmware again at a later date through the servo lead rather than having to cut the shrinkwrap of again
Old Apr 28, 2013, 03:56 PM
zaggy is offline
Find More Posts by zaggy
Joined Mar 2011
Plush old gen v3.1 40A
Originally Posted by simonk View Post
See the spreadsheet and previous posts on the subject.
Thank you Simon, everything went well. Here is the confirmed pinout.
zaggy is offline Find More Posts by zaggy
Old Apr 28, 2013, 06:23 PM
hollgi is offline
hollgi's Avatar
Joined Sep 2012
Thanks mate!
Old Apr 29, 2013, 07:22 PM
rogueqd is offline
Find More Posts by rogueqd
Quads, 4 times the fun.
Australia, NSW, Brookvale
Joined Apr 2011
Have you worked out what the problem was? I'm about to flash the same ESC's, bought about 4 weeks ago, and I don't have any spares if one dies.
rogueqd is offline Find More Posts by rogueqd
Old May 01, 2013, 03:44 AM
ChuckAdams's Avatar
Troy, MI
No, have been on the road with work and will not be able to get to it till this weekend. Let me know your results if you flash them before then.
Old May 01, 2013, 07:37 AM
rogueqd is offline
Joined Apr 2011
I don't want to risk 2 weeks of down time if the flashing goes bad. I've ordered 2 spare F-30A's so I'll start flashing with them when they arrive.
Old May 01, 2013, 06:08 PM
hollgi is offline
hollgi's Avatar
Joined Sep 2012
Sorry guys, I do this the first time and are a bit unsure which file to use.
I wanna flash Simon K onto my HK 30a.
Do I need the BS N FET file?
Or which one do I use
Description: ?
Your help is appreciated.
Old May 01, 2013, 06:18 PM
George Shering is online now
Find More Posts by George Shering
Scotland
Joined May 2005
Originally Posted by wkorosec View Post
Hi,
Wolfgang
Ask also on the F5B thread you quote. I don't know how it is done. Is the braking re-generative or variable dissipative braking? Fitting a Unilog to an aerobatic plane would tell.
AB Lomas, I don't think additional hardware is necessary, but I may be wrong. It is all in the firmware.
George Shering is online now Find More Posts by George Shering
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
