Old Apr 10, 2013, 05:11 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Originally Posted by AliB View Post
1 motor connected alone would work perfectly, but if i had more than 1 motor hooked up, it would cog
Sorry if I missed the relevant parts of discussion, but in general, 1 ESC to 1 motor is a very general rule..
and if You mean more than one set of esc+motor, or something 4in1 where multiple ESCs sits together on one board, it shows only to weak battery or wires (perhaps capacitors or connectors.. simply the weak power). If one motor runs well.
coro is offline Find More Posts by coro
Old Apr 10, 2013, 07:17 AM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, Blackpool
Joined Dec 2005
no i know that you cant have more than 1 motor to 1 esc
and its not weak batteries or wires, because i had the same wiring and esc on previous motors and didnt change anything, and they had been running for over 50flights flawlessly.
when i removed that setup from my heli after giving up with it, i even remade a wiring harness with just 2 esc and motors, and i still experienced the same cogging.
AliB is online now Find More Posts by AliB
Old Apr 10, 2013, 09:14 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
I'm ready (well... i think i am) to flash my F30's with simonk but wanted to clarify a few things......
Does the VCC output on the programmer go to the pad marked +5V (as labelled in the pics in the first post of this thread) ?
When i unzipped the tgy file and clicked on the bs_nfet.hex file the companion9X dashboard came up and i got some pop ups advising that the telemetry channel order and expo settings have been changed. How do i go about using this file without it playing silly buggers with companion9X???
Heres a pic of my pogo pins
nogas is offline Find More Posts by nogas
Old Apr 10, 2013, 09:47 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
OK, i plugged in the programmer, selected USBAVR, the correct file came up, so i pushed the pins down and Hit the FLASH button and all seemed fine until i got the message 'Unable to connect to the remote server'
Now what? I've got a good internet connection, should i use the offline option?
Old Apr 10, 2013, 01:36 PM
ABLomas is online now
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Which program told you this?
ABLomas is online now Find More Posts by ABLomas
Old Apr 10, 2013, 04:11 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
The avr programmer, it came up in the space below the flash button
Old Apr 10, 2013, 11:41 PM
nogas is offline
nogas's Avatar
Joined Feb 2011
Anyone help with issue above????
Also, is an external power supply necessary, seen plenty of people do it without one but have noticed more posts lately saying that they had to use an external battery ????
Old Apr 10, 2013, 11:50 PM
JakeFrmStateFarm is offline
Find More Posts by JakeFrmStateFarm
United States, IL, Winthrop Harbor
Joined Apr 2013
I just wanted to throw this out there, people have said the HK-SS20a has been coming with the reset pin disabled. I just got 2 HK-SS30a's and both were locked out just the same. Sorry if this has been mentioned before, I didn't see it.
Originally Posted by Sandav View Post
I flashed these with just the usbasp I bought from Hobbyking, so without the LiPo.
I connected the vcc and ground from the usbasp to the + and - from the servo leads. Actually, you can connect the ground to any ground on the esc as they are all connected.
good luck
I can second this. Just flashed one tonight. Just connected the avr programmers power and ground to the servo lead and it worked fine.
JakeFrmStateFarm is offline Find More Posts by JakeFrmStateFarm
Old Apr 11, 2013, 12:12 AM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
What program were you running on your PC? Where did you get it from?
"The avr programmer" is the piece of hardware you connect to your PC, not the software running on it
WendoNZ is offline Find More Posts by WendoNZ
Old Apr 11, 2013, 12:39 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
Yes, thank you i understand that but i'm not sure the program has a name. Its the same program everyone else seems to be using, i used it to flash my 9XR, i think the file name was called debug???? Not near my home computer right now so cant access it to confirm any more details.
I cant remember where i got it from.
Old Apr 11, 2013, 12:40 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
So should i not be connecting the VCC and + directly to the pogo / pads??
Or is that info directly related to the esc's your using?
Old Apr 11, 2013, 01:03 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Probably using ancient chatch tool to flash?
Just read first post. Or take tool directly from http://lazyzero.de/en/modellbau/kkmulticopterflashtool
Old Apr 11, 2013, 09:43 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
OK, maybe i'm not cut out for this firmware flashing gig. After spending 2 nights just trying to get the programmer to work i'm just about ready to throw in the towel.
I have downloaded the KKmulticopterflashtool v.71 and opened it up but it doesn't seem to be doing what it should.
Die molls instructions state
Select your programmer and “atmega 8-based brushless ESC + enable Bootloader” and proceed as always. (!!!select correct firmware)
Wait till verification is successfully done and “avrdude done. Thank you.”
USBASP came up automaticaly and thats what i've got so i left it at that, I've selected ATMEGA 8-based esc + enable bootloader, but i cant select the correct firmware. There is no bs_nfet.hex firmware, in fact there is only about 8 different options. When i try to open the simonk and wiiesc compatibility table i get a google chrome warning, titled 'bad image' stating such and such a file is not designed to run on windows or contains an error and to reinstall it.
After some more reading I then discovered that i shouldn't use firefox to download the tool (as its 32 bit and the tool needs 64 bit browser) so i downloaded with IE but now have a new error, "no JVM could be found on your computer" .
I have tried downloading a 64 bit java jvm but it hasn't made any difference that i can see.
I am seriously lost now and am about to give up as i just cant understand how something that seems quite straight forward can be so difficult?????
Old Apr 11, 2013, 10:01 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Did you install the 64-bit Java? What Windows do you use?
Christian
LazyZero is offline Find More Posts by LazyZero
Old Apr 11, 2013, 10:06 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
I did install 64 bit java (well i think it installed), i am using windows 7.
The file that downloaded from java is named jre-7u17-windows-x64 is this correct?
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 03:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 10:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 10:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 03:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 03:31 PM
