Old Apr 06, 2013, 03:07 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
I'm pretty sure you have to have enabled the fuse bits to boot the bootloader first, at least that's how every other AVR chip I've ever seen works
WendoNZ is offline Find More Posts by WendoNZ
Old Apr 06, 2013, 03:10 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
I know how to reflash my Nano, no problems there. I even used it to reflash a bunch of ESCs. However, where does the ESC wires go (GND, VCC and SIG)? You mention a bunch of pins in the readme, pins which I cant find on it.
Maybe it'll just be easier to cut away some of the heatshrink and resolder the wires. Takes a minute or two.
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 06, 2013, 03:12 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
If the servo wire is held high (eg. USB Linker) then it will switch to running the bootloader code. It's not an avr/arduino thing, it's a feature of the simonk firmware.
LittleMo is offline Find More Posts by LittleMo
Old Apr 06, 2013, 03:15 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Start with the directions at the top of the README, it has a list of steps in a bulleted list. There is only one pin mentioned, that is PD2/INT0 (digital pin 2).
The other stuff down low is for more complicated usage (like with MultiWii or using other pins).
Of course re-soldering is not that hard but it's worth it to get the linker running because from then on it's so easy you never have to think about reflashing.
Edit:
I was just thinking maybe I could draw a picture that shows how everything is hooked up. That might make it clearer. I'll do that when I get a chance. Really it's just digital pin 2 and ground that need to be connected between the arduino and servo wire.
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by LittleMo View Post
Which part? Maybe I can walk you through it. The KK flash tool has direct support for the Arudiono USB Linker.
Depends on which firmware, newer versions can enter the bootloader at any time even if it's not enabled.
It also helps you in making a Arduino USB Linker. See http://lazyzero.de/en/modellbau/kkmu...duinousblinker
for more informations on that.
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Apr 06, 2013, 04:12 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Ah, right, so PD2 = Pin D2. Should've been able to figure out that one. Durr.
Old Apr 06, 2013, 04:17 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Nevermind, used KKFlashtool, worked!
Old Apr 06, 2013, 04:21 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Excellent, I didn't even know that was there myself.
How's this picture for a start:
Old Apr 06, 2013, 04:25 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Great!
Although I wonder why it wouldn't compile for you the first time. Seems strange like it couldn't find the EEPROM header.
Old Apr 06, 2013, 04:30 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Well, the Lazyzero flash tool is throwing a whole heap of red messages at me. Didn't use a regulated supply though. I guess I'm gonna have to hook up a 1S lipo or something to this, or use a BEC. I just hooked up a 3S lipo to the ESCs but maybe that's not OK.
Old Apr 06, 2013, 04:37 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Actually a 3S or whatever should work, it's just a little risky in case the motors spin.
Can you copy the errors you get and post them here?
Also, do you know which version of the firmware you have on there? It may not be able to enter the bootloader if it wasn't enabled and your firmware is very old.
Old Apr 06, 2013, 04:41 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Flash the firmware file.
C:\Users\WiseDuck\Downloads\kkmulticopterflashtool _0.71beta7\lib\avrdude\windows\avrdude.exe -C C:\Users\WiseDuck\Downloads\kkmulticopterflashtool _0.71beta7\lib\avrdude\windows\avrdude.conf -p m8 -P COM11 -c stk500v2 -b 19200 -B 8 -e -U lfuse:r:C:\Users\WiseDuck\Downloads\kkmulticopterf lashtool_0.71beta7\tmp\/lfuse.hex:r -U hfuse:r:C:\Users\WiseDuck\Downloads\kkmulticopterf lashtool_0.71beta7\tmp\/hfuse.hex:r
avrdude.exe: stk500v2_ReceiveMessage(): timeout
avrdude.exe: stk500v2_command(): command failed
avrdude.exe: stk500v2_getparm(): failed to get parameter 0x98
avrdude.exe: Unable to get parameter 0x98
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.10s
avrdude.exe: Device signature = 0x1e9307
avrdude.exe: erasing chip
avrdude.exe: reading lfuse memory:
Reading | ################################################## | 100% 0.03s
avrdude.exe: writing output file "C:\Users\WiseDuck\Downloads\kkmulticopterflashtoo l_0.71beta7\tmp\/lfuse.hex"
avrdude.exe: reading hfuse memory:
avrdude.exe: writing output file "C:\Users\WiseDuck\Downloads\kkmulticopterflashtoo l_0.71beta7\tmp\/hfuse.hex"
avrdude.exe done. Thank you.
C:\Users\WiseDuck\Downloads\kkmulticopterflashtool _0.71beta7\lib\avrdude\windows\avrdude.exe -C C:\Users\WiseDuck\Downloads\kkmulticopterflashtool _0.71beta7\lib\avrdude\windows\avrdude.conf -p m8 -P COM11 -c stk500v2 -b 19200 -B 8 -e -U lfuse:w:0:m -U hfuse:w:10:m
avrdude.exe: reading input file "0"
avrdude.exe: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.03s
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 0:
avrdude.exe: load data lfuse data from input file 0:
avrdude.exe: input file 0 contains 1 bytes
avrdude.exe: reading on-chip lfuse data:
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of lfuse verified
avrdude.exe: reading input file "10"
avrdude.exe: writing hfuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.26s
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 10:
avrdude.exe: load data hfuse data from input file 10:
avrdude.exe: input file 10 contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
avrdude.exe: verification error, first mismatch at byte 0x0000
0x00 != 0x0a
avrdude.exe: verification error; content mismatch
Error during reading of high fuse.
Flashing of firmware aborted.
Old Apr 06, 2013, 04:45 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
<snip>
LazyZero might be able to answer better than me but do you have the bootloader option enabled? You might need to turn that off. It looks like it's trying to set fuses and that doesn't work over the USB Linker.
Old Apr 06, 2013, 04:49 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Tried without the "enable bootloader" thing. Failed again. Might as well do this the traditional way, would've been done by now if I had.
Flashing firmware from file.: C:\Users\WiseDuck\Downloads\simonk_avra1.3.0_windo ws\tgy.hex
C:\Users\WiseDuck\Downloads\kkmulticopterflashtool _0.71beta7\lib\avrdude\windows\avrdude.exe -C C:\Users\WiseDuck\Downloads\kkmulticopterflashtool _0.71beta7\lib\avrdude\windows\avrdude.conf -p m8 -P COM11 -c stk500v2 -b 19200 -B 8 -e -U flash:w:C:\Users\WiseDuck\Downloads\simonk_avra1.3 .0_windows\tgy.hex:i
avrdude.exe: reading input file "C:\Users\WiseDuck\Downloads\simonk_avra1.3.0_wind ows\tgy.hex"
avrdude.exe: writing flash (8192 bytes):
Writing | ################################################## | 100% 6.30s
avrdude.exe: 8192 bytes of flash written
avrdude.exe: verifying flash memory against C:\Users\WiseDuck\Downloads\simonk_avra1.3.0_windo ws\tgy.hex:
avrdude.exe: load data flash data from input file C:\Users\WiseDuck\Downloads\simonk_avra1.3.0_windo ws\tgy.hex:
avrdude.exe: input file C:\Users\WiseDuck\Downloads\simonk_avra1.3.0_windo ws\tgy.hex contains 8192 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 5.58s
avrdude.exe: verification error, first mismatch at byte 0x1ed0
0x49 != 0x48
Error during writing flash.
Old Apr 06, 2013, 04:57 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Sometimes it goes that way.
It looks like it "successfully" wrote the new firmware but also looks like it's the same problem I had with the very latest simonk firmwares not being able to update with the USB Linker (which Simon can't recreate ).
It's probably updated to something (unknown) relatively recent but it might be risky to run the ESC that way (I'm paranoid though) so you might might want to try updating the old way, sorry.
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
