Old Mar 07, 2013, 03:20 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Robbe Roxxy 730
Just tested with PWM_COMP enabled:
Motor starts and runs, but on a regulated power supply, voltage drops quickly amps get up too much!
Thought this esc has all n-fets, PWM_COMP is nod advised at first.
Simon, can we do something to it?
I saw that the power capacitor was heating while running for a few seconds! There is some king of shorting there ?...
manu
PS: I tried also wii_esc (had to modify rb50a.inc). With pwm_comp enabled it doesn't run as with Simonk fw, it stops before amps get up.
Code:
//orig #define CnFET           7
//orig #define CpFET           5
#define ApFET           7
#define AnFET           5
//orig #define BpFET           4
//orig #define BnFET           3
#define BnFET           4
#define BpFET           3
#define rcp_in          2
//orig #define AnFET           1
//orig #define ApFET           0
#define CpFET           1
#define CnFET           0
Originally Posted by LazyZero View Post
Okay I have to reply to my own post.
JÜRGEN_ wrote me a PM saying that Roxxy 730 is equal design than DragonSky60A and that is equal to RC Timer 50A.
So I tried rct50a.hex and it works like a charm.
Thanks again
Christian
alll is offline Find More Posts by alll
Old Mar 07, 2013, 03:41 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Anywhere sell decent preflashed ESCs?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Mar 07, 2013, 04:22 PM
shersey is offline
Find More Posts by shersey
USA, WA, Tacoma
Joined Mar 2009
I've purchased preflashed ESC's from TheFernMan here on RCGroups and was happy with them.
I've also purchased ESC's from rcmanchild.com and I am happy with them too.
shersey is offline Find More Posts by shersey
Old Mar 07, 2013, 04:48 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
TheFernMan is offline Find More Posts by TheFernMan
Old Mar 07, 2013, 08:03 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
OK, I want this so bad. Finally combining the simplicity and robustness of a multirotor with the maneuvering ability of a helicopter.
mwc quad // ultraesc 3d (2 min 53 sec)
Can this be done with simonk and normal ESC's? Maybe by using the car reverse setting or is it not fast enough?
LittleMo is offline Find More Posts by LittleMo
Old Mar 08, 2013, 01:08 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Hi!, +1
Mwii code adaptation:
http://www.multiwii.com/forum/viewto...8fb28a619d5585
Yes, car reverse + motor break? + pwm_comp
I will definitely try it, when i have time
manu
PS: "with the maneuvering ability of a helicopter"
Goblin 770 Final Version in Lodrino, Switzerland (4 min 2 sec)
https://vimeo.com/61127136
Old Mar 08, 2013, 01:40 AM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
What does this tone mean? It happens when i rev the motors really fast...
ESC Tone - SimonK firmware (0 min 22 sec)
It will be a different ESC each time, well more like random because it can happen to the same one.
ESCs: rctimer 10amp flashed with SimonK tgy.hex. I've tried swapping in new ESCs and different motors as well as a different flight control board.
All my other copters although much larger use SimonK or WiiESC with out issue.
Thanks.
Dolby is offline Find More Posts by Dolby
Old Mar 08, 2013, 03:01 AM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
Beep codes are at the bottom of this page, it sounds like a voltage brownout, which would make sense if you're seeing it at high throttle.
Can your battery supply enough current to your setup at full throttle?
WendoNZ is offline Find More Posts by WendoNZ
Old Mar 08, 2013, 03:21 AM
quad007 is offline
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
sense caps for nfet blueseries 12a
quad007 is offline Find More Posts by quad007
Old Mar 08, 2013, 04:15 AM
Dolby is offline
Needs more bacon!
Dolby's Avatar
Joined Jan 2011
Thanks! Voltage on my telemetry looks fine maybe an issue with my harness (although has worked fine for years maybe there is some corrosion).
Old Mar 08, 2013, 06:20 AM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Originally Posted by alll View Post
Hi!, +1
manu
Thanks for the link!
Yeah, I'm being a bit dramatic since a fixed pitch will never have the pop of high head speed and instaneous collective changes. However, it would be really great for practicing inverted skills without having to maintain a complicated and always breaking helicopter. I think the main problem is going to be finding decent reversable props. Especially ones that won't break from the torque of high speed reversal.
I am wondering if these "ultra" ESCs do something that simonk can't.
I have been meaning to test COMP_PWM on my Blueseries 12a's anyway. I need to get on that. Anyone know if it works?
Old Mar 08, 2013, 07:07 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
They work very well, you hear it already when running idle.
As said, esc that will be able to quickly reach their set-point is a must have for multi's (accelerating AND decelerating)! So if we could have a better (more accurate) feedback on motor position, a PID control loop would be heaven. And i don't care if i have to tune it for each different kind of motors.
So, the multicopter can go to the next stage, mainly by improving the esc responsiveness IMHO.
I have only to do the mwii_code adaptation to test it out.
Lets start the race
manu
PS: and yes, the simplicity of multis should be maintained, no collective setups.
Old Mar 08, 2013, 10:25 AM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Lets start the race
I wonder if both MOTOR_BRAKE and COMP_PWM need to be enabled. Don't they sort of do the same thing?
Or I wonder if it might break something to enable both. I just tested with both enabled and nothing bad happened but it seems like MOTOR_BRAKE is unnecessary and may interfere with COMP_PWM but it's not clear.
Edit:
I ran some tests with MOTOR_BRAKE on and off. It seems to reverse direction and get up to speed slightly faster with MOTOR_BRAKE enabled but that is subjective. It's also noisier, making lots of squeaking sounds. Maybe COMP_PWM isn't needed. So I guess I still don't know what configuration is best.
After thinking about it, I don't imagine this will fly much like a helicopter at all. When you change pitch on a heli it still has air resistance even at zero pitch but on a multirotor "zero pitch" is going to mean slow spinning props and little air resistance (ie. it's a falling brick ).
Old Mar 08, 2013, 12:45 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Damn, you started first
The idea is to "launch" the quad upwards, flip, reverse throttle...
Faster descends, ...
It will never be like a variable pitch, but more a proof that SimonKEsc / MWii_esc can also do it... or not, or will soon with improved firmware.
manu
Old Mar 08, 2013, 01:58 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
manu
Well I'm not flying yet . I had to adapt the patch for MultiWii_shared and get everything flashed (plus test COMP_PWM with my motors). Flashing the ESC's from MultiWii was "interesting" because with the patched MultWii and unpatched ESC's they would start spinning right away as MultiWii booted. I should have flashed the ESC's first. (Edit: see the warning below, that's why they would start spinning)
I do have it running on my quad now but around center throttle some of my motors tend to stop. I guess I need to adjust the minimum or something. Probably a dead band mismatch between MultWii and simonk.
Edit:
Also BIG WARNING, when MultiWii is reset the motors will spin up as it boots. Every time.
Also, if you have FAILSAFE in MultiWii it will most likely make the motors run backwards when it turns on.
I'm also not sure what happens if LEVEL mode is turned on and you're inverted. Does it flip back over but keep the motors running backwards? That would be bad. The level code may need to be modified so it will fly level inverted.
Obviously lots of patching needs to be done.
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 03:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 10:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 10:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 03:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 03:31 PM
