HVSK-40A Multicopter Brushless ESC 40A (OPTO)
![]() Hi all, I bought these from RCTimer and am a little unsure which firmware to use as RCT says the firmware used is tgy_debug.hex but I do not see that in the list of firmwares when I download the SimonK GitHub Zip. Also, I checked out the spreadsheet from post 1and I am also a little unsure as to where these ESC's fit in? RCTimer seems to eludes to these having an external oscillator, but it does not appear so from the spreadsheet. Thanks |
Germany, BY, Munich
Joined Mar 2012
The OPTO version is the same board layout like the previous one, there is no OPTO on the board and no BEC circuits. The firmware is the same, tgy.hex. From the 6 I got, one is not working, when changing the throttle a little faster the motor gets stuck. |
Joined Dec 2009
.It looks like the ESC has a SiLabs chip (on the inside), in fact it looks very similar to the Plush 40A, except that the BEC components have not been mounted. 99% sure you can use the Plush 40A code. But of course in order to avoid magic smoke, it is advisable to use current limiting .
Thanks for the reply. I am not very good at understanding exactly how ESC's work. but in the attached photo Thanks to anyone who can help me understand this better. **EDIT** I now see that is not the Opto. That thing is supplying 5V to atemega...and I just paid to much $$ for a misleading advertised ESC. |
Joined Apr 2012
Joined Feb 2013
Hi Alpha,
Kda.hex for Keda should work! Have look to this table: https://docs.google.com/spreadsheet/...BQkZZRlE#gid=0 The Multistars are also there(with their OrderNr from HK) Cheers |
Germany, BY, Munich
Joined Mar 2012
do you think it is a SiLabs chip? Any idea how I can identify which of the 3 pins needs to be connected to the programmer? I guess ground could be identified easily. Can I assume the next to ground is plus, which I don't need to connect, and the next 2 are the programming pins? |
Joined Dec 2009
Joined Jan 2009
Hi all
I bought these opto ESC before I found this amazing post on flashing ESC, these are on their way to me; has anyone flashed these? http://www.hobbyking.com/hobbyking/s..._4S_OPTO_.html I have 4 Turnigy Plush 60A that have sat around for a while, 3 are Atmel 8 and 1 is Silab; I want to flash the Atmel 8 can any one point me in the right direction in regards to the pinout pads; I've used a multi to test the pins. I've looked at all the pictures in this post with Atmel MCU and I believe that the factory flash tool may be set up in a default format in this order ( reset,Vcc,Grnd,SCK,MISO,MOSI ) reading the MCU from right to left or from pin 16. I'll load a picture when I fix my camera. I've read so much that I have brain fade now so, my other question is this since I have Atmel studio 4 and AVR2 stick that came with my Flycam KK black board can use it to flash the ESC's with a slight mod to the AVR stick like the HK one? I have already got the Hex files from Overdude? |
I'm waiting them to arrive from HK but usually it takes up to 1 month due to looooong italian custom inspection. I suppose you'll receive yours before me. Willy. |
Joined Jan 2009
![]() HK won't be able to sell these "Opto from the UK warehouse if they are not really Optos" because of the trade descriptions act in force here in the UK. I'm hoping my copter will fly better soon; I was encouraged when I changed to 20A Hobbywing but the Amp rating is too low for my 1.9 copter |
Germany, BY, Munich
Joined Mar 2012
I have flashed the 'black sheep' and will give them a last try, hope there is no big difference in the ESC behavior ... |
| Thread Tools | |
| Discussion Rctimer 30A esc cutting out with KK board | Efliernz | Multirotor Talk | 2 | May 26, 2011 02:20 PM |
| Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors | pwu_1 | Aircraft - General - Miscellaneous (FS/W) | 2 | Jan 18, 2011 09:58 PM |
| Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! | planebldr | Aircraft - Electric - Power Systems (FS/W) | 4 | May 25, 2010 09:54 PM |
| Discussion RCTimer 30A Programmable ESC | hunter7193 | Power Systems | 8 | Jan 02, 2010 02:27 PM |
| For Sale Several New ESC's - 10a, 20a, 30a - Reduced | Callen9345 | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 20, 2009 02:31 PM |
