Old Feb 05, 2013, 07:18 AM
Mike Carrio is offline
Find More Posts by Mike Carrio
It's all about FPV
Puerto Rico, Hatillo
Joined Sep 2012
Originally Posted by jetbootz View Post
yes I have. it rocks... !
all the ESCs in the photos in the post I made above were flashed with this item
beware though. ... pressing down with just the right amount of force is needed, not too much not too little its a real nack you have to get going. I actually thought it was broken first as it didnt seem to flash or even connect.. but after a while i got it. perseverance is needed..
Great tool, agree with jetbootz about the amount of pressure required to establish a good connection. Whenever I place the tool on the chip I would get a sound from the computer like the sound Win7 makes whenever a device is connected to an usb port in the pc. This helps me to determine I have a good connection, and when the connection breaks the pc will make the sound just like when something is unplug from an usb port. Hope this tip helps.
Mike Carrio is offline Find More Posts by Mike Carrio
Old Feb 05, 2013, 08:29 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
So I desoldered my motor wires on my esc for my f30's.
How much heat can those FETs handle? One of them got a little hot when I desoldered it. Couldn't pass the three second finger rule. So I cooled it off with a sponge.
stgdz is offline Find More Posts by stgdz
Old Feb 05, 2013, 03:05 PM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
just a guess but without current flowing in them at the same time I would think much more than when in use ,your probably safe
irun4fundotca is online now Find More Posts by irun4fundotca
Old Feb 05, 2013, 11:46 PM
rukie is offline
Find More Posts by rukie
rukie's Avatar
Philippines, Central Luzon, Marilao
Joined Jun 2008
Hi I noticed that the turnigy f50 is not included in esc compatible for simonk fw? is this just an accident they missed out or I really cant flashed the f50 with simonk?
rukie is offline Find More Posts by rukie
Old Feb 05, 2013, 11:59 PM
Flying Wood For Fun
Joined Jan 2012
Can anyone recommend a good size of heatshrink that will work for say a plush 40a?
I have 50mm but i think thats a bit big lol
Old Feb 06, 2013, 12:27 AM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
I use 25mm on the HK BlueSeries 30A and it's plenty big enough. Compare sizes on HK and if they are close/the same then 25mm will work
WendoNZ is offline Find More Posts by WendoNZ
Old Feb 06, 2013, 12:32 AM
Flying Wood For Fun
Joined Jan 2012
check out this cool pattern
In black
http://www.ebay.ca/itm/X-Tube-Heat-S...item460c804f63
or in yellow,green,blue,red
http://www.ebay.ca/itm/X-HEAT-SHRINK...item2a28de6967
it would look good on a quads matching color scheme
Old Feb 06, 2013, 08:38 AM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
Buying the correct size heat shrink is annoying. Some places list the size before it's shrunk and others list it as the size it shrinks to.
As WendoNZ mentioned above, the shrink I have gotten from Hobby King seems to list it as the size it shrinks to. The un-shrunk size you get is around twice that size.
Other places could vary so you have to look to see if they say which size they are referring to. Many don't say at all so it's a gamble. Like I said, annoying.
LittleMo is offline Find More Posts by LittleMo
Old Feb 06, 2013, 09:12 AM
willy163 is offline
Find More Posts by willy163
willy163's Avatar
Italia, Piemonte, Strambino
Joined Feb 2010
Hi everybody.
Uh... what a HUGE discussion!
I've a question.
I've bought this ESC:
Turnigy Multistar 20 Amp Multi-rotor Brushless ESC 2-4S (OPTO)
This is the cheapest OPTO version I've found.
I've seen in supported ESC list that non-opto version is supported.
Question is: does anybody own this (also non-opto version)?
Are there real improvements using SIMONK FW in Turnigy Multistar ESCs?
Once arrived, I can dismount mine and do a reverse engineering.
Thank you,
Willy.
willy163 is offline Find More Posts by willy163
Old Feb 06, 2013, 10:25 AM
hexacop is offline
Find More Posts by hexacop
Hexapilot
Germany, BY, Munich
Joined Mar 2012
Originally Posted by willy163 View Post
Hi everybody.
I've a question.
Thank you,
Willy.
Do you really believe that ESC has a real optocoupler??? Forget it, I would be surprised, all the other HK ESC, Maytech and RCTIMER <40A at this low price tag have NO OPTO.
All this ESC have NO BEC components on the board and HK calls them 'OPTO' to confuse the customer.
See my other post here:
http://www.rcgroups.com/forums/showthread.php?t=1807625
YES please post pictures of the board as soon you get it.
hexacop is offline Find More Posts by hexacop
Old Feb 06, 2013, 12:11 PM
willy163 is offline
willy163's Avatar
Joined Feb 2010
Damn... I hope it's not just an illusion...
Anyway, as soon I get it I'll post a very detailed picture.
If I have time, I'll put it inside our Flying Probe tester to reverse engineer it.
Unlikely, here in Italy custom inspections are terrible, so I have to wait up to one month (!!!) to receive my order from HK.
But... my question is still there: is there a real performance improvement flashing Turnigy Multistar ESCs witk Simonk FW?
Thank you everybody.
Willy.
Old Feb 07, 2013, 02:04 AM
TNboy is offline
Find More Posts by TNboy
User registered
TNboy's Avatar
Melbourne Australia
Joined Jan 2004
G'day all, Am I correct in saying, that if I flash my Multistar 45amp ESC with the kda.hex file, I will no longer be able to use the Multistar programming card.?
If that's true how would I set say the cutoff voltage or brake type etc etc ?
Many thanks for the learned replies..
TNboy is offline Find More Posts by TNboy
Old Feb 07, 2013, 02:49 AM
hexacop is offline
Hexapilot
Germany, BY, Munich
Joined Mar 2012
Yes, you are right, as soon you flash it, all of the previous features are gone but you get other benefits, see Simonk description on https://github.com/sim-/tgy
The only thing you will be able to change is the throttle min/max values.
Old Feb 07, 2013, 04:56 AM
TNboy is offline
User registered
TNboy's Avatar
Melbourne Australia
Joined Jan 2004
Thanks so much for reminding me about that page. As I am hoping to solder the ESC's direct to the motors, Am I to believe that the file that is named 'reverse' will reverse the direction of rotation as opposed to the other similar named file but not with reverse in the name ? (just checking I am understanding the text correctly in simon K's notes).
I pretty sure that'll be my last question, and I'll then commit one ESC (I purchased a spare for the flash testing) to the flashing process and report back to the forum.
Once again many thanks.
Old Feb 07, 2013, 06:20 AM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
Hey i got these rctimer 30a preflashed escs, they look different than the old ones?!
or are they just using different fets? can i still use the tgy.hex ?
New
Old and New
V_Okto is offline Find More Posts by V_Okto
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
