so, i would like to know if i can re-flash normal simonk version 09-30 to this esc. |
did you experienced it with 6s lipo? |
Simonk, please help
i think there is some issue or problem with this HVSK 40 amp from rctimer, more than one person experience the same problem. not sure if problem with hardware or software. I would to ask you for the following 1. the firmware in this esc is tgy_debug? it is different from your normal version 09-30 right? 2. can i re-flash your 09-30 version to this esc or not? i have been using version 09-30 on F40 hobbyking for many escs and without any problem. |
Creating your own LittleMo's ArduinoUSBLinker
Hi,
I worked a bit on the flashtool and now you can make your own ArduinoUSBLinker with a few clicks. See the video to figure out how it works.
Detailed Instructions on http://lazyzero.de/en/modellbau/kkmu...duinousblinker More Arduino's will be added the next days. Best Christian |
Simonk, please help
i think there is some issue or problem with this HVSK 40 amp from rctimer, more than one person experience the same problem. not sure if problem with hardware or software. I would to ask you for the following 1. the firmware in this esc is tgy_debug? it is different from your normal version 09-30 right? 2. can i re-flash your 09-30 version to this esc or not? i have been using version 09-30 on F40 hobbyking for many escs and without any problem. 3. which file in version 09-30 should i use for this rctimer red 40 amp? |
Best Christian |
Hi guys again...
firstly i'd like to thank the people who helped me last time I frequented this forum in November 2012 : SimonK Greebo ABLomas LAzyzero after much thinking I ended up with a pile of perfectly working flashed ESCs ! see pics below. many flights enjoyed since then ![]() now I have another question : I am thinking about a big heavy lift OCTO build and am considering the HKBlueseries ESCs again, I do have some 40 AMP versions still left over from my Nov 2012 flashing session but am always thinking bigger is better ie more headroom and safer. So , if I buy this : http://www.hobbyking.com/hobbyking/s...ontroller.html or maybe I just get the 60 amp version : http://www.hobbyking.com/hobbyking/s...ontroller.html my question is do I just flash them with the 40 amp blueseries simonK FW ? Is it going to work on these ? I assume these are simply bigger version of my 40 amp ones and so it should work ??? thanks again everyone, flying multicopters with simonK FW is like night and day diffference to normal ESC
40A even on 3S setup is over 400W, over 3KW octo? You will be lifting entire filming crew or what? Check your motor recommendations before going to use those heavy ESC's. |
ha! I know its overkill. its going to be a DW skyjib 8 V2 lifting heavy camera maybe sonyFS100. ill be using these
http://www.rctigermotor.com/show.php?contentid=144 max current 30amp . ill be using 6S 380KV 15 inch props. I just come from full size aviation background where safety factor is at least 2.5 x therefore 70 amp seems OK! I do realise ill probably only ever pull about 15 amp each motor but ESCs are cheap and camera are not ! just thinking out loud thats all .. still, will the FW work on those big bad ESCS ?????
JXF 15x6 ( my prop choice ) at 85 % throttle pulls 14.3 amps.
70 amp ESC probably is too big eh ? but 40 seems a bit close only being 2 x max amp pull possible. what if I flash the 60 amp ESC version ? will FW work on the 60 amp version ?? cheers everyone great thread this one
Everything above that - only waste of resources (more weight - aditional 200g on ESC's alone, etc). |
do you have motors for your hevey octo yet? how about low price tiger motor, mt4008, mn3510, mn4014? |
| Thread Tools | |
| Discussion Rctimer 30A esc cutting out with KK board | Efliernz | Multirotor Talk | 2 | May 26, 2011 02:20 PM |
| Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors | pwu_1 | Aircraft - General - Miscellaneous (FS/W) | 2 | Jan 18, 2011 09:58 PM |
| Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! | planebldr | Aircraft - Electric - Power Systems (FS/W) | 4 | May 25, 2010 09:54 PM |
| Discussion RCTimer 30A Programmable ESC | hunter7193 | Power Systems | 8 | Jan 02, 2010 02:27 PM |
| For Sale Several New ESC's - 10a, 20a, 30a - Reduced | Callen9345 | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 20, 2009 02:31 PM |
