Old Jan 25, 2013, 12:00 AM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
HK20amp
Originally Posted by presa1200 View Post
so you mean there no way to back up the original firmware ? I thought you can read from the ATMEL chip
Warning: I haven't tried this one but the F40A original FW I got from the same place works.
RedSky is offline Find More Posts by RedSky
Old Jan 25, 2013, 12:50 AM
presa1200 is offline
Find More Posts by presa1200
presa1200's Avatar
Joined Nov 2010
Originally Posted by RedSky View Post
Attachment 5477395
may i know where you get this firmware ? or did you get it yourself?
anyway tq very much i will test when this esc on my hand , hope it work but it's ok if kill the esc since it cheap
presa1200 is offline Find More Posts by presa1200
Old Jan 25, 2013, 01:16 AM
Kotze101 is offline
Find More Posts by Kotze101
Quarry Rat
Kotze101's Avatar
South Africa, KZN, Durban
Joined Aug 2007
Can somebody please advise me on exactly which settings to use to flash HK-SS30A-HW ESCs? I've got the flashing tool from HK. When I place it on the chip the motor starts to beep but when I try to flash I get the "rc=-1" error. Im using the "atmega 8-based brushless ESC) controller... Thnx
Kotze101 is offline Find More Posts by Kotze101
Old Jan 25, 2013, 02:24 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Did you power the esc from a current limiting power supply? I never got it work to flash with the hk flash tool with direct powering from usbasp.
Christian
LazyZero is offline Find More Posts by LazyZero
Old Jan 25, 2013, 02:30 AM
Kotze101 is offline
Quarry Rat
Kotze101's Avatar
Joined Aug 2007
Christian
Hi Christian. No I havent connected anything else to the ESC, just the motor. Do I need to add any power to the other side and if so how many volts? I do remember reading somewhere to use low volts or something like that... Thnx
Old Jan 25, 2013, 02:38 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Anything from 7-12V is okay but it must limit the current. So put a car bulb in line with the battery if you have no adjustable power supply.
Old Jan 25, 2013, 03:02 AM
Kotze101 is offline
Quarry Rat
Kotze101's Avatar
Joined Aug 2007
Thanks I will try that tonight. Just out of curiosity why would one need to limit the current during the process?
Old Jan 25, 2013, 03:15 AM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
To not destroy the FET if you choose wrong firmware or something other went wrong during flashing.
Best Christian
Old Jan 25, 2013, 04:47 AM
RedSky is offline
Joined Sep 2011
It was posted by a contributor here - Simon K gave me a reference to it
http://www.rcgroups.com/forums/showp...postcount=4393
And I think I have used it on an F30A and it worked. (I've done so much flashing and testing I've almost lost track of it)
Old Jan 25, 2013, 11:01 AM
presa1200's Avatar
Joined Nov 2010
TQ very RedSky , hope it will work on F-20A
Old Jan 25, 2013, 11:19 AM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
I find that 5V generally works too. Has anyone found that 5V does not work?
I power my whole quad (4 ESC's with motors plus FC) with a 5V 1A supply when I flash them all.
LittleMo is offline Find More Posts by LittleMo
Old Jan 25, 2013, 12:59 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
A 9v battery is the simplest and easiest way I've found
WendoNZ is offline Find More Posts by WendoNZ
Old Jan 25, 2013, 01:39 PM
kaakku is offline
Find More Posts by kaakku
Joined Feb 2012
Sambas you did it ! Thanks!
Originally Posted by kaakku View Post
I flashed 45A Multistar ESC with kda.hex.
No success.
Has someone been successful in flashing Multistar 45A?
This works:
Turnigy MultiStar 45A + simonk dlu40a.hex
Turnigy MultiStar 45A + simonk dlu40a.hex (1 min 5 sec)
kaakku is offline Find More Posts by kaakku
Old Jan 25, 2013, 04:38 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
This works:
http://www.youtube.com/watch?v=3pSS5EARsJA
Kaakku,
Thanks for the info. Now I can flash them
chewy
chewytm is offline Find More Posts by chewytm
Old Jan 25, 2013, 07:48 PM
DroneBuilder is offline
Find More Posts by DroneBuilder
United States, TN, Brentwood
Joined Oct 2010
Hey guys -
I am helping a friend who is about to flash some eRC 45a (Not opto-isolated) speed controls.
I have done a million eRC 35a ones (using bs_nfet.hex), and I have flashed several 65 and some 80a eRC ones (using bs.hex).
But I have not done the 45a ones. I see a nice picture in the first post of an eRC 45a speed controller, but no mention of which hex file to use! The pic was posted by SeismicCwave.
The reason for my concern is that someone posted in this thread that bs.hex did not work well with his ZTW 45a opto ESC, so he instead used bs40a.hex. I understand that the eRC esc's are rebranded ZTW's, so that is why I am concerned. But as I noted above, the ones my friend will be working on are NOT opto-isolated.
I don't want to toast one of these eRC45's, so: does anyone know which file to use?
DroneBuilder is offline Find More Posts by DroneBuilder
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
