Old Jan 22, 2013, 03:36 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Haaa, you are there , wait i try...
manu
Originally Posted by simonk View Post
Sorry, apparently it's difficult, since somebody else couldn't get it, either. I made this: http://0x.ca/sim/tmp/pwm_deadband.asm Does that help?
alll is offline Find More Posts by alll
Old Jan 22, 2013, 03:58 PM
eirikso is offline
Find More Posts by eirikso
Joined Dec 2011
Eep. Probably not bad motor, probably not related to joining BECs. I do this all the time, and it works fine for me. I have a quad with these ESCs, BECs joined, and it works just fine. Are you sure you flashed "bs.hex" to them and not "bs_nfet.hex"?
I'm pretty sure I flashed the right FW. Two of he ESCs that died now have been doing their job nicely in another hex (I had to take them from that hex over to this new ESC-eating Y6 when replacing some of the ESCs it had already eaten).
I am waiting for a new batch of motors (TGY 2211 2300kv this time) and a new batch of ESCs. Will flash them all wih the same bs.hex, rebuild the Y6 and report back. When testing the 1510-motors on an old TGY Plush I can see that they struggle during start and some times just vibrate instead of starting. But they're not killing the Plush.
But, I've done a lot of acro flying with small quads running those 1510 on 3S with both 6A and 10A SimonK-flashed ESCs. So I still don't understand why they would suddenly die.
Could -10 degrees celcius be the reason?
eirikso is offline Find More Posts by eirikso
Old Jan 22, 2013, 04:17 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Nop
Tested on regulated power supply (8.4V 3A max)
On 10A tp.hex, 4nops, 8, 10, 20 nops : motor starts, amps get up rapidly, voltage drops from 8.4 to 5V, fets get really hot
On turnigy 10A tgy.hex, 0nops, 4, 8, 10, 20 nops : motor strats, stops brutally, restarts, ..., at restart amps get up, voltage stays +-8v, fets get quite warm
both don't have external osc.
Its a lost case those n/p fets?
Gould you guide me to do other tests?
manu
PS: and the gimbal esc drive? ....
These guys get it quite well done...
http://www.youtube.com/watch?feature...v=ch2iRCWZfKc#!
manu
Old Jan 22, 2013, 04:48 PM
maddog7 is offline
Find More Posts by maddog7
maddog7's Avatar
Joined Jan 2004
I honestly think I've checked everything 5 times! AAARRRRGH
Hi all,
I'm sorry to be another to bring annoying questions to the table but could you guys have a look at something for me please?
I'm getting the " target doesn't answer. 1 " error with the KK flash tool.
I was using an improvised press fit tool initially but after many failed attempts I decided it would be better if I soldered the connections direct to the board.
The ESC is a recently bought HK F30A with the light blue shrink and orange and blue label.
I'm using the HK 6pin usbasp which has worked fine on my KK controller boards up to now.
Nearly all the stuff I see on here and the internet in general refers to 10 pin USBASPs and since mine is a 6 I looked up the pinout.
I think I pinned everything out correctly and I've resoldered the connections twice to make sure, each time using a continuity tester to check that none of the solder has joined an adjacent pin.
Am I going mad? Have I missed something?
Is my asp likely to have some weird pinout? I did put just the asp into a usb port and find the +5v in the place the diagram indicated.
You can see in the attached photos from the colours on the wires which way I have the connection from esc to asp.
Also you don't have to power the ESC during the process do you?
Any help to restore my sanity would be gratefully received!
maddog7 is offline Find More Posts by maddog7
Old Jan 22, 2013, 05:05 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Remove the +5Vdc and power up the board via the power wires
Old Jan 22, 2013, 05:11 PM
maddog7 is offline
maddog7's Avatar
Joined Jan 2004
Alll,
Would that be an alternative way to power the Atmega? What I'm asking is, should it have worked the way I had it? and is your suggestion a diagnostic alternative?
I've tried removing all the pins from the esc now and it does not work at all.
I don't know maybe if I allowed the initial press fit connector to slip during my first attempts and have bricked the esc?
Cheers D
Old Jan 22, 2013, 05:27 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
Your programmer may or may not power the chip itself to flash it, my ASP Mk II doesn't, and so when I flash ESC's I power it up using a 9v battery first, then flash it. ASP Mk II's also have a 6 pin header (I made a little adapter board using some vero board and headers)
WendoNZ is offline Find More Posts by WendoNZ
Old Jan 22, 2013, 06:13 PM
maddog7 is offline
maddog7's Avatar
Joined Jan 2004
Thanks for the reply Wendo,
It it likely that if it flashes my KK board without power, it should flash the ESC without power or does it not necessarily work that way?
Cheers
D
Old Jan 22, 2013, 07:22 PM
WendoNZ is offline
Joined Dec 2012
If you can flash the KK without power I would expect it to do an ESC without power too. That means your programmer can and does supply 5v internally, which should be enough
Old Jan 22, 2013, 07:29 PM
rshep is offline
Find More Posts by rshep
crashology student
Ontario, Canada
Joined May 2008
maddog7, I went through the same frustration ... my solution:
http://www.rcgroups.com/forums/showp...&postcount=617
Be sure to remove the jumper on the USBasp ... and replace it after you are done.
rshep is offline Find More Posts by rshep
Old Jan 22, 2013, 07:53 PM
Freighternut is offline
Find More Posts by Freighternut
Joined Dec 2012
Hi,
I have flashed my HK Blue series with bs_N. Everything appears to be working fine!
I there a reason for the very low beep volume? I find it very difficult to hear the beeps even in a very quiet workshop.
I am running Turnigy NTM2826 motors.
Thanks.
Freighternut is offline Find More Posts by Freighternut
Old Jan 22, 2013, 10:58 PM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Hmm. So, I added this check and automatic calibration disabling on purpose, since otherwise you can accidentally calibrate them if testing with a weak power source. Probably what is happening is not that you are connecting the battery poorly, but that the capacitor is holding a charge long enough for the AVR to stay alive enough to remember that there was a brown out. This always happens as the voltage drops low enough for the oscillator to stop, but then current draw may be so low that you may need to wait a long time for the capacitor to discharge, or poke the capacitors around the ATmega8 with some tweezers/wire to discharge them completely.
Unfortunately, there is no way in software I can make this work any differently other than removing the check.
Just checking to make sure I have this straight. If I were flashing F20's (or 30's, or any ESC??) and wanted to make sure they worked before I flashed (I had a DOA F20) I need to be careful to make sure the caps are fully discharged after the initial test before I flash them then? Would disconnecting the battery and then shorting the input wires together accomplish this? Or is it a case of test them all, go away for a while (hour, day??), and then have a flashathon?
Thanks in advance.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Jan 23, 2013, 12:02 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Do they work indoors when you first flash it? I hope you are testing on a current-limited supply of some sort before you hook up the LiPo. A ~6V-12V wall wart or small "laptop-like" supply is probably better than nothing. They will all fall down and prevent damage if something isn't working right. If you must use a LiPo, connect it in series through a small 12V light bulb.
If the Plush can't start it either, maybe the motor is crap. They look pretty dead easy to get right, though. I don't know what could be wrong.
For the next release, I have added LiPo cell counts and such, and I want to make it detect stuck on high FETs (or wrong board flash), but I'm not sure how to safely report the condition other than just not trying to do anything. It is difficult to detect one FET being stuck on from another without trying to actually beep, but detecting wrong high side inversion or a stuck-on high side is easy.
Nop
Ohh. I don't remember you saying you were going to try it on cruddy P/N boards. For those, it pretty much is a lost cause. You will probably need waaay more nops, to the point where it will make the interrupt so slow and max throttle bump so big that it will just be silly.
Hehe, the AQ is not even moving even without the gimbal. But yeah! The brushless gimbals certainly look to be working well. Only so much time!
As others have said, make sure you power the ESC separately. Yes, you can get away with it sometimes, but the ESCs have bigger capacitors and sometimes it doesn't work. Worse, sometimes it can brown out while it's flashing, and I think it can get into a state where it forgets the flash address and writes over the fuses instead.
Also, check that the cable to your usbasp actually has ground connected! I've seen more than a few now that literally run the black wire to an "NC" pin. This means it doesn't actually connect ground, and the only way it works is by relying that pulling down reset sort of connects the ground.
Hmm, I've never had a problem myself with the F-20A boards. The voltage sense resistors and other things typically drain it almost instantly. If you make a solid connection to it from a power source, it should not give the brown-out beeps. Make sure you are not indirectly leaking power into it through some other source, like a powered servo tester or usbasp. Does anybody else have this problem? I could remove the check again, I suppose...
simonk is offline Find More Posts by simonk
Old Jan 23, 2013, 12:03 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
The USPASP does not always provide enough power to program. So connect Miso,Mosi,Clk,Rst and GND and provide power via power wires.
Alll,
Cheers D
Old Jan 23, 2013, 12:07 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
error for bs12A
@Lazy&simon
i dont know if you remember about the different mcu BS12A i asked before? here's the error I got from it
esc: hkbs 12a
the mcu is Atmega8-16AU 1206 (regular ones came with atmega8A with the A)
tool, the socket tool from HK... works fine with other hkbs12a
Code:
Flash the firmware from repository.
E:\ProjQuad\Esc\kkt\lib\avrdude\windows\avrdude.exe -C E:\ProjQuad\Esc\kkt\lib\avrdude\windows\avrdude.conf -p m8 -P usb -c usbasp -B 8 -e -U lfuse:r:E:\ProjQuad\Esc\kkt\tmp\/lfuse.hex:r -U hfuse:r:E:\ProjQuad\Esc\kkt\tmp\/hfuse.hex:r
avrdude.exe: set SCK frequency to 93750 Hz
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e9307
avrdude.exe: erasing chip
avrdude.exe: reading lfuse memory:
avrdude.exe: writing output file "E:\ProjQuad\Esc\kkt\tmp\/lfuse.hex"
avrdude.exe: reading hfuse memory:
avrdude.exe: writing output file "E:\ProjQuad\Esc\kkt\tmp\/hfuse.hex"
avrdude.exe done.  Thank you.
E:\ProjQuad\Esc\kkt\lib\avrdude\windows\avrdude.exe -C E:\ProjQuad\Esc\kkt\lib\avrdude\windows\avrdude.conf -p m8 -P usb -c usbasp -B 8 -e -U lfuse:w:46:m -U hfuse:w:202:m
avrdude.exe: reading input file "46"
avrdude.exe: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 46:
avrdude.exe: load data lfuse data from input file 46:
avrdude.exe: input file 46 contains 1 bytes
avrdude.exe: reading on-chip lfuse data:
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of lfuse verified
avrdude.exe: reading input file "202"
avrdude.exe: writing hfuse (1 bytes):
Writing |  ***failed;
################################################## | 100% 0.02s
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 202:
avrdude.exe: load data hfuse data from input file 202:
avrdude.exe: input file 202 contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
avrdude.exe: verification error, first mismatch at byte 0x0000
             0xcf != 0xca
avrdude.exe: verification error; content mismatch
Error during reading of high fuse.
Flashing of firmware aborted.
thanks
jy0933 is offline Find More Posts by jy0933
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
