Old Jan 09, 2013, 11:54 AM
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Originally Posted by plusultra View Post
Hi All!
Please help me. What .hex file i must use to flash "Maytech 45A-OPTO with NO BEC"?
Thank you.
I believe it is "bs.hex". Let me know if it works and I will add it to the spreadsheet.
Originally Posted by chessmaster View Post
I have a quick question, what is bootloader exactly? I flashed 6 turnigy plushes that had atmel chips and didnt enable it.
It's a chunk of code at the end of the flash that, if the fuses are set, gets executed first on reset/power up. The one I wrote that is included supports flash and EEPROM writes and reads via the Turnigy USB linker. This allows you to update to a newer version later without having to access the ISP pins.
simonk is offline Find More Posts by simonk
Old Jan 09, 2013, 12:15 PM
chessmaster's Avatar
Colorado
Joined Oct 2008
All you have to do is enable when you flash your esc? Is there anything different you have to do when flashing it? Thanks
chessmaster is offline Find More Posts by chessmaster
Old Jan 09, 2013, 01:04 PM
France, IdF, Neuilly-sur-Seine
Joined Jan 2012
Well in fact, default behavior of kkMulticopter Flash Tool is perfect, I didn't notice that flashing through USB Linker also erase the EEPROM, so after each flash, I'm using default values, perfect for me !
In tgy.asm I change STOP_RC_PULS to 1100us and FULL_RC_PULS to 1900us, but when I send a 1100us signal at start time, my ESC doesn't beep, it's like the signal is to high.
When I change STOP_RC_PULS to 1105us, there's a beep for a 1100us signal when my esc start, and after it can work. Is it normal ?
airmamaf is offline Find More Posts by airmamaf
Old Jan 09, 2013, 01:34 PM
hacker
Joined Dec 2010
Yes, this is an "on the fence" case of what happens when there is a slight oscillator mismatch. There always has to be some margin somewhere, even if it's less than 1%, when working with pulse lengths. What flight board are you using in this case? Most boards will send something much lower, like 1000µs or 900µs to arm the ESCs, and then jump up to 1100µs or so to start the motor.
Old Jan 09, 2013, 02:35 PM
manuLRK
Belgium
Joined Sep 2004
Hi!
What parameter / code do i have to change so that the calibration really starts on "low throttle" during calibration? When i test with a servo tester, there is a much higher start position.
manu
alll is offline Find More Posts by alll
Old Jan 09, 2013, 03:08 PM
Efti's Avatar
Norge, Rogaland, Bryne
Joined Oct 2011
Can the first post be updated with the SiLabs programming?
I have flashed a lot of Atmel chips, but never SiLabs.
Don't want to read the whole thread to find out.
Thanks.
Efti is offline Find More Posts by Efti
Old Jan 09, 2013, 03:29 PM
Efti's Avatar
Joined Oct 2011
OK...
I found this
http://www.rcgroups.com/forums/showthread.php?t=1686498
Old Jan 09, 2013, 03:36 PM
Joined Jan 2013
Some one a hint for my problem? -> http://www.rcgroups.com/forums/showp...postcount=6784
Fuses look like this -> http://s7.directupload.net/file/d/3130/3bnkujsn_png.htm
Also flashed tp_8khz.hex firmware with no success.
MasterG is offline Find More Posts by MasterG
Old Jan 09, 2013, 04:17 PM
Hexapilot
Germany, BY, Munich
Joined Mar 2012
@Simonk,
This is the layout of my Mystery 40A ESC,
I guess you are right the S29B ( LM3485) probably is set to 5V not 3.3V
The internal BEC (red cable) was not connected, so I don't see any reason why this 3 components would burn down.
The datasheet of the 4421 is clearly limited to 18V, so I assumed this could be the possible cause for the problems.
Maybe this layout is the previous version of the ESC which was limited to 4S?
hexacop is offline Find More Posts by hexacop
Old Jan 09, 2013, 09:09 PM
hacker
Joined Dec 2010
Hi Manu! PROGRAM_RC_PULS sets this. It is normally halfway between the default neutral and full throttle, so that a slightly higher throttle does not start calibration at power on. The trade-off is that the maximum throttle cannot be calibrated below that point.
Without poking at it with an oscilloscope, I cannot guess what the problem may be. I suspect something has failed.
Originally Posted by hexacop View Post
@Simonk,
Yes, you definitely have a different layout. Yours does not seem to have the 78L05 that was heating up at 6S in our case. By the way, isn't the 4421 an AO4421 P-channel FET with -60Vds rating?
Old Jan 10, 2013, 02:38 AM
Joined Jan 2012
It's an home made tool, I used to bench some motors. To arm my ESC, I use a 1100µs signal. I was wondering if the difference between 1105µs and 1100µs was a symptom of something wrong, but it seems, that I may need to send lower signal to arm my ESC (beep) and then send a idle signal of 1100µs.
Thanks for your reply
Old Jan 10, 2013, 02:54 AM
manuLRK
Belgium
Joined Sep 2004
Hi,
Can Multiwii handle motor outputs at a rate of 1KHz (1000Hz), is it a parameter that can be set? Hardware PWM?
@Simon
I had to set ultrapwm=1 to be able to use a 200...1200µs signal.
i saw this :
Code:
ldi    temp1, 32 * 17/16    ; Stop/reverse pulse (slightly above exact)
This was my question
I changed it to
Code:
ldi	temp1, 32 * 64/63;
and now it is more "exact" start at low throttle.
I still can't understand this asm logic, but could calibration be done this way?
Set throttle at desired max pos = rxMaxInit (enter calibration if > 1200µs), power up esc, you enter calibration as usual, read rxMin, you leave calibration if rxMin<(rxMaxInit-"10") and rx >= (rxMaxInit +- 2),finally save to eeprom.
This will let you more precisely set rxMin and you have the time to do it.
Also, why are we using "real" timings.
Assumption:any PWM length from 200-2400 is valid (only time you use the osc as a reference)
In code you only use a "steps" resolution (2x800=1600 for example or more )
After calibration you map rxMin/rxMax to 1600 ....
manu
Old Jan 10, 2013, 05:40 AM
simone76's Avatar
Italy, Lombardy, Cremona
Joined Mar 2007
I really don't know what happened here. At first it used to work, and then somehow they started flashing a version with broken calibration (even though I don't see how, it works when I flash it). I sent them the latest version, so newer ones should be OK.
Thanks for all the info, i confirm my ESCs, and i guess all the ESCs sold by RC Timer during that period, have not bootloader enabled.
Regards
simone76 is offline Find More Posts by simone76
Hexapilot
Germany, BY, Munich
Joined Mar 2012
Hi Simon
According to some other pictures I found, it is the layout of the Blue Series ESC, which would also require a different firmware.
Btw. what is the difference then between bs40a.hex and bs.hex, could this have been the cause for the smoke in the end?
Old Jan 11, 2013, 04:59 AM
Joined Jan 2012
ESC customisable parameters
Hi Simon,
I made some tests with parameter COMP_PWM = 1 for an HobbyKing 20A BlueSeries ESC, i didn't notice any change in consumption / noise from low throttle to high throttle. Maybe at high throttle there were little less consumption for a little more thrust, not quite sure, it can be the measure error margin.
It'd like to know if this parameter (COMP_PWM = 1) could have any advantage, and for which conditions ?
Another question, for MOTOR_ADVANCE parameter, by default it's set to 18, is there any advantage to change this value or not ?
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
