Old Jan 08, 2013, 10:29 AM
mnegrete is offline
Find More Posts by mnegrete
mnegrete's Avatar
Sacramento
Originally Posted by LazyZero View Post
Please try again with a current limiting power supply attached to the battery wires of the ESC. You then have to remove the 5V connection from the USBasp.
There should be no difference in calling avrdude on 8 and 8A ATmega.
Best Christian
LazyZero - Thx, that seemed to do the trick. I powered the ESC with 5v (current limited via tail light battery) and the flash was successful. I forgot to remove the 5V connection from the USBasp, but it still worked.
Why did 5V need to come from something other than the USBasp?
mnegrete is offline Find More Posts by mnegrete
Old Jan 08, 2013, 11:20 AM
quad007 is offline
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
Originally Posted by airmamaf View Post
@SimonK and Lazy Zero
In github :
In tgy.asm :
When using KKMulticopterFlashTool, the last nibble of the hfuse is set to 'a' when bootloader is enable. Is there a way to clear EEPROM, to use default values of the firmware, when flashing with PWM (USB Linker) ?
Is it possible to upload a code to clear the EEPROM and then upload ESC firmware ?
i can do that, it's not just setting it to "a". the first bit of the last nibble has to be 1 and then it will not save the settings(0 is enable eesave)
i can make that some time this weekend. it will set the fuse, flash the rom, then set the fuse back to 0. this should clear the EEPROM
quad007 is offline Find More Posts by quad007
Old Jan 08, 2013, 02:33 PM
simone76 is offline
Find More Posts by simone76
simone76's Avatar
Italy, Lombardy, Cremona
Joined Mar 2007
RC-Timer SK-40A SimonK Firmware issue
SK-40A SimonK fw bought on november, out of six of them, i can't get to calibrate any. Even extending throttle to 110%, directly connected to RX. So weird. There is some way to fix that, without uninstalling them for flashing again?
simone76 is offline Find More Posts by simone76
Old Jan 08, 2013, 04:32 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Had the same ones, with firmware the throttle calibration is not possible. I think they used an older version of the firmware. You will have to flash them yourself.
manu
alll is offline Find More Posts by alll
Old Jan 08, 2013, 05:23 PM
simone76 is offline
simone76's Avatar
Joined Mar 2007
ty, well at least there is a solution. Can i use the USB linker with that old firmware without calibration feature? or the bootloader isn't enabled... it would be annoying to take the ESCs off the frame now.
Old Jan 08, 2013, 06:15 PM
quad007 is offline
quad007's Avatar
Joined Oct 2012
unfortunately you will probably have to remove them from the frame. that was before we needed bootrst/bootsz i think
Old Jan 08, 2013, 10:18 PM
quad007 is offline
quad007's Avatar
Joined Oct 2012
when setting the fuse for this firmware do we flash the firmware first or do we set the fuses first? or should it all be done in one avrdude command
Old Jan 09, 2013, 12:06 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
First flash firmware with bootloader enabled (compiled), then set fuses.
Old Jan 09, 2013, 12:07 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Bootloader is also misssing in these batches...
Old Jan 09, 2013, 02:24 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Originally Posted by hexacop View Post
Hi Simon,
seems my Mystery ESC (40A 2-6s) looks the same from the label but they have a different layout, please see the video at 3:00, even the 3.3V regulator and the mosfet driver next to it is the same. They worked for a while but in the meantime 2 copters crashed three times with the same symptoms. And the worst experience was the burning one in my garage right after swapping the battery.
In any case I will throw them away, I have ordered HobbyWing 40Amp OPTO and will give those a try...
Thank you for all the help here ;-)
Hello! Hobbywing ones will all be Silabs, so you will have to use BLHeli if you want to flash it. Or you could just keep it stock.
Btw, I still don't understand why there was a 3.3V regulator on your Mystery boards. Nothing should be 3.3V.
The 5V from USB may not supply enough current to charge the capacitor on the ESC without first tripping overcurrent on the port.
Also, I noticed some of the USBASP connections I have are stupidly wired. Some are running ground to a pin marked "NC"! I've had to pop out this wire on the 10-to-6 to fix it (and just removed VCC while I'm at it). This means that if it worked, it was actually relying on VCC to set an offset from ground, and the I/O pins to pull away from it. The chip would be unpowered until the moment the programming tries to start. I'm not sure if this is some intentional hack to help with the 3.3V signalling required for USB, but it's extremely ghetto.
Those of you having flashing problems where the target doesn't answer, maybe check that ground is actually grounded...
Originally Posted by V_Okto View Post
the escs stop working after 30 seconds it just restarts... what to do?
It works fine, then just restarts for no reason? Is it heating up or anything? Are there any different beeps when it restarts? They seem to work fine for me...
simonk is offline Find More Posts by simonk
Old Jan 09, 2013, 02:35 AM
simonk is offline
hacker
Joined Dec 2010
I really don't know what happened here. At first it used to work, and then somehow they started flashing a version with broken calibration (even though I don't see how, it works when I flash it). I sent them the latest version, so newer ones should be OK. Meanwhile, you can check to see if you can access the boot loader by using a wire to jumper between the servo pins (assuming a BEC is present).
Connect +5V (red wire) to the PWM input pin (white wire) and power up the ESC. If you hear beeps, the boot loader fuses are not set. If there are no beeps, then you are in the boot loader, and the linker should work. You should hear beeps once you remove the jumper _or_ once you drain the PWM input pin to ground (black wire).
After the start-up beeps, connect again PWM to +5V, wait 2 seconds, then connect PWM to ground. If you hear the ESC reset (start-up beeps again), version 2012-09-30 or newer is flashed ("boot loader any time"). This works regardless of the fuse settings, but if you flash wii-esc or half-flash/erase the software, you may not be able to access the boot loader again without restoring it via ISP. If this or the first test don't produce any difference, then an older version is flashed and the boot loader fuses are not set. You must use ISP to update/fix it. :/
Btw, "chip erase" via the boot loader clears the EEPROM (for those who asked before).
Old Jan 09, 2013, 02:36 AM
airmamaf is offline
Find More Posts by airmamaf
France, IdF, Neuilly-sur-Seine
Joined Jan 2012
Default firmware values with USB Linker
Thanks for your reply quad007, are you sure fuse can be changed through PMW signal (USB linker) ?
Oups, it seems, I post this question, a minute after Simonk's reply
airmamaf is offline Find More Posts by airmamaf
Old Jan 09, 2013, 02:37 AM
quad007 is offline
quad007's Avatar
Joined Oct 2012
updated the tool at:
http://realfpv.com/escfirmware/bin.zip
It now sets the correct lfuse based on your ESC selection. if you do not have ext OSC it sets CKOPT to 1, lfuse to 0010 0100
if it has ext OSC it sets lfuse to 0011 1111 and CKOPT to 0
then it makes sure hfuse ends in 010
steps to flash:
select programmer(usbasp or avrisp is most common)
select ESC
Click "build std. firmwares" once if you want to freshly build the firmwares
click "Flash!"
Then click UNLOCK BOOTLOADER
you are done
Old Jan 09, 2013, 07:27 AM
plusultra is offline
Find More Posts by plusultra
Joined Mar 2011
Hi All!
Please help me. What .hex file i must use to flash "Maytech 45A-OPTO with NO BEC"?
Thank you.
plusultra is offline Find More Posts by plusultra
Old Jan 09, 2013, 07:49 AM
chessmaster is offline
Find More Posts by chessmaster
chessmaster's Avatar
Colorado
Joined Oct 2008
I have a quick question, what is bootloader exactly? I flashed 6 turnigy plushes that had atmel chips and didnt enable it.
Should I go back and reflash them with it enabled? Is there anything differant you have to do for the flashing process?
chessmaster is offline Find More Posts by chessmaster
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
