Old Jan 06, 2013, 08:15 AM
quad007 is online now
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
maybe not :/
the rctimer ones are ok, i think they will go to slovenia
http://rctimer.com/index.php?gOo=goo...80&productname
i use 18A rctimer, they have been on my quad since last january
quad007 is online now Find More Posts by quad007
Old Jan 06, 2013, 08:27 AM
Drekavac is offline
Find More Posts by Drekavac
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
Thanks Quad007.
I believe I will order F20 or F30 from HK, and then flash them.
As I read, they are good, and I like to do things myself.
Drekavac is offline Find More Posts by Drekavac
Old Jan 06, 2013, 09:33 AM
TheFernMan is online now
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Originally Posted by Drekavac View Post
Thanks Quad007.
Order quick before they go out of stock which they do for months at a time. And order a spare or two. You'll hate yourself if you don't and then need them.
TheFernMan is online now Find More Posts by TheFernMan
Old Jan 06, 2013, 09:51 AM
MasterG is offline
Find More Posts by MasterG
Joined Jan 2013
Hi together,
after flying some multirotors for some years i thought it would be time to try out the world famous SimonK ESC Firmware.
I got some Hobbyking SS Series 25-30A ESC (card programmable) (HK-SS30A-HW) here for some test. After looking up the correct firmware (tgy.hex) and flashing it to my ESC everything was fine and my Motors (Keda 20-26M) where spinning nice.
But then I made my first test flights. After two minutes one motor stopped for a split of a second and the Quadrokopter got down. I noticed that my ESC are all quite hot after two minutes of flying. On my other Quads this configuration works perfect and keeps cool. The Problem is always the same, one ESC gets to hot and stops for a split of a second. After some test I noticed that this problem appears at most when the Quad hovers at 1/4 of the power.
Now I am asking me what is the problem, I think, if i took the wrong firmware the ESC would not work. Maybe there is a Problem with the Fusebits? I did not touch them, but maybe there is a problem with the internal clock speed?
A othe thought from me was the ESC is killing itself becouse of that note?
Note: HK-SS18A, HK-SS20A, and maybe other sizes kill themselves (P-FET gate noise) when ran at higher PWM speeds - avoid
MasterG is offline Find More Posts by MasterG
Old Jan 06, 2013, 11:28 AM
dopplet is online now
Find More Posts by dopplet
Joined Apr 2012
I bought RedBricks 25A with locked atmegas.
So I change them with new ones.
I upgade them with LazyZero SW, all went ok, no errors.
And now this is what I got, strange startup sond.
Can anyone help me, what does this mean?
http://youtu.be/r3Z0SBG6vbg
Sounds like the microcontrollers clock is not what the firmware needs, just a guess but I think your microcontroller's clock is 8MHz and the firmware flashed needs 16Mhz, I'm not sure but I think there are 8MHz firmwares.
Also possible, the fuses got set wrong and it's using internal 8MHz clock instead of external 16MHz xtal.
Andrew
dopplet is online now Find More Posts by dopplet
Old Jan 06, 2013, 11:53 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Yes, use 8KHz firmware.
Btw, quad007 == chatch###? ;-)
ABLomas is offline Find More Posts by ABLomas
Old Jan 06, 2013, 12:53 PM
MasterG is offline
Joined Jan 2013
Are you sure with 8Khz? What firmware is this? tp_8khz.hex?
Old Jan 06, 2013, 01:14 PM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
No, i'm not sure, please kill some more ESC's to be sure, thanks!
https://docs.google.com/spreadsheet/...BQkZZRlE#gid=0
Link to ESC FW sheet is in 1st post in this thread...
So, you can use the same FW, just 8KHz commutation freq.
Old Jan 06, 2013, 03:01 PM
Drekavac is offline
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
Ofcourse I will try, but I don't know how...
Old Jan 06, 2013, 04:11 PM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
Originally Posted by quad007 View Post
on my kk2, roll is all the way up on 90 lol.
Let me know when you've hit 320...
fallingdown is offline Find More Posts by fallingdown
Old Jan 06, 2013, 04:56 PM
MasterG is offline
Joined Jan 2013
Sorry, I donīt know what you mean. Can you give me a other hint? Of course I know where to find the Firmware.
Old Jan 06, 2013, 05:12 PM
hexacop is offline
Find More Posts by hexacop
Hexapilot
Germany, BY, Munich
Joined Mar 2012
Mystery (HK blue series) 2-6s 40A burn down with 5S
Since weeks I (and a friend of mine with the same setup) had problems with several motor glitches during flight with the hexacopter. Two times it ended with a crash but in most cases I could land safety.
I have flashed Mystery 40A 2-6S ESC.from HobbyKing and was pretty satisfied with them but then we had intermittent problems with motor glitches.
Now I know the problems really started after we have used 5S batteries instead of 4s batteries. In the meantime I tried everything possible to eliminate or find the cause, I had swapped motors, rewired everything and soldered every cable directly but the problem did not go away. I found out the problem occurred most of the time right after start and the last few days it was always the same motor #5 which shut down. During my last test in my garage I cold reproduce the problem and after I have swapped the battery to continue testing one of the Mystery ESC burned down.
I have documented some of the issues in the video:
Copter crash with Mystery 40A ESC (3 min 34 sec)
The burning and failing component was a mosfet TC4421
This are the specs:
The TC4421/TC4422 are high-current buffer/drivers capable of driving large MOSFETs and IGBTs.
These devices are essentially immune to any form of upset, except direct overvoltage or over-dissipation.
Wide Input Supply Voltage Operating Range: 4.5V to 18V
http://datasheet.octopart.com/TC4421...sheet-2975.pdf
In my opinion this ESC is NOT SUITABLE FOR 5S or even 6S!!!
hexacop is offline Find More Posts by hexacop
Old Jan 06, 2013, 06:38 PM
quad007's Avatar
Joined Oct 2012
if you plan on flying more than 4S please check your ESC chips datasheet for voltage limits etc.
you had a lot of expensive stuff on there powered by some $20 mystery ESC
Old Jan 06, 2013, 08:27 PM
rshep is offline
Find More Posts by rshep
crashology student
Ontario, Canada
Joined May 2008
My first 20+ attempts to flash bs-nfet to F30A using the bent pin 6-pin header just gave the same high fuse error. So I carefully made up the other 6 pin flasher, which fit the pins better, and was easier position. Many more attempts with it still gave the same error. i must be doing something wrong. Suggestions please ...
PS: I verified the pins were leading to the proper HK USBasp 6-pin hole with a multimeter.
rshep is offline Find More Posts by rshep
Old Jan 06, 2013, 08:35 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I know others were very successful with the technique you are trying to us but I ended up just soldering each wire to the pads. Flashing was over in a flash providing all of the connects were made. before removing the wires, I made sure the test the ESC were good.
rimshotcopter is online now Find More Posts by rimshotcopter
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 03:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 10:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 10:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 03:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 03:31 PM
