Old Dec 01, 2012, 05:24 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
usb linker - Arduino USB linker
Hi,
I try to make the Arduino USB linker to work without success (my Turnigy USB Linker stopped working, pc doesn't detect it anymore?...)
What am i missing here?
https://github.com/c---/ArduinoUSBLinker
Are there other alternatives?
manu
alll is offline Find More Posts by alll
Old Dec 01, 2012, 07:17 AM
magic21nrw is offline
Find More Posts by magic21nrw
Joined Mar 2012
@SimonK
Hello,
I have a little question about throttle configuration after flashing 4 of my Hobbyking Blue Series A30 with the appropriate BS-Nfet.hex.
AVR programmer reported no errors on read and write of all my 4 ESCs. After successfully programming them, they all beeped. So far everything looks normal.
I put the first two esc's on my remote receiver and calibrated them perfectly. Just two of them won't enter into calibrate mode. I can reflash them without problems but giving full throttle they don't react. No beep.
Question: Could it be possible that they are somehow not accepting the new firmware but two of them did?
Question 2: Stupid as I was, I haven't saved the original firmware of the Hobbyking Blueseries A30. Does anyone have the original one on file for me that I could revert them back to the old state and check if throttle calibration works with that firmware?
So I could at least check if I somehow fried my ESC's...
Any thoughts what could help to get the two escs throttle calibrated?
magic21nrw is offline Find More Posts by magic21nrw
Old Dec 01, 2012, 07:26 AM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
I'm happy to help. What is the problem exactly? What hardware and software are you using?
LittleMo is offline Find More Posts by LittleMo
Old Dec 01, 2012, 07:59 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Software:
http://avr8-burn-o-mat.aaabbb.de/avr...de_gui_en.html
Hardware: Arduino Duemilanove
I was used to do it with the turnigy usb linker without a problem, but this one stopped from working , hk out of stock, so i tried your Arduino linker.
Uploaded the .ino, set the correct baud in avr8_burn_o_mat STK500v2, make the connection, rx signal to arduino D2 + rx ground to arduino gnd, power the esc via power cables (regulated power supply).
When i try, i have averdude timeouts.
manu
Hi,
manu
Old Dec 01, 2012, 08:16 AM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Software:
I assume you are using version 0.8 of the ArduinoUSBLinker?
Also do you know what version of the simonk bootloader you are using? I think only the most recent versions can enter the bootloader at any time, the old one may need to be powered on only after the Arduino is running.
Is your Duemilanove ATmega168 powered or 328? It should not matter but although I recently made changes for the smaller atmega, I have not tested them.
Can you post the log output from AVR8 Burn-O-Mat? I'm interesting in seeing the avrdude command it tries to run and any other output.
One thing you can do to make sure the ArduinoUSBLinker is working is open a serial console and try sending a command to it. The Arduino IDE is good for this, just open the Serial Monitor at 19200 baud then type the command
Code:
$M<
and see if it responds with the current settings (post the output here if you can). Maybe try 115200, 57600, or 9600 baud if 19200 doesn't work.
Old Dec 01, 2012, 08:21 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Hi,
I have this "tgy.inc" like 10A esc.
All P and N Fets match the tgy.inc layout. What is different is the common comp. and the muxABC.
Now, i didn't found a inc layout where PD7/AIN1 is used for the mux_c
I see
Code:
; PORT C definitions *
.MACRO set_comp_phase_a
    ldi    @0, mux_a    ; set comparator multiplexer to phase A
    out    ADMUX, @0
    cbi    ADCSRA, ADEN    ; disable ADC
.ENDMACRO
.MACRO set_comp_phase_b
    ldi    @0, mux_b    ; set comparator multiplexer to phase B
    out    ADMUX, @0
.ENDMACRO
.MACRO set_comp_phase_c
    sbi    ADCSRA, ADEN    ; enable ADC and comparator to phase C (AIN1)
.ENDMACRO
I think i should need something like this added, no?:
Code:
    ldi    @0, mux_c    ; set comparator multiplexer to phase C
    out    ADMUX, @0
.ENDMACRO
Pin layout:
PC2:mux_a
PC3:mux_b
PD7:mux_c
PD6:common comp
PB-2,0,1:NFET-A,B,C
PB-5,4,3:PFET-A,B,C
PD2:Rx
How can i find the order mapping for mux?
Motor beeps, but can't start (stutter only )
Old Dec 01, 2012, 08:55 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Yes, ver 0.8, SimonK tgy_2012-06-01_07c3957, arduino-328
$M< response with:
P18:B32:R19200:PINS:B0:C816:
When i start reading, i hear motor beep:
C:\WinAVR-20100110\bin\avrdude.exe -u -C C:\WinAVR-20100110\bin\avrdude.conf -p m8 -P com6 -c stk500v2 -D -b 19200 -F -U hfuse:r:C:\DOCUME~1\manu\LOCALS~1\Temp\hfuse430792 2232615526845.hex:r -U lfuse:r:C:\DOCUME~1\manu\LOCALS~1\Temp\lfuse373107 0551223928024.hex:r
avrdude.exe: stk500_2_ReceiveMessage(): timeout
avrdude.exe: ser_recv(): read error: L'opération d'entrée/sortie a été abandonnée en raison de l'arrêt d'une thread ou à la demande d'une application.
Code:
$M<
Old Dec 01, 2012, 09:11 AM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Usually when I get a beep from the motor like that it's because the ESC was not in the bootloader or it's getting a communication error. Often I can just try again and it works, sometimes I have to reset and try again. It should not beep though, that means there is definitely some sort of communication error between the Arduino and the ESC. Are you powering on the ESC after the Arduino is powered up?
However, it could be the ESC. What type of ESC is this and does it use an external oscillator?
You can try slowing the ArduinoUSBLinker down to the normal Turnigy USB Linker speed. Open Serial Monitor and type:
Code:
$M<B136
Then save the settings with:
Code:
$M<W
. Make sure the Arduino confirms each step in its output.
Old Dec 01, 2012, 12:45 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Got it working with this adapted tgy.inc file
How to find out the mux phase mapping?
manu
Pin layout:
PC2:mux_a
PC3:mux_b
PD7:mux_c
PD6:common comp
PB-2,0,1:NFET-A,B,C
PB-5,4,3:PFET-A,B,C
PD2:Rx
thanks,
manu
Hi,
10A esc.
Old Dec 01, 2012, 01:10 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Tried all these, but still not lucky.
I use the esc i am talking about in previous post.
Everytime i start communication, the esc resets, but the get the timeouts
manu
Code:
$M<B136
Code:
$M<W
Old Dec 01, 2012, 01:29 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Looks like it may not have an external oscillator. I imagine that affects the timing somewhat and I don't have an ESC without an external oscillator to test with. I will have to think about this and look over the code.
I assume the Turnigy USB Linker did work with this ESC at some point?
Old Dec 01, 2012, 03:33 PM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Yes, no osc, and yes it worked before on the tgy usb linker.
manu
Old Dec 01, 2012, 04:06 PM
Phasor is offline
Find More Posts by Phasor
KG7MNT
Phasor's Avatar
United States, WY, Cheyenne
Joined Jun 2008
Originally Posted by magic21nrw View Post
@SimonK
Hello,
I would be interested in an answer to his question also as I had the very same thing happen to me. Two our eight HK F-20 esc's exibited the same behavior...flashed perfectly but would not calibrate.
Phasor is offline Find More Posts by Phasor
Old Dec 01, 2012, 08:19 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Originally Posted by kaakku View Post
See attached Hobbyking Multistar 45A pictures.
Dissapointed that it is totally different from 30A version, where the pads are available.
The line of connectors on top connects 2 board to each other - "CPU board" to "FET" board. Can those connections be used for flashing?
The easiest way to find pads is to use a continuity tester between the MOSI, MISO, SCK, and RST pins (see first post) and poke around until you find them going somewhere. It doesn't look like there are any on that one, though. It is probably easier to use the socket tool or 4 nano-clips and a ground connection.
Listen to the start-up beeps. The stock firmware takes a long time to beep and sounds very different. The only thing I can think of with calibration not working is that the ESC has powered up with the brown-out flag set (eg: maybe a bit of a jump during connection and the voltage fell down but not all the way to 0V, then back on again). You will hear two descending beeps in this case, and calibration mode will be disabled. You need to be sure that the ESC makes three ascending beeps (or more) for calibration to work.
You didn't fry them. The stock firmware is almost always locked, but you can download firmware for the F-20A and F-30A from this post.
Hi, Manu! What do you mean mux phase mapping? As long as you call the "a" FETs the same as you call the "a" mux and similar for "b" and "c", it should work. Is it working for you now or still stuttering?
simonk is offline Find More Posts by simonk
Old Dec 01, 2012, 09:56 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
@simon
can you take a look at this?
http://www.rcgroups.com/forums/showp...postcount=6512
also.. i didn't figure out how to disable stick calibration. any advise ?
jy0933 is offline Find More Posts by jy0933
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
