Old Nov 22, 2012, 03:19 AM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
it is look simple, but it is designed up to 4 layers
fantasy1988 is offline Find More Posts by fantasy1988
Old Nov 22, 2012, 05:50 AM
JR63 is offline
Find More Posts by JR63
Joined Nov 2012
yes, but it was not so hard to follow the pins:
ApFET PD4
AnFET PD5
BpFET PC5
BnFET PC4
CpFET PC3
CnFET PB0
mux_a ADC6
mux_b ADC7
mux_c ADC0
and the bs.hex works perfekt.
I like the short form factor and that it has the 'large' Atmel so the HK flash adapter matches after short modification.
Bye
JR63
JR63 is offline Find More Posts by JR63
Old Nov 22, 2012, 06:39 AM
sandrodadon is offline
Find More Posts by sandrodadon
sandrodadon's Avatar
Joined Mar 2012
Hello everybody !
I bought F-20A ESCs from Hobbyking for my new Quad - I wanna flash SimonK Firmware.
1: Is it better to remove the 3 last capacitators? SimonK told me it was an option and i have read about better timing
2: Is there anybody with experience using F-20A without the Heatsink? What do you do? Thermal Paste on the FETs and then shrink? Or just remove the Heatsink and shrink again?
Bye
S
sandrodadon is offline Find More Posts by sandrodadon
Old Nov 22, 2012, 06:42 AM
leovz is offline
Find More Posts by leovz
The Netherlands, GE, Vorden
Joined Aug 2012
TYPI-25 turnigy esc falshed annybody?
Hello,
Maybe it is asked earlyer bud I can't find it.
Annybody flashed the TY PI 25 turnigy esc and flying it?
I am building a quad:
NTM 28-36 750KV
10x4.7 slowfly prop
TY PI 25 ESC
550mm cross
thank you,
Leo.
leovz is offline Find More Posts by leovz
Old Nov 22, 2012, 08:09 AM
rkenosha is offline
Find More Posts by rkenosha
Joined Jan 2012
External powering of escs for flashing
Hi everyone. I am going to externally power the esc when flashing with 4 aa batteries. If so, do I need to connect the ground and vcc pins onthe pads. Thanks rkenosha
rkenosha is offline Find More Posts by rkenosha
Old Nov 22, 2012, 09:33 AM
flow23 is offline
Find More Posts by flow23
Deutschland
Joined Jul 2011
Hi there,
did anyone tried to flash this esc?
Black Mantis 8A
http://www.giantshark.co.uk/black-ma...-p-402902.html
I did it with BS N-Fet and it didn't work out well, after connection a 2cell lipo it gets very hot but that's all.
flow23 is offline Find More Posts by flow23
Old Nov 22, 2012, 10:27 AM
Tw34k is offline
Find More Posts by Tw34k
I = V/R
Tw34k's Avatar
United States, FL, Jacksonville
Joined Aug 2012
When externally powered you may be able to omit VCC but GND will always be required.
Tw34k is offline Find More Posts by Tw34k
Old Nov 23, 2012, 01:48 AM
future88 is offline
Find More Posts by future88
Joined Oct 2012
HI SIMONK
you can write new programs for brushless esc, I2C communication
 I think it is best for multirotor
future88 is offline Find More Posts by future88
Old Nov 23, 2012, 01:58 AM
foonji is offline
Find More Posts by foonji
Australia, NT, Darwin
Joined Sep 2012
Can anyone help identify the direction of the row of pads for flashing the Turnigy Multistar 30A esc's? I haven't been able to find anything identifying them.
foonji is offline Find More Posts by foonji
Old Nov 23, 2012, 02:10 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Nice and tiny, though.
You will need to with wii-esc, but for my code, it currently only makes a difference in the timing. If you remove them, the timing will be slightly more advanced ("higher"). Starting may also be easier on some motors. It should work either way.
You could probably just reshrink them. I wouldn't run them bare because it's really easy to touch the oscillator and stop it oscillating, or similar.
Originally Posted by future88 View Post
HI SIMONK
Hello! It is not the best, but it is already implemented. The best would be something like i2c but without the ESCs being able to jam the bus. On the other hand, uart and pwm have the problem of clock accuracy, whereas i2c does not.
I just checked..From the side closest to the PWM input wire, it is MOSI, MISO, SCK, RESET, +5V, GND.
simonk is offline Find More Posts by simonk
Old Nov 23, 2012, 02:13 AM
foonji is offline
Joined Sep 2012
Thank you Simon!
Old Nov 23, 2012, 04:37 AM
foonji is offline
Joined Sep 2012
I just flashed one of my multistars, sucessfully completed. Hooked it up to the FC and motor, then once powered up it smoked the motor and killed it. :S
Ok, just tried with another unused motor, and did the exact same thing. Turned on ok, but once armed and throttle applied, it burnt out the motor.
Old Nov 23, 2012, 07:20 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Flashed with kda.hex?
And... Why ignore warning about tests with dummy load?
ABLomas is offline Find More Posts by ABLomas
Old Nov 23, 2012, 08:26 AM
otti20vt is offline
Find More Posts by otti20vt
Joined Sep 2012
ApFET PD4
AnFET PD5
BpFET PC5
BnFET PC4
CpFET PC3
CnFET PB0
mux_a ADC6
mux_b ADC7
mux_c ADC0
Bye
JR63
Hi JR63
I got today 4x mystery 6A esc (MY6A) this looks same like yours.
otti20vt is offline Find More Posts by otti20vt
Old Nov 23, 2012, 10:31 AM
JR63 is offline
Joined Nov 2012
Originally Posted by otti20vt View Post
Hi JR63
Can you post pictures from both sides of the ESC PCB and the label and have you meassured the pin connections?
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
