Old Nov 20, 2012, 03:40 PM
Jonny_sch is offline
Find More Posts by Jonny_sch
Austria, Vienna
Joined Jun 2011
I have some Skywing SW-80A ESCīs.
Has somebody a idea which firmware I can use?
Attached see the photos.
The Fetīs have the No: F KK42 FDD 8896.
The Half-bridge-driver has following No: IR2101 S 0347 IOR.
Jonny_sch is offline Find More Posts by Jonny_sch
Old Nov 20, 2012, 08:44 PM
flyingdogfilms is offline
Find More Posts by flyingdogfilms
Joined Mar 2009
I'm just recently switched my Ecilop Quad to SimonK flashed Rctimer 30amp ESCs and have a question about overheating. Before flashing the esc would get warm but never really hot. They are now getting pretty steamy and I've only flown them in some very cool weather. Is this normal and is it safe? How hot is too hot? Also can the PID settings on my Multiwii baord affect how rapidly it heats up? I've got a decent little bird and I'd rather not see it fall out of the sky.
flyingdogfilms is offline Find More Posts by flyingdogfilms
Old Nov 20, 2012, 10:06 PM
Joined Mar 2009
Oh and I'm running Avroto 2814 motors
Old Nov 21, 2012, 02:12 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
Originally Posted by rc my life View Post
hi simonk
I use six fet n-channel
I do not use adc to indicate low battery
in addition to motor control, it does not add any task, it is only suitable for multirotor
looks well..
but now i'm more expecting some smaller esc that can handle high s battery while being light weight
i run in such a problem that only 40A+ esc can handle 6s battery.. but my current is like 3A for all time... those esc with heatsink weight 60g+... pretty heavy..
it would be very nice to see some light weight 6s 20A esc
jy0933 is offline Find More Posts by jy0933
Old Nov 21, 2012, 03:01 AM
JR63 is offline
Find More Posts by JR63
Joined Nov 2012
Ok, just if somebody else owns these ESCs.
They work perfect with the bs.hex file.
Many thanks Simon for the cool project.
Bye
JR63
Originally Posted by JR63 View Post
Hi,
does anybody know the following ESC and which SimonK FW is needed for this one:
The MOSFETs are AP4503AGM p-n channel MOSFET, so a pn FW is needed, but which one?
Many thanks
JR
JR63 is offline Find More Posts by JR63
Old Nov 21, 2012, 04:49 AM
rc my life is offline
Find More Posts by rc my life
Joined Nov 2012
Originally Posted by jy0933 View Post
looks well..
if you want to use 6s battery power, small weight, just a little change
use driver bridge h ir 2101
12 fet N IRF 7832 (20a ,30v,0.7moh )
it is work 6 cell lipo
rc my life is offline Find More Posts by rc my life
Old Nov 21, 2012, 06:13 AM
Joined Mar 2009
I'm running it on a 4s bat and flight times are around 11 min
Old Nov 21, 2012, 07:46 AM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Hi.
I have these two esc that are exactly alike, one Turnigy and one Aoxan.
In the database the are listed as SIL chip, but these are Atmega8.
What ver. hex do i need to flash on them ?
DrEvil is offline Find More Posts by DrEvil
Old Nov 21, 2012, 02:01 PM
kc10kevin is offline
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
Searched the entire thread and the spreadsheet. Anyone have success flashing these ESCs? Hobby King HK-SS60A: http://www.hobbyking.com/hobbyking/s...dProduct=22520
Thanks in advance.
kc10kevin is offline Find More Posts by kc10kevin
Latest blog entry: KKNG Rename
Old Nov 21, 2012, 03:04 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
So, the bs.hex firmware should do the job.
I can't see your picture without registering to the forum you linked it to (clear your cookies and you will see what I see). Be sure to check that the "p" (high) side turns OFF when the logic output is low, or else you may need bs_nfet.hex instead (which has the high side inverted).
hi simonk
Right. My code currently doesn't check the ADC so it does not add any task either , but I am thinking of adding some stuff for safety checks (like don't try to beep if the motor average voltage is not low -- eg, if somebody mixes up bs/bs_nfet). Also, it could still read the voltage before start and scale the start power accordingly.
Originally Posted by TheFernMan View Post
Can i get a confirmation that these Mysterys 30amps take bs.hex to flash
The database sheet doesn't contain these 30 amps and they look very much like the 30amp of Blueseries that have P/N fets
It's hard to tell from that picture...Those sense resistors are not the typical values for Mystery/BlueSeries. Maybe try identifying the ESC pin configuration or just test it on a current-limited supply so that it does not fry if it is wrong.
Originally Posted by andi33 View Post
Do you mean the gates are not discharged fast enough? Then would help a resistor from gate to ground. Is there a schematic with gate resistors who can be used.?
There is a lot of noise when it happens, so it's hard to see what exactly is happening, but it seems like the gates get pulled down (on) a bit as the low side PWM turns on. It is not a problem unless the high side is still conducting through the FET body diode, which happens more easily at higher frequencies or when the motor is loaded. See quax' original schematic. Note that here they seem to be doing some strange thing with no base 10k resistor (but doing 10k pull-up instead of drive high at the ATmega8 makes things worse) and 330 Ohm instead of 680 Ohm. Maybe the problem is with the FET capacitance as its source drops down from above battery voltage? Some schottkies from each phase to +Vbat would also help and also increase efficiency.
simonk is offline Find More Posts by simonk
Old Nov 21, 2012, 03:10 PM
simonk is offline
hacker
Joined Dec 2010
They should be able to get quite hot before you have any problems, but with the RCTimers you will see some oscillator drift with temperature (it will actually think you are requesting lower throttle), so I'd probably use something with an external oscillator and all-N instead. I haven't done enough destructive testing in real-world cases to know really where the limit is.
Hello! I don't have any of these, so I don't know. Maybe you could follow the guide and see if that helps? If not, let me know why.. You could also try the lazy / dangerous approach and guess, which I admit I do sometimes if I have a hunch, but only with a safe power supply.
Old Nov 21, 2012, 04:39 PM
Joined Mar 2009
Do the blacksheep esc have external occilators and all N?
http://team-blacksheep.com/products/prod:30aesc
Old Nov 21, 2012, 06:01 PM
Joined Nov 2012
hi simonk
Hope you will change the program so that it becomes more complete
most of the type esc has two cut off, the mode is
cut off when the battery is low
Cut off when the temperature increases (using resistor temperature changes)
You can change the type esc the use bs.nfet, bs.fet because it is prevalent
I will wait for the results. thank you
Old Nov 21, 2012, 09:38 PM
Joined Jan 2010
Thanks Simon. I'll give it try when I get back from the holidays.
Old Nov 22, 2012, 02:51 AM
JR63 is offline
Joined Nov 2012
Hi Simon,
thanks for the hint that the jpg is not shown, I put it in the attachment.
Since yesterday it is working perfect with the bs.hex file as I supposed after checking the PCB and finding the following connections:
ApFET PD4
AnFET PD5
BpFET PC5
BnFET PC4
CpFET PC3
CnFET PB0
mux_a ADC6
mux_b ADC7
mux_c ADC0
Bye
JR63
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
