Old Nov 18, 2012, 06:39 PM
acuralegendz is offline
Find More Posts by acuralegendz
What goes up...
acuralegendz's Avatar
United States, NJ, Cherry Hill
Joined Feb 2012
Thanks andi. Do you know which each pin as like miso,ground,5v?
acuralegendz is offline Find More Posts by acuralegendz
Old Nov 18, 2012, 06:43 PM
andi33 is offline
Find More Posts by andi33
Joined Nov 2012
+ = 5V
- = GND
O = MISO
I = MISI
C = CLK
R = Reset
andi33 is offline Find More Posts by andi33
Old Nov 18, 2012, 11:58 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Originally Posted by whakahere View Post
I am having a problem which I am unsure why it is happening. I am having problems calibrating the max throttle on my esc. I have HK a30 esc with the lastest BS N-Fet firmware. When I put it at max throttle, plug the esc into my receiver, then add power the esc doesn't beep but just spools up. Any idea why this is?
Do you have fail-safe enabled on your receiver? If it is powering up from the ESC, it may be outputting an idle fail-safe signal until the radio signal has locked. which would cause the ESC to arm instead of calibrate. Maybe try disabling fail-safe temporarily, or power the rx from another, unrelated ESC or BEC first, so that it can get a signal, then plug in the ESC.
simonk is offline Find More Posts by simonk
Old Nov 19, 2012, 04:27 AM
JR63 is offline
Find More Posts by JR63
Joined Nov 2012
which FW for the folowing ESC
Hi,
does anybody know the following ESC and which SimonK FW is needed for this one:
The MOSFETs are AP4503AGM p-n channel MOSFET, so a pn FW is needed, but which one?
Many thanks
JR
JR63 is offline Find More Posts by JR63
Old Nov 19, 2012, 06:22 AM
xmonster is offline
Find More Posts by xmonster
Joined Jan 2010
Turnigy Multistar
Can someone help me to identify the pads?
This is a 15amp Turnigy Multistar.
Thanks.
xmonster is offline Find More Posts by xmonster
Old Nov 19, 2012, 08:02 AM
turrican_1 is offline
Find More Posts by turrican_1
Joined Nov 2012
thank you andi !!!!!!!!!!!!!
I just updated my redbrick 30A with tp.hex in 5 minutes using the tool hobbyking
http://www.hobbyking.com/hobbyking/s...hing_Tool.html
very useful tool
turrican_1 is offline Find More Posts by turrican_1
Old Nov 19, 2012, 08:19 AM
georok is offline
Find More Posts by georok
Germany, NDS, Gifhorn
Joined Jul 2012
Thanks.
You must soldering the cable to the pins from the chip or you can use the Flashing Tool from HK.
See follow ATMega8 schematic
georok is offline Find More Posts by georok
Old Nov 19, 2012, 01:40 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
[QUOTE=simonk;23209548]Hi Steve! Before the boot loader.. So 2012-03-21 or older? Lots of changes have happened since then. Starting should be a lot better all around, but there are still problems on some motors (sometimes with one in a batch of motors). Once it is running, however, 2012-09-30 should be fine on all motors. I am working to see if I can do static position tracking during starting that should help.
QUOTE]
update to this, my motors still have trouble starting but have not failed in the air yet.... I am wondering if I should be worried
Steve
saabguyspg is offline Find More Posts by saabguyspg
Site Sponsor
Old Nov 19, 2012, 05:27 PM
andi33 is offline
Joined Nov 2012
Now I flashed 4 Red Brick 30A with tp.hex and all are working.
One had no solder pads, needed to solder wires to the atmel.
The high frequency sound which made me headache when flying Indoor is gone now. But I think the ESC is getting hotter then before. Is it maybe better to use the 8khz tp.hex?
Old Nov 20, 2012, 01:39 AM
rc my life is offline
Find More Posts by rc my life
Joined Nov 2012
I designed a large number of brushless esc for multi.it works very good and stable.
I will share the schematic for anyone who wants to do
rc my life is offline Find More Posts by rc my life
Old Nov 20, 2012, 02:23 AM
simonk is offline
hacker
Joined Dec 2010
Those are the MT-4008, right? I should be getting some to test with shortly. Starting can still be a bit of a pain with some motors. It might help to remove the sense filtering capacitors.
If it's getting hotter than before, particularly when the motor is loaded, definitely try the 8kHz version, but it will whine again. I'd recommend using the F-30A instead, or you could try messing with the gate drive resistors so that the P-channel FETs don't leak on when the N-channel PWM turns on.
Hmm, looks like all-N and external oscillator, but input pin still on PD2 (INT0), not PB0 (ICP1), and AIN1 is not used, so can't use ADC while timing from that pin. Trying to maintain compatibility with some software?
Old Nov 20, 2012, 02:28 AM
JR63 is offline
Joined Nov 2012
Originally Posted by JR63 View Post
Hi,
Many thanks
JR
Ok, I checked it by myself:
ApFET PD4
AnFET PD5
BpFET PC5
BnFET PC4
CpFET PC3
CnFET PB0
mux_a ADC6
mux_b ADC7
mux_c ADC0
So, the bs.hex firmware should do the job.
I will test it tomorrow and report the results if anybody else will use these ESCs.
JR
Old Nov 20, 2012, 03:28 AM
Joined Nov 2012
hi simonk
I use six fet n-channel
I do not use adc to indicate low battery
in addition to motor control, it does not add any task, it is only suitable for multirotor
Old Nov 20, 2012, 02:17 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Originally Posted by TheFernMan View Post
These are what im looking at..
Can i get a confirmation that these Mysterys 30amps take bs.hex to flash
The database sheet doesn't contain these 30 amps and they look very much like the 30amp of Blueseries that have P/N fets
TheFernMan is offline Find More Posts by TheFernMan
Old Nov 20, 2012, 02:35 PM
andi33 is offline
Joined Nov 2012
Do you mean the gates are not discharged fast enough? Then would help a resistor from gate to ground. Is there a schematic with gate resistors who can be used.?
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
