Old Nov 16, 2012, 01:48 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Originally Posted by RedSky View Post
At lower power the F30A is just as efficient as the T40A but I still have the unexplained 25% lower maximum power (thrust and amps) from the F30A.
Very simple question - did you calibrated ESC's after flashing (so ESC's will know your testing rig endpoints)?
ABLomas is offline Find More Posts by ABLomas
Old Nov 16, 2012, 02:33 AM
Australia, SA, Renmark West
Joined Sep 2011
Yes, all ESCs were calibrated on the same DX8.
I suppose some ESCs will have a higher resistance than others so with a low resistance motor like the MT4008 it might make a difference.
RedSky is offline Find More Posts by RedSky
Old Nov 16, 2012, 03:44 AM
Joined Apr 2012
Has anyone had any success flashing 50A HK Blue Series ESCs with SimonK firmware and which file seems to be working??
Lance
Vortexxx is offline Find More Posts by Vortexxx
Old Nov 16, 2012, 03:17 PM
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by jy0933 View Post
Update on Dynam Detrum 40A
chip layout is same as T40A
hex file used tp_nfet.hex I flashed it with kktool set bootloader[attached]
usblink update is yet to be confirmed... pin identification will be update later with pin id
Dude, this is a life saver, that is a MONEY saver!!!
Thank you.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 16, 2012, 07:48 PM
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Originally Posted by acuralegendz View Post
Has anyone seen or flashed this version of the HK Redbrick 30a
Hello! Looks the same to me. Assuming they aren't still disabling SPI flashing by setting the RSTDISBL fuse in the factory, it should work if you can flash tp.hex.
You'll know if you're reaching full throttle since it should happen rigth before the top of your stick movement, and going higher/trimming higher should have no effect. There is no possible way that resistance will have any effect, or the ESC would catch on fire. It can only be timing (which should only have a very small effect) or input voltage.
I haven't got any of those yet since they weren't carrying them before, but since the 60A is "bs.hex", I would assume the 50A is, too. You could try and let us know if it works. If not, you should follow this guide to see what it should be.
simonk is offline Find More Posts by simonk
Old Nov 16, 2012, 08:17 PM
Joined Sep 2011
OK, the other possibility is that the motors are not all the same but I doubt that. I did check the throttle by going to 125% and, as you say, it makes no difference and I checked for voltage effects by changing batteries. I guess you'd know if it' could be timing on your firmware but the RCTigermotor T40A ESCs are on "high" timing because thay can stall the motors if they're lower.
Old Nov 16, 2012, 08:48 PM
What goes up...
acuralegendz's Avatar
United States, NJ, Cherry Hill
Joined Feb 2012
any idea which pins go where,sorry im used to the simplicity of the f30s
acuralegendz is offline Find More Posts by acuralegendz
Old Nov 16, 2012, 09:37 PM
Philippines, Central Luzon, Marilao
Joined Jun 2008
Hi it might not be the proper thread but csn anybody direct me to a seller who has hobbyking simonk f30?
rukie is offline Find More Posts by rukie
Old Nov 16, 2012, 09:47 PM
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
I sold a bunch last month but they been out of stock and the last batch I bought I kept for my builds. I will be selling some other mystery 30a soon.
TheFernMan is online now Find More Posts by TheFernMan
Old Nov 17, 2012, 01:41 AM
Joined Oct 2012
hi simonk
help me again, I have sent message to your inbox ,sorry because it does not fit this thread
I want to change esc braking mode, used for car
I have used the program your,it is posted on this thread, dedicated to the car, use all the type esc brushles of the multicopter
 it works fine, but I want to brake mode become more flexible
First application of reverse throttle = Brake. Back to neutral and then reverse throttle again = Reverse.
when you have free time, help me change the program
Thank you again ,wish health
fantasy1988 is offline Find More Posts by fantasy1988
Old Nov 17, 2012, 01:56 AM
Joined Nov 2012
Hi simonk i have the same problem of acuralegendz with new redbrick 30A
try many firmware but my first esc burning during test.
The pcb of this esc is very similar to birdie 30A pcb
turrican_1 is offline Find More Posts by turrican_1
Old Nov 17, 2012, 11:52 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I am having a problem which I am unsure why it is happening. I am having problems calibrating the max throttle on my esc. I have HK a30 esc with the lastest BS N-Fet firmware. When I put it at max throttle, plug the esc into my receiver, then add power the esc doesn't beep but just spools up. Any idea why this is?
whakahere is offline Find More Posts by whakahere
Old Nov 18, 2012, 05:57 PM
Joined Nov 2012
I have the same, tp.hex is working.
You need to calibrate the ESC after flashing or it will not spin.
andi33 is offline Find More Posts by andi33
Old Nov 18, 2012, 06:03 PM
What goes up...
Joined Feb 2012
Hey andi can you sen me a pic for which pins go where?
Old Nov 18, 2012, 06:33 PM
Joined Nov 2012
Here is a picture with cable numbers.
The numbers are from the 10pin cable to the winasp
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
