Old Sep 18, 2012, 04:10 AM
Harpia is offline
Find More Posts by Harpia
Harpia's Avatar
Brasil, PE, Gravatá
Joined Apr 2004
Originally Posted by simonk View Post
I'm not sure, I have't seen it. It might be bs_nfet, or it might be something different, like bs40a or something else.
Thank you.
You did a great job, the Maytech 30 Amp ESC programmed with firmware Simonk works very well.
Edson
Harpia is offline Find More Posts by Harpia
Old Sep 18, 2012, 05:12 PM
whizz101 is offline
Find More Posts by whizz101
Joined Aug 2012
Originally Posted by saabguyspg View Post
I have a picture on my home computer that I found with the connections labeled... do you need it? if so I will post it tonight.
steve
hey steve, if you got a pic that would be ace. thanks
And simon thanks for the info, but i don't have a meter(yet). i flashed my first esc' last week for my zero uav FC. massive improvement. thanks loads!
whizz101 is offline Find More Posts by whizz101
Old Sep 18, 2012, 07:56 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
@simon
just to confirm something
my hexa has all 3 clockwise rotating motors heavily heated up.... and I got a comment on this.. just to confirm if it might be the problem?
I seem to remember reading somewhere with the simon flash that each esc was to be flashed separately and all throttle setting separately one at a time on receiver throttle channel. I just glanced over it so not sure which thread I read that on.
jy0933 is offline Find More Posts by jy0933
Old Sep 19, 2012, 01:02 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
If it flies OK, it's nothing to do with calibration, and probably an issue with motor mounting or one group of propellers having more pitch than the other.
simonk is offline Find More Posts by simonk
Old Sep 19, 2012, 01:07 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
yeah.. I'm actually suspecting the props... anyways... eliminate one possibility..
thx man
Old Sep 19, 2012, 04:45 AM
GliderLover is offline
Find More Posts by GliderLover
Joined Apr 2008
hi all
i have four brand new BlueSeries 40A ESCs from HK, just flashed with the specific bs40a.hex FW. flashing went well, but 2 of them don't arm at all anymore (even if connected directly to an rx) and other two start from middle of the throttle range and don't get full throttle. They don't sound like the other simonkeyed ESCs and it not possible to calibrate them (no sound at beginning). I tried to reflash them with usb linker, errors all the way (writing and reading errors). Any suggestion?
GliderLover is offline Find More Posts by GliderLover
Old Sep 19, 2012, 05:15 AM
Mike Barton is offline
Find More Posts by Mike Barton
United Kingdom
Joined Nov 2008
had this on a quad - check all motors are vertical !
with those nice cf tubes, can be tricky getting them all aligned
Mike Barton is offline Find More Posts by Mike Barton
Old Sep 19, 2012, 05:16 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
actually i got square alu boom and plate mounter... no DOE there...
Old Sep 19, 2012, 05:33 AM
Multor is offline
Find More Posts by Multor
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
Hi there guys, Just got my ordered BS 20a escs.
The first look was not familiar, the esc was kind of different than the older one,
the older i bought about 1 year ago as really dark colored, and the new one i just got about 2 days ago have their copper rails abit exposed. and the oscillator is different and all the fets seems changed.
i ordered 3 for my quad as 2 of my older ones got smoked
btw i flashed them all with the 2012 BS nfet.hex all of the new ones and the old ones.
i havent tried them yet, but do you guys think they can still be used even they look and seem different?
here is the best picture i could get, sorry i dont have a close up lense xD
the JR wire is the New one (orange red brown) and the twisted futaba one is the old one (Black Red White)
Multor is offline Find More Posts by Multor
Old Sep 19, 2012, 09:14 AM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
I am hoping someone can tell me where I can buy the header pins seen in this photo, They come in long strips of pins, and you break off as many as you need. Thanks!
Brian Courtice is offline Find More Posts by Brian Courtice
Old Sep 19, 2012, 09:21 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Any electronics parts shop as them, Mouser, Farnell,...
Or get them from ebay. Search for male pin headers and you'll find
plenty to choose from.
IceWind is offline Find More Posts by IceWind
Old Sep 19, 2012, 10:22 AM
Dale.E is offline
Find More Posts by Dale.E
Canada, BC, Nanaimo
Joined Sep 2012
Hello No hardware mods, just need to verify that it _does_ have all of the same FETs on the FET side. They are known to be a mix of P/N or all-N even if you buy them at the same, so check each one. It will be bs_nfet.hex (or bs.hex if it's P/N). See https://docs.google.com/spreadsheet/...jU1YzdBQkZZRlE
Yeah, either the wires aren't connecting properly, a FET is bad, or something is wrong with the circuitry. Since you haven't flashed it, you could try returning it.
Thank you much
Dale.E is offline Find More Posts by Dale.E
Old Sep 19, 2012, 01:13 PM
Manuel Silva is offline
Find More Posts by Manuel Silva
Oporto Portugal
Joined Sep 2007
Help Lash HK F30A ESC
Hello all!
I do not know if it is the right place to put the difficulties I have to program a ESC with the Simon kirb firmware.
I have an AVRISPMKII and using the AvrStudio I can read the actual firmware of the ESC, read the fuses, etc. Using the ESC Flash Tool I can not program the ESC, I get the following MSG: "avrdude.exe: ser_open(): can't open device "\\.\com1": Access is denied" .
I installed the ".NET framework" and the ESC Flash tool according to the instructions.
Can some one help to solve the problem or if I can get the .hex file I can program it directly with the AVRISPMKII. About the Fuses, doen any one know if we need to change the Fuses setting.
Thanks in advance
Manuel
Manuel Silva is offline Find More Posts by Manuel Silva
Old Sep 19, 2012, 01:22 PM
Oporto Portugal
Joined Sep 2007
I looked for some posts back and I think it is the right thred to put the problem of flash the HK F30A ESC with the AVRISPMKII.
Simon, can you, or some one else help solving the problem?
thanks
Manuel
Old Sep 19, 2012, 03:04 PM
simonk is offline
hacker
Joined Dec 2010
Hmm, when you say they don't sound the same, do the beeps sound low? Perhaps you changed the fuses somehow so that they aren't running at the proper speed, and that is making them sound different and not arm. Curious that that the USB linker is able to talk at all but get errors. Can you try with ISP again and read the fuses, and post the values? On the ones that start at middle throttle, do they beep (and enter calibration mode) if you start with the throttle at full? At just around/above middle?
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
