Old Aug 27, 2012, 10:43 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by thwaitm View Post
and HK F-30A are about to be put into stock after the back orders (like mine) are filled... and mine just went from back ordered to reserved
Lucky you! After waiting 14days for nothing, last night I just cancelled my backorder for 4 F-30A's, and used the credits for 4 Blue 20's because they were in stock (and 20 is enough for me). F30A and F20A are still currently backordered; both popular esc these days so who knows how much longer before my order would have finally been filled. The Blues will take an hour longer for me to flash because the pads aren't in a row (can't use my clip). OTOH I'm content spending that extra hour, rather than wait 14days to get pads in a row.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Aug 27, 2012, 02:05 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
I successfully flashed and calibrated all 6 of my BlueSeries 30 Amp ESC's. Thanks to all for help along the way.
I made a "flash my ESC" video for my build log in case anyone is interest. Most of the other tutorials I found seem to leave out some steps, so I tried to cover it all. I used kkflashtool, which has great documentation, so I did not dwell on the software itself.
This is my first venture into this kind of thing - I am not an electronics person. For those in a similar boat, maybe this will be helpful.
Derek
Flash BlueSeries ESC with SimonK firmware (9 min 59 sec)
DerekB is offline Find More Posts by DerekB
Old Aug 27, 2012, 02:27 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Has anyone flashed the HobbyKing BlueSeries 12A? I know it's compatible but what were your experience with them?
TheFernMan is offline Find More Posts by TheFernMan
Old Aug 27, 2012, 03:59 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Code:
BsNfet.inc
hf:DA
lf:2E
alll is offline Find More Posts by alll
Old Aug 27, 2012, 06:30 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
So I'm curious, with the upgraded firmware, will some of these ESC's run hot? I just upgraded three of them for my tri (HK SS 25A with Atmega) and found that they all run pretty warm. I'm flying DT-750's with 11x4.7 GWS props and 10x4.7 APC SF props. With the 11x4.7, I'm pulling about 9A in a hover and 18A when I throttle up to gain altitude according to my EagleTree logger.
I'm not too concerned as they're not overly hot but I'm sticking a GoPro on it and then FPV gear a little later so I wanted to know if I would eventually need better ESC's or if it's normal for the newer firmware to run a little hot.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Aug 27, 2012, 06:43 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Please try http://www.rcgroups.com/forums/showt...z#post22092906 ...The HK-SS boards around that size have a serious electrical problem that causes excessive fail particularly at PWM rates above 8kHz. There are a lot of posts about it in this forum, and somebody even recently mentioned that they could measure a heat difference between 8kHz and 9kHz. If you can't stand the PWM sound, go with F-20A boards instead.
simonk is offline Find More Posts by simonk
Old Aug 27, 2012, 06:45 PM
DerekB is offline
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
I read somewhere that SimonK firmware makes the ESC run "warmer" because it is working it "harder" (ie, higher frequency and such), which is why certain ESC's with quality components are more desirable. Supposedly the Hobby King F30A brand and the BlueSeries are recommended due to the high quality components.
Beyond that, I really can't say - I'm not an electronics person - that's just what I read somewhere.
(ah, from the man himself in the post above)
Old Aug 27, 2012, 08:08 PM
Joined Jan 2007
Oh man, I'm going to have to take everything apart again! Oh well, I don't care too much about having the sound as I couldn't tell too much of a difference. Having to solder everything on for each ESC will be a pain. I'll need to find more heat shrink again too!
Back to the man cave tomorrow to fix these issues...
Oh, simonk, with those new hex files, what method do you recommend to load everything up? I used LazyZero's software as it's quite easy. I assume I can just point the program to the location of the tgy hex file and that should take care of the rest correct?
Old Aug 27, 2012, 08:56 PM
ziss_dm is offline
Find More Posts by ziss_dm
Joined Nov 2008
Hi,
Another option could be to use latest wii-esc: http://code.google.com/p/wii-esc/
Due use of Sigma-Delta modulation instead of PWM it has higher efficiency with relativelly low noise emission. It also has higher resolution ~ 1600 points in standard range.
regards,
ziss_dm
ziss_dm is offline Find More Posts by ziss_dm
Old Aug 27, 2012, 09:01 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
hi ziss.. im interested in wii-esc fws.. and would be interested to know what is the downside of wii-esc? simonk works pretty good eliminating the whine and better efficiency.. but does not work with some pancake motor.. how about wii-esc?
thanks
James
jy0933 is offline Find More Posts by jy0933
Old Aug 27, 2012, 09:19 PM
ziss_dm is offline
Joined Nov 2008
Hi,
Probably wrong person to ask. but..
Bright side:
1) up to 4000 steps of resolution.
2) low noise with comparatively high efficiency (Sigma-delta modulator, instead of fixed frequency PWM)
3) linear power response. (completely no "bump" at 100%)
4) Sync recovery.
5) Safe stall detection.
6) Complimentary PWM support
dark side:
1) no EPA, throttle endpoints are fixed.
2) no reverse
3) probably lower max RPM.
4) require removing BEMF capacitors ;(
There are people reporting success with pancake motors.
regards,
ziss_dm
Old Aug 27, 2012, 09:23 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
Originally Posted by ziss_dm View Post
Hi,
Bright side:
4) Sync recovery.
dark side:
2) no reverse
regards,
ziss_dm
it's actually a piece of good info.. seems it is best for pancakes most time
Old Aug 27, 2012, 10:14 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
My flashed ESCs work oh-so-much-better than the stock ones. Here's a video I did recently with them...it was pretty windy and the quick response of the flashed ESCs made a difference on keeping things 'level'...but not always dry . Watch the video for the rest...
Wet -n- Dry (5 min 10 sec)
Vantasstic is offline Find More Posts by Vantasstic
Old Aug 28, 2012, 12:16 AM
simonk is offline
hacker
Joined Dec 2010
Nah. The HK-SS boards just have problems where the noise caused by switching on a low-side FET and swinging down a phase voltage from Vbat+body diode conduction losses is enough to briefly turn on all high-side FETs. This can happen even at 8kHz under heavy load, but it typically happens less at lower PWM frequency, regardless of firmware.
Oh man, I'm going to have to take everything apart again! ... I assume I can just point the program to the location of the tgy hex file and that should take care of the rest correct?
If you get the Turnigy USB Linker, and enable the boot loader in LazyZero's flashing tool, you can use the USB Linker through the servo wire only for future upgrades or even wii-esc, as long as it doesn't clash with a built-in boot loader there.
Old Aug 28, 2012, 04:54 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
A part form your source code ... do you have anywhere the the specs for this "communication" protocol at the ESC plug level .. it must be a bidirectional interface over 1 single line ... since the other 2 are fixed lines
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
