Sorry for my noob ? But what esc are the best and easyst to flash I have all the tools to do it
Latest blog entry: Win a frame
Thanks TC (and SS)
Problem solved - missed a step in loading up the KK flash tool Quote:
The Netherlands, LI, Venray
Joined Dec 2008
Hello,
i am using Hobbywing Flyfun 18Amp for my quad, i did not know if these are high refresh ESC, so i asked my seller he stated: As we know, all the flyfun series ESCs have a high refresh rate of 423HZ. We also confirmed this information with Hobbywing company. And they are all compatible with multicopters. Did anyone know this already?, so there is no need to flash them ? |
i dont think hw's esc does high fresh rate....
http://www.hobbywing.com/product_show.asp?id=201 |
incase you didn't get it, hobbywing esc = garbage, do not buy, do not waste money, cheaper, better ESC is available that is reflashable. |
Doha, Qatar, Middle East
Joined Jan 2005
Hi Guys
Im having some issues getting my software setup to flash some esc's I am trying to run the lazyzero tool When i try to run the serial command to launch the program i get this message. "java is not recognized as an internal or external command, operable program or batch file" Even though i have Java installed? What am i doing wrong? Then i have tried the Chatch15117 fashtool and i get the following message avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update. avrdude.exe: error: programm enable: target doesn't answer. 1 avrdude.exe: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude.exe done. Thank you. I am trying to flash RCtimer 18amp esc using HK USBasp programmer. I am pretty sure i have the driver installed correctly for this programmer. Any ideas what i am doing wrong? Cheers Ben |
Slovenia, Ljubljana
Joined Sep 2011
| Thread Tools | |
| Discussion Rctimer 30A esc cutting out with KK board | Efliernz | Multirotor Talk | 2 | May 26, 2011 02:20 PM |
| Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors | pwu_1 | Aircraft - General - Miscellaneous (FS/W) | 2 | Jan 18, 2011 09:58 PM |
| Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! | planebldr | Aircraft - Electric - Power Systems (FS/W) | 4 | May 25, 2010 09:54 PM |
| Discussion RCTimer 30A Programmable ESC | hunter7193 | Power Systems | 8 | Jan 02, 2010 02:27 PM |
| For Sale Several New ESC's - 10a, 20a, 30a - Reduced | Callen9345 | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 20, 2009 02:31 PM |
