Old Oct 02, 2011, 02:44 PM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Turnigy/Hobbywing 6A old version with Atmega.
1'st photo courtesy of RCexplorer
SebastianJ is offline Find More Posts by SebastianJ
Old Oct 02, 2011, 03:44 PM
Droner
SebastianJ's Avatar
Joined Mar 2006
Turnigy/Hobbywing 25A
Old Oct 02, 2011, 08:27 PM
Nek is offline
Nek
Find More Posts by Nek
Nek
DIY O.G.
Nek's Avatar
French Polynesia, Windward Islands, Faaa
Joined Nov 2002
Thanks bas10an, I updated the first post with those pictures!
Nek is offline Find More Posts by Nek
Old Oct 02, 2011, 08:35 PM
firepong is offline
Find More Posts by firepong
United States, AR, Jonesboro
Joined May 2011
Whoo buddy. If that's the bottom view, then I can flash my dynamic 25's. Haven't taken the shrink off yet, but the chips look exactly the same through it.
firepong is offline Find More Posts by firepong
Old Oct 02, 2011, 11:23 PM
c2po is online now
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
My preliminary tests show that current is now about 5-7% less, maybe even more, so that would probably add about a minute to a flight time, as Nek mentioned before.
So far I'm very happy with all the benefits and impovements, thanks again.
c2po is online now Find More Posts by c2po
Old Oct 03, 2011, 12:00 AM
pinball is offline
Find More Posts by pinball
USA, AK, Soldotna
Joined Jan 2005
Originally Posted by Nek View Post
Pinball can you post a close up pic of your ESC, the side that has the Atmega8?
Didn't have much time tonight. This was taken through the shrink, if you want a better shot I should be able to tomorrow night.
The chip is a Mega8L. Is there something specific you want in focus?
pinball is offline Find More Posts by pinball
Old Oct 03, 2011, 12:15 AM
Nek is offline
Nek
Nek
DIY O.G.
Nek's Avatar
Joined Nov 2002
Well it looks like you have the 6 programming pads at the bottom, you will need to check the pin order direction. Just take a close look at the traces and you can probably figure out where ground and vcc are and guess the rest if you don't have a multimeter to check to what pin on the Atmega8 each pad connects to.
Good luck!
Old Oct 03, 2011, 12:17 AM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
Yup, I'm an ET for a living so I think I can find a meter somewhere.
I just happen to have a pro mini 328 at work with me, and am tempted to program it up and try and flash these. In theory I should just have to tell avrdude the programmer type is 'arduino; right?
Thanks for all the help!
Old Oct 03, 2011, 12:19 AM
Nek is offline
Nek
Nek
DIY O.G.
Nek's Avatar
Joined Nov 2002
No worries, you can probably give this a shot: http://arduino.cc/en/Tutorial/ArduinoISP
Old Oct 03, 2011, 12:21 AM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
Yup, thats what I was going to go by. I will report back if / when I try it out. So far it sounds like there aren't any downsides to it.
Old Oct 03, 2011, 12:49 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Simon, consider doing a 200-1200ms (UltraPWM) version of the code and gain popularity with the Xaircraft users (poor guys).
Really, 200us-1200us? Just change MIN_RC_PULS to 100, MAX_RC_PULS to 1300, STOP_RC_PULS to 300ish, and it should just work. If you want no deadbands at each end, just adjust POWER_RANGE to 1000 to stretch it out; it's a fully-adjustable 16-bit range now.
I just pushed a newer version that corrects a few things and hopefully starts more smoothly with all motors at higher voltages. Most importantly, it lowers the duty cycle maximum based on timing even if no new pulse is received. This should prevent burning if the motor plants into the ground and the pulse wire or receiver breaks at the same time. Previously, it would have to wait ~1.5 seconds for the receive timeout to reset.
Also, it now runs the 8MHz boards at 16MHz by setting OSCCAL to 0xff (as far as I can tell, this is safe as long as we don't use the EEPROM without restoring it), so the same tree can now be used on boards with or without 16MHz oscillators without changing the code. From this, we also get the ability to support 800 PWM steps (or more at lower PWM cycle frequency).
timecop supplied a patch to restore I2C support, which I still need to merge. I'm wondering if there's a nice way to set the ID without having to make a new build for each controller. Has anybody seen any nice ways to do this?
As with all builds, please test carefully; I don't have a BlueSeries board to test with, and I just rewrote the PWM interrupt code again, so it may blow up, and YMMV.
Cheers!
simonk is offline Find More Posts by simonk
Old Oct 03, 2011, 12:53 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
You can do I2C by sticks maybe? power up with throttle high, beep, then beep X times for I2C address. Of course this is all only MK-specific ...
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 03, 2011, 12:59 AM
Centurion1 is offline
Find More Posts by Centurion1
Joined Sep 2011
this sounds like interesting change to make. I have to see if I can scrounge up for pogo pins to make a programming bit easier .
Centurion1 is offline Find More Posts by Centurion1
Old Oct 03, 2011, 01:11 AM
c2po is online now
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Looks exactly like ESC that bas10an pictured in post #31 with pin-out.
Old Oct 03, 2011, 03:41 AM
Droner
SebastianJ's Avatar
Joined Mar 2006
Cheers!
Excellent work Simon,
I just presented this in the XA thread, perhaps someone are willing to try it and report back:
http://www.rcgroups.com/forums/showp...ostcount=13025
I2C talk - Will this work with I2C without physical mods to the ESC?
And could this over time evolve into including a user interface like Castle creations?
Set I2C adresses, configure different ESC brands/versions, select PWM, switching freq, motor direction!! etc.?
I don't know squat about coding, but since this is already open source I'm sure that some of the clever guys out there would take this on in an instant.
This could be the next BIG thing in multirotors.
Keep up the good work gentlemen
Sebastian
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
