Old Sep 30, 2011, 08:28 PM
pinball is offline
Find More Posts by pinball
USA, AK, Soldotna
Joined Jan 2005
This sounds sweet! Specially since I use RCtimer 20As. Thanks for the great write up and info. You mentioned that plush ESCs should work too. I have a set of plush 6As on my mini Tcopter. How can I tell if this FW will work on them?
Will it work on any ESC that uses an Atmega8?
Thanks again!
pinball is offline Find More Posts by pinball
Old Oct 01, 2011, 08:23 PM
c2po is offline
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
It worked just fine on my Plush 10A which is old Atmega8 based, see the picture.
Finally that annoying 8kHz whine from the motors is gone, and motors are very smooth.
Why didn't I do that before?
Thank you so much everyone who made it possible, quax, Simon, timecop, Nek, and others.
For the reference: pads are (from top to bottom on the picture) - MOSI, MISO, SCK, GND, VCC, RESET, in same order as other ESC.
c2po is offline Find More Posts by c2po
Old Oct 01, 2011, 08:43 PM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
Nice! Did you notice a performance gain; ie more stable due to the better update rate? I might have to pull the shrink off my 6A and see whats under there.
Pretty sure I know the answer to this question, but is there any way to use an FTDI to do this? I'm at work for the next 2 weeks and have an FTDI and my mini Tcopter with me...
Old Oct 01, 2011, 08:55 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
No you need a proper AVR programmer
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 01, 2011, 09:37 PM
milo12 is online now
Find More Posts by milo12
Joined Feb 2011
Can any one do this for me for a fee? I do not have the materials or the skills to do this. I will buy the esc's and send them to you. Please PM me if you can help.
milo12 is online now Find More Posts by milo12
Old Oct 01, 2011, 09:39 PM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
Thought so. Thanks.
Old Oct 01, 2011, 11:28 PM
c2po is offline
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
I just did a quick check to see if ESCs are working so haven't done full comparison tests yet, it will take a while, don't have much spare time. But I'm pretty sure there will be some improvements as reported by others. Just not having that stupid high pitched noise anymore alone worth the conversion!
Yes, timecop is right, you need special AVR programmer, one of the cheapest one is USBasp, but there are others, including the method of converting Arduino board into AVR ISP programmer.
I just had AVRISP mkII in hand, so I used it to reprogram ESC.
Old Oct 02, 2011, 12:33 AM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
Thanks for the links. Found this on Ebay: http://www.ebay.com/itm/USBASP-USB-I...ht_4770wt_1396
Looks like the same thing only cheaper.
Old Oct 02, 2011, 09:29 AM
edge0xc is offline
Find More Posts by edge0xc
Joined Sep 2011
hey,
i have a question:
are the rctimer 18A the escs like the hobbywing 18A?
Cheers
Alex
edge0xc is offline Find More Posts by edge0xc
Old Oct 02, 2011, 09:37 AM
timecop is offline
Joined Dec 2010
Yes
Old Oct 02, 2011, 10:40 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I've been running my copter on RCtimer ESCs for ages in lipo cutoff mode and just monitoring my flight times and landing before cut-off. Does anyone know If I will have to re-calibrate the throttle if I hook them up to a program card and change the setting to NiMH?
lovegroove is offline Find More Posts by lovegroove
Old Oct 02, 2011, 10:45 AM
timecop is offline
Joined Dec 2010
I think so. I remember I calibrated throttle on one then forgot I didn't card program it, went back to do card setting, then throttle got reset. You can easily check with some FC that allows sending motor test pulses like CopterControl or similar. But just to be safe I'd recalibrate.
Old Oct 02, 2011, 01:37 PM
Nek is offline
Nek
Find More Posts by Nek
Nek
DIY O.G.
Nek's Avatar
French Polynesia, Windward Islands, Faaa
Joined Nov 2002
That is another plus of that firmware, no need to calibrate the ESC anymore, they are set on standard 1000/2000 range!!
Pinball can you post a close up pic of your ESC, the side that has the Atmega8?
Nek is offline Find More Posts by Nek
Old Oct 02, 2011, 01:38 PM
pinball is offline
USA, AK, Soldotna
Joined Jan 2005
I might be able to pull the shrink off of one tonight. I will post pics then.
Old Oct 02, 2011, 02:15 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
It was a kind of off topic question. I'm not going to re-flash my ESCs, I just want to program them with the program card. I may get round to flashing them at some point in the future, but it would be really annoying to try and do that with them hardwired into my hexa.
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
