Old Oct 23, 2011, 06:49 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Johnny,
Nice adapter Where did you get the pogo pins?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Originally Posted by jonnyc67 View Post
Well I finally got my pogo pins in the post, so I knocked up a quick programming clip, attached my programmer & got flashing. 6 18A & 6 30A rctimer esc's are now running tgy.hex. The ones I've tested seem pretty good.
As requested here are a few pics of my programming adapter.
Step 1 - Solder wires between 6 pin header & ends of pogo pins - ...
jesolins is offline Find More Posts by jesolins
Old Oct 23, 2011, 08:37 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
http://www.sparkfun.com/products/9174
probably the cheapest place for them, sadly as everything else on sparkfun is severely overpriced.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Oct 23, 2011, 08:56 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
you would like to purchase them in quantity, here is an ebay listing.
http://www.ebay.com/itm/100pcs-P75-E...item27bf614f8a
rimshotcopter is online now Find More Posts by rimshotcopter
Old Oct 23, 2011, 09:58 AM
jonnyc67 is offline
Find More Posts by jonnyc67
jonnyc67's Avatar
Hi Jim - rimshotcopter's ebay suggestion is as good as any.I posted the ebay link for the pins I got early on in the thread. If I did it again I'd use P50 or p75 b1, j1 or q1 pins as they have a smaller head, as clearance is a bit of an issue (I'd also weaken the peg's spring a bit at a guess). I store it with a pencil keeping the jaws open so I don't ruin the springs in the pogo pins.
jonnyc67 is offline Find More Posts by jonnyc67
Old Oct 23, 2011, 05:12 PM
Nek is offline
Nek
Find More Posts by Nek
Nek
DIY O.G.
Nek's Avatar
French Polynesia, Windward Islands, Faaa
Joined Nov 2002
thx jonny, updated the 1st post with your setup.
Nek is offline Find More Posts by Nek
Old Oct 23, 2011, 06:37 PM
jesolins is offline
Joined Feb 2007
Hi Johnny,
I found this mother-lode link of of pogo pin selections, but the size nomenclature is a bit different. I supposed smallest is the best choice for this? http://www.alliedelec.com/search/sea...&Term=pogo+pin
Cheers,
Jim
Old Oct 23, 2011, 07:16 PM
c2po is offline
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Here is another place for 10 pack of Pogo Pins:
http://www.adafruit.com/products/394
c2po is offline Find More Posts by c2po
Old Oct 25, 2011, 10:20 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
I can report that 12A plush works with the TGY.hex firmware (on the bench, not flight-tested yet)
Attached is a picture of the ISP-connections for this ESC.
Thanks to all the contributors and SimonK in particular!
JussiH is offline Find More Posts by JussiH
Old Oct 25, 2011, 12:35 PM
Nek is offline
Nek
Nek
DIY O.G.
Nek's Avatar
Joined Nov 2002
Thanks for the picture Jussi, I updated the main post with it.
Old Oct 25, 2011, 01:19 PM
Saneless is offline
Find More Posts by Saneless
Joined Jun 2011
Anyone know the difference between the v3.1 and v4.1 of typical HobbyWing/Turnigy Plush ESCs?
I've got a few Plush v3.1 and some HobbyWing v4.1. I'd like to mix them on a Y6 but only if I'm able to re-flash all to the same firmware.
V4.1 at the bottom. What do you electronics experts think?
Also, since you can't see the chip on the v4.1, it's SIL F330.
Saneless is offline Find More Posts by Saneless
Old Oct 25, 2011, 02:00 PM
Centurion1 is offline
Find More Posts by Centurion1
Joined Sep 2011
both are sil chip, which you cannot flash using this code.
Centurion1 is offline Find More Posts by Centurion1
Old Oct 25, 2011, 05:45 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
anybody find a place for that really thin clear & black hs tubing? haven't had much luck on my end....
bob4432 is offline Find More Posts by bob4432
Old Oct 25, 2011, 06:27 PM
jonnyc67 is offline
jonnyc67's Avatar
Originally Posted by jesolins View Post
Hi Johnny,
Cheers,
Jim
Hi Jim - yes I'd definitely get the smallest possible - I had a look at the link you posted, I'd look at size 0 at max by their sizes (or get the metric pins off ebay as they're cheaper). the p50 pins (0.68mm dia) would be best as the p75 (1.02mm dia) pins are just too large to be able to set straight once you've got the wires soldered & the insulation done.
Cheers, Jon
Old Oct 25, 2011, 07:30 PM
timecop is offline
Joined Dec 2010
I was told this works
http://www.amazon.com/gp/product/B001HYMIQW
Double check everything though.
Old Oct 25, 2011, 07:43 PM
c2po is offline
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Well, sad news. Just bought few of RCTimer 6A ESC and of course they also are now based on SIL C8051F334... Aaargh!
Does anyone know where to get AVR based 6A?
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
