Old Jan 25, 2012, 04:02 PM
Fuwubuman is offline
Find More Posts by Fuwubuman
Joined Jan 2012
Well thats good news
Fuwubuman is offline Find More Posts by Fuwubuman
Old Jan 25, 2012, 05:01 PM
Uranium is offline
Find More Posts by Uranium
Joined Sep 2011
Originally Posted by TomSn0w View Post
Uranium I will add it for you
The ESC was a dead end. The pads were not connected to the programming pins (but to the mosfet gate drivers, probably to test the power stage). The reset pin is hard tied to VCC (and under the chip, dang) so programming without trashing it is not possible.
This is a major bummer as the default software on the atmega is absolute sh*t. The motors often don't start and when they start it often loses timing blowing the fuse as it runs dc through one winding.
Uranium is offline Find More Posts by Uranium
Old Jan 25, 2012, 05:30 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi U,
Yikes! Please post a link to those so I can put them on the ESC poor performer notrecommeded list in the Quadrocopter and Tricopter Mega Link Index
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Jan 25, 2012, 07:52 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
The RCTimer 50A is like this, too, but the trace is not under the chip. Maybe you could tie the output to the reset pin and then it would burn off the trace for you.
simonk is offline Find More Posts by simonk
Old Jan 26, 2012, 09:25 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Can someone tell me if one of these (Pomona PLCC Quad Clip Test Adapter, 32-Pin) will work for flashing ESCs? I know it is expensive.
http://www.hmcelectronics.com/produc...googleshopping
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 26, 2012, 11:25 AM
Peter Seddon is offline
Find More Posts by Peter Seddon
Solihull, England
Joined Jun 2004
I have successfully flashed two (out of two) with the tp.hex firmware.
Peter
Originally Posted by IceWind View Post
On first look they look the same as mine.
I ended up never flashing them, but if you go ahead and works please share what version you used.
Thanks.
Peter Seddon is offline Find More Posts by Peter Seddon
Old Jan 26, 2012, 02:28 PM
CATA2003 is offline
Find More Posts by CATA2003
Joined Jan 2012
Brushless controller
CATA2003 is offline Find More Posts by CATA2003
Old Jan 26, 2012, 02:30 PM
CATA2003 is offline
Joined Jan 2012
......interesting
Old Jan 26, 2012, 02:36 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
meow?
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Jan 26, 2012, 04:12 PM
obor is offline
Find More Posts by obor
France
Joined Nov 2003
Hi Simonk,
Which version of your firmware would you recommend to flash this ESC (Turnigy TY-P8) ?
obor is offline Find More Posts by obor
Old Jan 26, 2012, 06:08 PM
simonk is offline
hacker
Joined Dec 2010
Originally Posted by obor View Post
Hi Simonk,
I haven't tested it myself and HK dropped it from my order, but if it's the TY-P1 (not sure what TY-P8 is), it should be tp_nfet.hex, as per https://github.com/sim-/tgy/blob/master/README.md.
Old Jan 27, 2012, 02:43 AM
obor is offline
France
Joined Nov 2003
Thanks Simonk. oh yes, I meant TY-P1 and not TY-P8... So I'll pick the last git version and flash. I have 10 to burn and see how it goes.
I saw on your readme page an interesting comment: " This doesn't yet check temperature or battery voltage. This is not desired on multi-rotor platforms; however, people still want to use this on planes, cars, boats, etc., so I suppose I'll add it."
That's true, on multikopter we don't want the ESC to cut when overheat. However, it could be cool to provide the temperature information on a dedicated wire (when available).
Old Jan 27, 2012, 03:28 AM
wwldo is offline
Find More Posts by wwldo
USA Retired
Brooksville Florida
Joined Jan 2003
Maytech 30A AKA ZTWs
Hello Simonk,
Which version of your firmware would you recommend to flash this ESC..?
And how do I go about reading and saving the stock SW/FW..?
Larry
wwldo is offline Find More Posts by wwldo
Old Jan 27, 2012, 03:41 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
i'd guess bs_nfet, that almost looks like 20A blueseries.
You can't have original firmware, its usually locked.
timecop is offline Find More Posts by timecop
Old Jan 27, 2012, 04:25 AM
wwldo is offline
USA Retired
Brooksville Florida
Joined Jan 2003
timecop:
It's A 30A E Series with International Rectifier Co. n-FETs.
Also it has ZTW printed on the circuit board.
Do I use the round dots/pads for flashing...?
I looked for similar in the data base but no joy...!
Larry
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
