Old Jan 23, 2012, 05:47 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Originally Posted by timecop View Post
Stuff between october and december 31 is buggy. You should update.
Thanks, doing it now....
JussiH is offline Find More Posts by JussiH
Old Jan 23, 2012, 06:42 AM
icedfusion is offline
Find More Posts by icedfusion
Joined Aug 2011
Just been reading through this thread. How can you tell if the ESC is:
1. all nfets
2. nfets + gates
3. Alternatives?
I have a few of these 'Mystery 30A Firedragon' series, could someone enlighten me as to what is on it (FET wise, so I can try and flash it) - I will probably just solder the relevant wires straight onto the pins of the IC to flash.
Cheers
ice.
icedfusion is offline Find More Posts by icedfusion
Old Jan 23, 2012, 06:44 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Looks like P/N fets, and since its called mystery, maybe 'bs.hex' target?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 23, 2012, 07:07 AM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Just got into this, but I do not understand why should I reflush my ESC (unless I want to change it to I2C for MK) ?
I have DJI wooking and Plush ESC.
sharonx is offline Find More Posts by sharonx
Old Jan 23, 2012, 07:08 AM
timecop is offline
Joined Dec 2010
It makes them SUPER FASTER.
Old Jan 23, 2012, 08:02 AM
Joined Aug 2011
THanks for that that TC - I will try it and see - I am assuming direct wire connection to the relevant pins is ok? No pullups etc need?
Cheers
ice.
Old Jan 23, 2012, 08:05 AM
timecop is offline
Joined Dec 2010
Yeah, just clip them or solder to them or wahever - plenty of examples in the pics in this thread.
Old Jan 23, 2012, 08:29 AM
sharonx is offline
sharonx's Avatar
Timecop - do you mean more hz ? more than 400 ? is it needed for DJI wookong
Old Jan 23, 2012, 10:11 AM
timecop is offline
Joined Dec 2010
https://github.com/sim-/tgy
Just read the text below, if you don't need it, then you don't need it.
Old Jan 23, 2012, 11:29 AM
Joined Aug 2011
I have just tried flashing a HobbyKing F-30A. THe spreadsheet and also the flash tool, wants to flash the bs_nfet.hex file. However, if I flash bs_nfet.hex, I do not get a 'beep'. If I flash the bs.hex file, I get a beep when it finishes flashing and I also get 'beeps' when I power it on.
Which is the correct file to use (i was under the impression, beeps = good, no beep = bad? I don't want to flash 4 of them, build a quad, only to find I have to resolder the wires and reflash them all again so any input appreciated.
(note I am using avrstudio with an avr dragon and selecting Atmega88PA as the IC to flash to)
Cheers
ice.
Old Jan 23, 2012, 11:51 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi IF,
The ESC beeps are good If you look at the numbers on your FETs and there are two different types, then you have P/N and the bs.hex is proper.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Cheers
ice.
jesolins is offline Find More Posts by jesolins
Old Jan 23, 2012, 11:58 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Cheers
ice.
shouldn't that be Atmega8 ?
SadSack is offline Find More Posts by SadSack
Old Jan 23, 2012, 03:36 PM
Joined Aug 2011
That is the thing that is confusing me. They HobbyKing F-30A all have the same number on the FETS, so I assume that they are all nfets. However, if I flash with the bs_nfet.hex I do not get any beeps, whereas if I flash with the bs.hex, I do get the beeps.
I am not talking about the mystery ESC's i posted a few posts back, but these ones:
Originally Posted by jesolins View Post
Hi IF,
Cheers,
Jim
The closest IC I can choose to flash from the AVR is 'Atmega88' - not sure why there is not an 'Atmega8'
Cheers
ice.
Old Jan 23, 2012, 04:06 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Question, Anyone flashing these for sale for example 30A or higher?
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 23, 2012, 04:26 PM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
just want to tell you that blueseries 20A don't like cold weather.
3 of 4 beep when i let them for 5min out in 0C
i will try to plasti dip them. but i don't expect wonders
which component causes this ?
they have an external oscillator.
frustrating.
w4Rd3n is offline Find More Posts by w4Rd3n
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
