Old Jan 21, 2012, 01:47 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
Originally Posted by wheelspinner20 View Post
Buffy, that thing is solid. The on-board video at times looked like it was on a tri-pod.
Outstanding, congrats. Which motors and controller??
Pat
Maiden flight of my DJI Naza Quad. Reflashed RCTimer 30a escs, thanks to SimonK. RCTimer motors 750kv, APC 1047 props, 3s 3300 battery, Lawmate 2.4 500mw vtx, IRC 5v camera, Dragon Link UHF. RTF weight is 1240g's. Default gyro settings(100 across the board).
GWS 3 blade props come so unbalanced i needed like 5 pieces of tape on the light blades lol
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Jan 21, 2012, 01:48 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
How do I read youtube video description??
timecop is offline Find More Posts by timecop
Old Jan 21, 2012, 01:50 AM
Joined Apr 2011
rofl
one does not simply "read" a youtube video description!!! ever!!!
timecop got dubs
Old Jan 21, 2012, 03:16 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Could you not implement a PID cloded loop?...
Originally Posted by simonk View Post
Hey, I've used the Hobbywing 60A in rock crawler mode in my car, and recently compared with the AfroESC flashed with RC_PULS_REVERSE=1 and MOTOR_BRAKE=1. It worked but the brake was so strong that it just killed the tires (and it was hard to drive as a result). Depending on the motor, etc., it probably makes more sense to implement pulsed braking again first. I was going to do this, after a few other things.
Also, is it common for RC car radios to have the thumb brake these days? Mine sends a really short pulse with that pressed (~800µs) -- it might be nice to support harder braking on that and not actually transition to reverse. Also, drag brake is useful (light pulsed brake when in idle throttle). The only other thing is that the adjustable start power is probably fairly important. I think a 25% duty limit to start is probably a bit low in some applications, depending on gearing, etc. It's still pretty easy to slip the differential in my RC10, though. Yours is probably geared a lot more?
alll is offline Find More Posts by alll
Old Jan 21, 2012, 03:26 AM
GrootWitBaas is offline
Find More Posts by GrootWitBaas
I don't speak German ....Yet !
GrootWitBaas's Avatar
Germany, Baden-Württemberg, Weissach im Tal
Joined Dec 2010
Originally Posted by chatch15117 View Post
no it's just a GUI interface that uses avrdude. It builds the avrdude command string piece by piece when you select what programmer/esc you have.
Now can you add a fuse screen, for changing the Int/Ext oscillator and eeprom retain (keep calibrations)
GrootWitBaas is offline Find More Posts by GrootWitBaas
Old Jan 21, 2012, 03:28 AM
timecop is offline
Joined Dec 2010
http://www.engbedded.com/fusecalc/
Old Jan 21, 2012, 03:49 AM
Joined Dec 2010
yea I use that one 2, but was thinking it may be good to have a simple selection in the flash gui. Something to read the current settings, and then just have simple selection for example if a external oscillator was added to change this. For normal flashing they should be left alone anyway and will work fine
Old Jan 21, 2012, 04:14 AM
timecop is offline
Joined Dec 2010
Ya. I dunno if there's a difference for fuse numbers for atmega8/a/l, if there isn't, current stuff could be read out and just bits masked for extosc/whatever without giving the user too much power to screw stuff up. Could be a worthy addition.
Old Jan 21, 2012, 06:27 AM
noppita is offline
Find More Posts by noppita
noppita's Avatar
Joined Jul 2009
i have some finding to share
i just receive new rctimer 30 amp for my hexcopter (MK)
and one of the 6 motor start later than the other 5. i calibrate by both rx and i2c converter and still motor start late.
so i move my tx subtrim up by +20 and now all motor start about the same time.
anyone know what is happen here and my solution is good????
noppita is offline Find More Posts by noppita
Old Jan 21, 2012, 07:27 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
Pat
Thanks Pat. RCTimer 2830/14 750 kv motors and the DJI Naza FC. Very impressed with just the Naza default gyro settings. A true "400" esc makes it possible;-)
Buffythesaint is offline Find More Posts by Buffythesaint
Old Jan 21, 2012, 08:28 AM
Schorschi is offline
Find More Posts by Schorschi
Joined Aug 2009
Hobbyking SS Series 25-30A ESC
Hi guys,
i tried to flash some Hobbyking SS Series 25-30A ESC with tp.hex.
3 of 4 ESC work with the same configuration. But one worked for
the fist 30sec. Now i have to set brown out to 2,7V and i think one ore more of
the fets damaged.
This esc worked very well for more than 10 flights. I take my tests with current limit.
Someone else with the same esc or similar problems?
How to config the esc with tp.hex?
Now i tested a second esc with prop on Copter. After some trys motor stops and jitter. The
esc generates a magic smoke.... Someone a idea?
Georg.
Schorschi is offline Find More Posts by Schorschi
Old Jan 21, 2012, 09:02 AM
timecop is offline
Joined Dec 2010
Aren't HK-SS tgy targets, NOT tp?
Old Jan 21, 2012, 09:04 AM
Joined Dec 2010
not all .... I have some and they are all TP
Most ones I have is TP for some reason. I have seen some are TP and others are TGY
this was bought as HK SS 18
but traced out to TP.hex
Old Jan 21, 2012, 09:32 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
on 21st of november, I flashed some 20A mystery blue and some 18A plush. I seem to remember I used the most recent version from Github at the moment (BS.hex and TGY.hex), but not really sure, workshop computer is a mess - is there a way to work out version number from the .hex file (besides of course comparing versions line by line..)
There has been some talk about glitches... Do I need to change FW?
As a side note my Plush12A is still flying glitch-free on TGY.hex from 2011-09-06
Thanks!
Jussi
JussiH is offline Find More Posts by JussiH
Old Jan 21, 2012, 09:33 AM
timecop is offline
Joined Dec 2010
Stuff between october and december 31 is buggy. You should update.
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
