Old Jan 20, 2012, 08:47 AM
I'm new here
timecop's Avatar
Joined Dec 2010
Originally Posted by LazyZero View Post
Is there still the need to change fuses like mentioned in the first post and the Git?
Best Christian
No.
<simonk> only if it doens't work.
Two cases:
1) WDT is enabled, so it keeps resetting. Turn that off
2) You want BOD to be lower/higher.
timecop is offline Find More Posts by timecop
Old Jan 20, 2012, 10:07 AM
United States, FL, Maitland
Joined Apr 2011
http://www.youtube.com/watch?v=x6HOO9S0waU
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Jan 20, 2012, 10:27 AM
I'm new here
timecop's Avatar
Joined Dec 2010
I could tell it was reflashed ESCs cuz I couldn't hear the whine
Old Jan 20, 2012, 11:22 AM
Joined Apr 2011
ok im having some issues. the motors keep dropping rpm randomly. i can't tell what's causing the problem. if you look above in the video, when it drops and i recover, that's not me doing that. the throttle is at like 40% the whole time.
also in wind it isnt that great. it was having some trouble and i had to land it in the grass across the street.
the motors drop in uniform, as if i just put the throttle down to 20% and then i put it back to 80% to recover, then back to normal 40%.
Old Jan 20, 2012, 11:42 AM
manuLRK
Belgium
Joined Sep 2004
Nothing to do with the esc firmware imo, it's the kkb+kkfw+copter+(pilot) setup. For me this a normal behavior for a given setup.
manu
alll is offline Find More Posts by alll
Joined Apr 2011
ok i finished cache settings. it works. click "download cache" and it will recursively download all files that end in .hex
check the box that says "use cache" and it will not download anything. it will assume you have firmware file specified in the /debug/ directory
Old Jan 20, 2012, 12:57 PM
Southampton, Ontario CA
Joined Feb 2005
That sounds so quiet, what a difference. I'm jealous, shorts and barefeet. I have too go blow out my driveway, dam snow Watch out you don't chop up your toes too.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Jan 20, 2012, 12:58 PM
Espaņa, PV
Joined Apr 2011
Hello,
I am trying to reprogram this ESC:
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
Do not get it to work with the file bs.nfet.hex or with bs.het
When just programmed sounds "beep" does not work.
cheers,
Jose
josetxu is offline Find More Posts by josetxu
Old Jan 20, 2012, 01:16 PM
manuLRK
Belgium
Joined Sep 2004
It can be done ...
manu
Originally Posted by timecop View Post
What is the possibility? Zero. There's nothing to clip on the MLF package.
Nada, zip.
Old Jan 20, 2012, 01:43 PM
let's brm together!
Czech Republic, Prague
Joined Nov 2011
does anybody know what's different in the current batch of Turnigy Plush 25A ESCs? I had some year old ones, now I got some new ones - look the same, weight is the same, but they beep differently (higher pitched) - so I guess something is different. I'm worried about mixing them on a hexa. Anybody took a look already?
zviratko is offline Find More Posts by zviratko
Old Jan 20, 2012, 03:53 PM
Joined Apr 2011
http://www.tunerspotter.com/escfirmware/flashtool.zip
new one
Old Jan 20, 2012, 05:28 PM
hacker
Canada, BC, North Vancouver
Joined Dec 2010
You're talking about the SiLabs ones, I presume? The whole MCU is different and the firmware behaves quite differently. The throttle ramp may be different and so you may have skewing problems at higher and lower speeds. It's kind of fun to try something that people say not to do, though.
simonk is offline Find More Posts by simonk
Old Jan 20, 2012, 05:38 PM
hacker
Joined Dec 2010
I don't see this with anything I fly, but I still need to build a quad (everything has been tri so far). I think some vibration situations can cause the average throttle to be higher while present, and since the vibrations are amplified at the resonant frequencies of the frame, etc., it depends on the current motor speed, and so appear to come and go. I'm not quite sure why this would happen, however, as any oscillation would, in theory, average out to the same as no oscillation unless something (gyros, mixing, throttle response) is non-linear along the way. This is the only theory I have for that at the moment, though.
Old Jan 20, 2012, 05:44 PM
Joined Apr 2011
i balanced my props better and the problem kind of went away. i have narrowed it down to normal behavior recovering from high alpha and wind gust.
before the props would hit mechanical resonance - start shaking at X rpm and it would take a burst of power to push past that, then easy to continue past that point. so every time it hit mechanical resonance frequency it would jump and spaz out
Old Jan 20, 2012, 06:07 PM
I'm new here
timecop's Avatar
Joined Dec 2010
Originally Posted by alll View Post
It can be done ...
manu
Useful response, as usual. He was asking about clips that clip on to *QFP legs working with MLF package. Yes, you can ghetto up wires to them. No, I don't have that kind of time to waste.
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
