Old Jan 19, 2012, 09:43 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
calibration
FYI,
Got something really strange with 1 of the 4 plush 10A esc.
I reflashed all 4 with latest firmware. Calibrated all 4 at the same time. Only 1 does not "store" the value..., after a repower, it lost the calibration.
I tried to calibrate it separately, it does the calibration well, all ok, but after a repower, it loses it.
Solution, i had to trim down the throttle by a few trims
1)Full throttle -> 2)lower it -> 3)i get the calibration beeps "ok" -> 4)start the motor and see the effect of the calibration. 5)power off / on and lose the calibration
Now, when i do 1), 2), 3), 3bis) 5 trims lower, ....
It keeps calibration.
I should be on the edge of something...
For the info: the startup without calibration does follow this order! So, calibration with esc without ext osc, is a must! And it works great! Thanks Siimon. And now the programming without reflash...
Esc OSCCAL
1 A2(162)
2 A6(166)
3 AD(173)
4 B0(176)
Manu
alll is offline Find More Posts by alll
Old Jan 19, 2012, 10:28 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Try to lower the P factor and see how it behaves.
In hovering its a nice "sound", when you move the copter, you hear clearly the "chirping low tone, grrrr, grrrr", which is NOT good! It should always be a sweet "phwee, pfweee" sound.
I am experiencing same kind of behavior on one of my kk-copter with lot of vibration due to not well balanced props and these motors (1200kv i think).
I set P as high as possible, in hover it looks rock stable, then, when start flying, i get constant "chirping low tone" like motors can't follow and lose sync for a short moment.
The esc takes all the unfiltered pwm commands.
So i should first get rid of the vibration, and see if i gets better.
Second, use a better "vibration tolerant" firmware..., or the esc firmware can do a part of the job...
Originally Posted by Cossacs View Post
Yes, 4s, here is video, going full throttle on 0:13
I've pulled one dedicated motor much harder before in static with no problems. 8cm wire length from ESC to battery should not be a problem. But long Battery-ESC wire length in combination with -5c outside temperature (increased capacitor impedance) and really hard setup (3x2820/14 Pulso 140 gramm motors per each 4s 5000 30C battery) and low input capacitor (only 440uF per ESC) could be a problem, how do you think?
I have not tried wii-esc code yet because i do not exactly know why i never seen such problem with one motor only.
Which input PWM refresh rate you recommend to use? Does it really matter?
Old Jan 19, 2012, 10:54 AM
igorek82 is offline
Find More Posts by igorek82
United States, NY, New York
Joined Apr 2011
Originally Posted by timecop View Post
Theres no reason the app should be > 800x600
Also, don't forget to account for taskbar or those with 800x600 won't be able to display it..... it's rarely a problem on the laptop but for some netbooks....
igorek82 is offline Find More Posts by igorek82
Old Jan 19, 2012, 01:46 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
lol my tablet is 1280x800...
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Jan 19, 2012, 01:52 PM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Will your Tool be cross platform?
If you need avedude with xwopen USBasp support give me a pm.
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Jan 19, 2012, 01:56 PM
GrootWitBaas is offline
Find More Posts by GrootWitBaas
I don't speak German ....Yet !
GrootWitBaas's Avatar
Germany, Baden-Württemberg, Weissach im Tal
Joined Dec 2010
he said c# so I guess not ...
GrootWitBaas is offline Find More Posts by GrootWitBaas
Old Jan 19, 2012, 01:57 PM
Joined Apr 2011
run it in wine lol its not that difficult to find .net emulator
Old Jan 19, 2012, 02:00 PM
Joined Dec 2010
Yes sure I'll find a way to run it, but I hope you'll share the code so I can use your hard work to make a nice Mac Gui ...
Old Jan 19, 2012, 02:01 PM
LazyZero is offline
Master of Flash
LazyZero's Avatar
Joined Jun 2005
Why not directly compile with mono? So no need for an additional emulator.
Christian
Old Jan 19, 2012, 02:40 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
Most tablets were introduced just a few years ago so their resolutions are pretty up to date.
Bmr4life is offline Find More Posts by Bmr4life
Old Jan 19, 2012, 05:59 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
If it doesn't have any funky code c# will run in Mac and Linux using Mono.
IceWind is offline Find More Posts by IceWind
Old Jan 19, 2012, 06:04 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
And here I thought Mono was some kind of disease. Oh, wait. Mac and Lunix. It probably is.
timecop is offline Find More Posts by timecop
Old Jan 19, 2012, 06:38 PM
Joined Apr 2011
i like this timecop dude
i will use std libraries. if i can run asp in linux apache server u can figure out simple gui.
Old Jan 19, 2012, 06:45 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
I thought a STD was a bad thing? Never the less, I've ordered a set of RCTimer 20amp ESCs and plan on flashing them
Po73 is offline Find More Posts by Po73
Old Jan 19, 2012, 07:21 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
Unless you use some BSD or Solaris I'd say you're a Windows fanboy!
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 03:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 10:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 10:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 03:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 03:31 PM
