Old Oct 09, 2011, 08:52 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Originally Posted by Captainhook1 View Post
That's gonna be one big monster of a model!
She's big, for sure, Carey. Wingspan is 104". The planned weight is 20#. They suggest a motor that swings anything between an 18X6 to a 20X10.
TomCrump is offline Find More Posts by TomCrump
Old Oct 09, 2011, 10:12 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Looks great! Ikon kits aren't for everyone but I love 'em! The instruction manuals usually consist of 2 or three sheets of paper and, maybe, a photo sheet. They delineate the traps but otherwise you are almost scratch building. Before you pull the tail end together make sure the centerline on the plan isn't crooked. I had that happen to me building a Rearwin Speedster and had to undo some stuff to rid the 'banana fuse' effect.
ARUP is offline Find More Posts by ARUP
Old Oct 10, 2011, 05:12 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Thanks for the tip.
I've been getting my yard ready for Winter, but I hope to work on the Cessna today.
Emil calls for cutting the rear fuselage completely off, and then re-gluing it at the "bend." I hope to "crack" it, and then pull the sides together.
Old Oct 10, 2011, 03:41 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
The fuselage is finally joined !
After that, the stab was test fitted. The fin will glue into slots in the stab. When I dry fit the assembly, I found that it did not fit correctly to the fuselage.
I double checked the stab, fin, and rudder for correct size, over the plan view. I then measured the stab over the plan view of the fuselage side. According to that, it is 3/8" too long, chordwise.
Obviously, there is a discrepency in the plans. After looking at the problem, I think I can add 3/8" square stock to the fin post area, and everything should work out.
It'll be a while before I get to it, however. The fuselage front needs joining first. Then it will be on to the wing. I'll use the mounted wing to make sure that I mount the stab squarely.
Old Oct 10, 2011, 04:57 PM
Wilian Amaral is offline
Find More Posts by Wilian Amaral
SENTA A PUAAA!!!
Wilian Amaral's Avatar
Brazil, RJ, Miguel Pereira
Joined Apr 2007
looking good, tom. and besides, 3/8" isn't that bad. should be a plotting problem.
Wilian Amaral is offline Find More Posts by Wilian Amaral
Old Oct 10, 2011, 05:54 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
You're the engineer, Will. I have no idea of what a plotting problem is. LOL
I do think I have a solution figured out, though.
Old Oct 11, 2011, 06:30 AM
Crowfly is offline
Find More Posts by Crowfly
Crowfly's Avatar
United States, MO, Belton
Perhaps it means Don is having a problem "plotting" how he is going to sneak tools out on his next visit
Just kiddin
Fred
Crowfly is offline Find More Posts by Crowfly
Old Oct 11, 2011, 07:10 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Good point, Fred !
Wil visits during his Summer, but that's our Winter. I'm not too sure that Don would leave a relatively warm New Mexico, to visit with Wil..........and steal my tools.
Old Oct 11, 2011, 05:37 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Today, I joined the front of the fuselage sides. The firewall and nose ring were added, too.
I decided to power this model with a Bennett built G-38, which I robbed from my Focke Wulf 190D. The firwall was drilled for the mount, and blind nuts installed.
The nose looked like it could use a little beefing up. Triangle and square stock was added for extra support.
The plans didn't make sense, for the work that I did, placing the forward floor inside the nose pieces. To do this would require a lot of notching around the uprights. I just glued the floor to the bottom of the nose piece sides, and glued the unit to the fuselage. I had to "crack" the interior wall stiffeners, but it all fit well together, and provided a self aligning structure, with plenty of gluing surface.
Old Oct 11, 2011, 06:34 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Tom looks like a great start to another fine project good luck with your build.
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Oct 11, 2011, 06:38 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Thanks, Bruce.
I'm doing what I like best......Gluing sticks together !!!
This kit is proving to be a challenge, but I'm enjoying myself.
The scarey part is that I have another IKON kit in the wings. The Locheed Vega is a favorite. I'm saving this kit until I feel confident that it will turn out well. It is a more complicated build than this Airmaster.
Old Oct 12, 2011, 05:49 AM
yel914 is offline
Find More Posts by yel914
yel914's Avatar
SLC, Ut
Joined Apr 2010
Looking good Tom, making some good progress. Those Ikon kits do cause some head scratching. The results are usually nice though. I've got an Ikon Monocoupe 90 to build someday when I feel "up to the challenge"!
yel914 is offline Find More Posts by yel914
Old Oct 12, 2011, 06:28 AM
supercubman is offline
Find More Posts by supercubman
supercubman's Avatar
Slaton, TX
Joined Oct 2008
At the rate you are going you will have this thing in the air before your flying season is over. Looks great!!
Trey
supercubman is offline Find More Posts by supercubman
Old Oct 12, 2011, 06:53 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Rick; I have the IKON Monocoupe. I didn't build her, but I can tell you that she flies very well. When you get to it, build a stronger, and easily accessable, landing gear. The original design is soft, allowing the model to "squat" after a few landings.
Trey; "in the air before flying season is over" ??? Although we have just experienced a week of incredible weather, it is coming to an end. Temps wil drop 20 degrees, and rain is moving in. I'm afraid that our flying season is about finished.
Old Oct 12, 2011, 07:03 AM
Slaton, TX
Joined Oct 2008
I have faith in you, Tom. BTW nice Monocoupe!
Trey
Wanted 96" De Havilland Beaver Plans by Ikon N' West softlanding Aircraft - Fuel - Airplanes (FS/W) 6 Feb 05, 2015 02:20 PM
Help! Ikon N'west Hawker Hurricane??? barkleyb Fuel Warbirds 0 Nov 05, 2009 12:48 PM
Found Ikon N'West Sperry Messenger Cowl ace_drummond Aircraft - Fuel - Airplanes (FS/W) 3 Dec 31, 2008 05:25 PM
Wanted Ikon N'west PT-22 kit TJK Aircraft - Fuel - Airplanes (FS/W) 1 Aug 23, 2007 05:42 PM
