Old Sep 29, 2011, 01:01 PM
NCDLG is offline
Find More Posts by NCDLG
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
Cool, can't wait to see more about both planes.
P5 looks awesome!
All the best,
Eric
NCDLG is offline Find More Posts by NCDLG
Old Sep 29, 2011, 01:17 PM
Merk is offline
Find More Posts by Merk
Merk's Avatar
United States, SC, Clover
Joined Sep 2004
Dave this looks great.
Keepup the good work.
Russ M.
Merk is offline Find More Posts by Merk
Old Sep 29, 2011, 03:33 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by Shaper Dave View Post
Jim,
The primer I use is called Duratec which is a polyester based filler. I can take it from rough filler to full polish with no need to paint.
Great stuff.
Dave
Thanks Dave. I will see if it is available here in Australia.
Jim.
edit: What size tip are you spraying that through Dave? I have found a source here in Aus.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Last edited by Jim.Thompson; Sep 29, 2011 at 09:06 PM. Reason: additional question.
Old Sep 30, 2011, 03:30 AM
Shaper Dave is online now
Find More Posts by Shaper Dave
Shaper Dave's Avatar
Oahu Hawaii
Joined Aug 2004
Jim,
Im using a Binks HVLP Touch up gun. Depending on how thin you make it, I can use the standard tip for finish coats or my second tip is a 30 T according to the box for thicker sprays.
You can thin with either MEK or Acetone. I prefer Acetone as I have a bowl next to me for quick cleanup anyway.
What I do on a fresh glassed plug after it has gone off and ready to coat is, mix a small batch and paint it on the surface in a area about 6" long and squeegee it into the weave. Continue this until the whole surface is done. This fills all the pin air. When it has tacked up go ahead and brush, spray or roll your first sanding coat.
This is a polyester based material and you have to use catalyst as a hardener.
Don't get it too thick, like making fillets as it will shrink and crack.
I use Bondo for thickness and finish with Duratec.
Any questions while your using it let me know.
Tuesday I prepped the Ghost mold with epoxy and milled fibers around all the edges. Then mixed my surface coat. Something wasn't right and sure enough I botched the mixture and it did not go off correctly. Ended up striping it off by laying up a layer of glass over it and peeled it up.
So now Im refinishing the wing surface and will continue the thread in a few days after I fix my mistake. #%$@ happens.
Dave
Shaper Dave is online now Find More Posts by Shaper Dave
Old Sep 30, 2011, 04:33 AM
Joined Aug 2008
Jim,
Im using a Binks HVLP Touch up gun. Depending on how thin you make it, I can use the standard tip for finish coats or my second tip is a 30 T according to the box for thicker sprays..................................
Dave
Thanks for the details Dave. Meanwhile our local suppliers suggest a gun with a 2.5mm tip. The price of 1 gallon here is around $180 plus delivery. That would put it up to around $220 which is a bit prohibitive, especially if I add the cost of the special gun.
Undecided,
Jim.
Old Sep 30, 2011, 07:25 AM
wilem is offline
Find More Posts by wilem
airplanes r made from aluminum
wilem's Avatar
United States, SC, Darlington
Joined Jul 2009
Don't kid your self, you can make a molded wing that flys great without the computer. You just need a big can of Elbow Grease!
Dave
seems to be a major shortage of that these days.
wilem is offline Find More Posts by wilem
Old Sep 30, 2011, 01:58 PM
Oahu Hawaii
Joined Aug 2004
Jim,
It is expensive, just over $25.00 a quart here. I would not buy a gallon just because you will never use that much before it goes off.
I used just over a quart to do the P5 and all the parting trays. Also you can spray it with a regular gun. No need for specialized equipment.
And yes, there really is a shortage of elbow grease users.
Dave
Old Sep 30, 2011, 04:37 PM
Joined Aug 2008
Jim,
Dave
I thought so too Dave, but the supplier here only does it in quarts. I will try and find smaller quantities elsewhere.
It sure sounds the way to go!
Old Oct 01, 2011, 08:38 PM
Oahu Hawaii
Joined Aug 2004
After I botched the surface coat I have cleaned everything up and did a polish on the wing to check for any waves or irregularities before putting it back in the tray. Looks pretty good, I will continue next week with starting the glass layup.
Dave
Old Oct 01, 2011, 08:42 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Dave, Can you priority mail that to me and I will finish the project for you......Beautiful....LOL
Cant wait to see the finished parts,
will trade for some nice cotton shirts!
doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Oct 01, 2011, 09:24 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
Dave that looks fantastic
rcgeorge is offline Find More Posts by rcgeorge
Old Oct 01, 2011, 11:10 PM
Oahu Hawaii
Joined Aug 2004
Thanks guys.
Doug, your Orian is looking nice and strong!
Old Oct 02, 2011, 04:07 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Dang, now that is a mirror smooth finish! I'm anxious to see the final mold, good luck and take your time on this next go around!
samc99us is offline Find More Posts by samc99us
Old Oct 03, 2011, 01:17 PM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
Oh yeah...looking great.
Are you using a polishing machine, like a buffer or something?
Sean
sporter is offline Find More Posts by sporter
Old Oct 03, 2011, 09:51 PM
Oahu Hawaii
Joined Aug 2004
Yep, Surfboard tech all the way. I use a power sander with a polishing pad. The plug is taped down so it wont move. I use a cutting compound and liquid polish. Its really dangerous for the plug as you can hook an edge and total it.
Defiantly risky unless you have some experience.
Dave
Alert P51 Mustang "Galloping Ghost" crashes at Reno today! rcGman General Aviation 272 Sep 22, 2011 12:39 PM
Sold * Pierce Arrow Products 2 Meter Pierce Arrow Sailplane NIB $65.00 FREE SHIPPING!!! stevster Aircraft - Sailplanes (FS/W) 2 Jul 13, 2011 09:28 AM
Sold NIB Bill Love Ghost Bipe Kit M.Putnam Aircraft - Electric - Airplanes (FS/W) 4 Apr 11, 2011 05:21 PM
Ghost vs Drive Image, has Ghost been improved? lakedude Life, The Universe, and Politics 11 Feb 04, 2005 02:43 PM
