Old Sep 13, 2012, 12:56 PM
Shaper Dave is online now
Find More Posts by Shaper Dave
Shaper Dave's Avatar
Oahu Hawaii
Joined Aug 2004
I agree GT.
D
Shaper Dave is online now Find More Posts by Shaper Dave
Old Sep 28, 2012, 06:41 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
TE trench on the P5
Hi Dave,
Following with interest your methods and have one question in relation to the P5;
...how do you machine and fit the TE trench so accurately without CNC? Did you make a template from the plug TE, then use that as a guide for a router?
Also the Corian strip that is inserted...is that bought off the shelf or stripped off a larger sheet?
Chris
http://www.seat.org.au
DrFragnasty is offline Find More Posts by DrFragnasty
Old Oct 08, 2012, 02:30 PM
Merk is offline
Find More Posts by Merk
Merk's Avatar
United States, SC, Clover
Joined Sep 2004
Dave,
How is the new wing?
Do you have alot of flight time on it yet?
Still looking for a release Date.
What about some pics?
Russ M.
Merk is offline Find More Posts by Merk
Old Oct 08, 2012, 03:43 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Hi Dave,
I hope you don't mind me asking here on your thread, but you (and others) might like to suggest a first DLG glider for me.
I want to have a go at one.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Oct 09, 2012, 02:37 AM
Oahu Hawaii
Joined Aug 2004
Hi Chris,
I always make a full size master pattern of one side of the wing out of 1/8" mahogany plywood. I do the initial drawings full scale and work out all the details on it. No Computer's involved. This is bonded to the wood and cut out and trued. The wing plugs are made and checked to this master.
For the trough, I use the master and make it the template to run the router against on the MDF trays, 1/4" deep and 1/4" wide.
The Corian is cut off a larger sheet using a table saw 1/2" x 1/4". I then sand and round the edges. Makes a perfect fit and bends nicely to the curve. No heat forming necessary.
Hope this helps,
Dave
Old Oct 09, 2012, 03:22 AM
Oahu Hawaii
Joined Aug 2004
Russ,
I do have a lot of time on the new wing. My original prototype is pretty beat up and its not showing the potential of the wing. The hinge line on top has been mangled by experimenting with different gap seals and removing the tape has delamed the glass so its pretty rough.
My friend Milts "Ghost" in the photos is # 2 and its pristine and fly's much better than mine. Unfortunately, last Sunday this ship lost radio on a launch and went straight in totaling it. On the good side I got to see where all the failures are and can beef up a few spots that need it.
I will post some shots later of how I have been making my foam sheets. As you can see in the photos, the cell structure is very tight and smooth. The paint and colors you can do with it is amazing. Only draw back is its heavier and not as stiff as Rohacell. I have been doing everything I can to get the weight down but its ending up an ounce heavier than what is needed.
Only thing I have left to do is to order some 80 gram cloth from R&G. I have been using 1.19 oz on the outside and .75 on the inside. The .75 is not holding up to the stress of launching and the cloth needs to be more balanced between the outside and inside for this foam.
I have been relentless in trying to get this to work. The cost comes to $12.00 of foam for a full wing not counting labor.
Jim,
The best advice I can give is to see if you have any local builders producing a glider. The Aussies have to have some good designs available.
Dave
Old Oct 09, 2012, 03:33 AM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Cheers Dave, that all makes sense and the results speak for themselves.
Chris.
Old Oct 09, 2012, 11:00 AM
Merk is offline
Merk's Avatar
Joined Sep 2004
Dave,
Planes look great.
I would like to see the new wing and the cloth that you will using.
Can't wait to see one in person and see how it performs.
Russ
Old Oct 09, 2012, 03:38 PM
Joined Aug 2008
Thanks for the tip Dave. Your plane looks like a fine work of art in the pics. Nice work!
Jim,
who might try a cheap HobbyKing Versus for starters!
http://www.hobbyking.com/hobbyking/s...lider_Kit.html
Old Oct 09, 2012, 10:02 PM
Oahu Hawaii
Joined Aug 2004
Jim,
Good call, looks very similar to my Arrow Sport I was selling a few years ago.
Dave
Old Oct 09, 2012, 10:04 PM
Oahu Hawaii
Joined Aug 2004
Forgot the photo
Old Oct 09, 2012, 10:44 PM
jcats is online now
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
Very nice.
Jun
Originally Posted by Shaper Dave View Post
Russ,
I have been relentless in trying to get this to work. The cost comes to $12.00 for a full wing not counting labor.
Jim,
Dave
jcats is online now Find More Posts by jcats
Old Oct 23, 2012, 09:09 AM
Merk is offline
Merk's Avatar
Joined Sep 2004
Come on Dave any updates???
How many are flying?
You have all of us hooked and we have not heard anything in sometime about it.
Russ
Old Oct 24, 2012, 03:34 AM
Oahu Hawaii
Joined Aug 2004
Hi Russ,
I have been uber busy with it being the surf season over here. I've been chained to my shaping room doing production shaping.
It was a dead summer for the board business so I had lots of time for gliders. But for the next few months its all about boards. Im sure I'll get days off here and there to get some planes built.
Had a little hiccup on a Rohacell order that pushed the time table back some more but it will be resolved very soon.
Dave
Old Oct 24, 2012, 01:02 PM
Merk is offline
Merk's Avatar
Joined Sep 2004
Dave,
I understand.
I hope this surf season is good to you.
Just blip in some time and lets us see what you are doing.
Good luck
Russ
Alert P51 Mustang "Galloping Ghost" crashes at Reno today! rcGman General Aviation 272 Sep 22, 2011 12:39 PM
Sold * Pierce Arrow Products 2 Meter Pierce Arrow Sailplane NIB $65.00 FREE SHIPPING!!! stevster Aircraft - Sailplanes (FS/W) 2 Jul 13, 2011 09:28 AM
Sold NIB Bill Love Ghost Bipe Kit M.Putnam Aircraft - Electric - Airplanes (FS/W) 4 Apr 11, 2011 05:21 PM
Ghost vs Drive Image, has Ghost been improved? lakedude Life, The Universe, and Politics 11 Feb 04, 2005 02:43 PM
