Old Sep 27, 2011, 01:18 PM
bamabaxter's Avatar
United States, MS, Clinton
Joined Apr 2010
2.4 GHz VTx interfering with 72Mhz Rx?
OK, so I experienced something very odd this weekend. I am running 72MHz to do some FPV flying, and went to turn on my Video equipment and my plane went crazy. I have RSSI pinned out for the Futaba 127df Rx that I am using and sure enough it was bouncing all over the place. I was testing out the equipment since I got a new radio and had to change channels. I was running ch50 and had only some small motor glitches. Nothing crazy. I recently changed to ch14 and the plane went bat $h!t crazy as soon as I turned on the Vtx. Servos were moving, not jittering, but moving over full travel and the motor went to about 3/4 speed. Besides the obvious fact that I am getting interference, what the heck is going on? How is my 2.4Ghz messing with a 72MHz system? I have everything spaced pretty well, Any help will be appreciated. I am running a CL antenna on the plane for video, if that matters and the Video equip is BEVRC 500m Tx. I just don't get why I am having this type of problem.
bamabaxter is offline Find More Posts by bamabaxter
Old Sep 27, 2011, 05:58 PM
Joined Nov 2005
Sounds like your rx is bad. 2.4g should not interfere with your fm setup. Try using a different rx and see if your problems go away.
soulreaper is offline Find More Posts by soulreaper
Old Sep 27, 2011, 06:22 PM
Team White Llama!
gundamnitpete's Avatar
i would agree, sounds like bad RX to me. Try another and see if it goes away
gundamnitpete is offline Find More Posts by gundamnitpete
Old Sep 27, 2011, 08:03 PM
bamabaxter's Avatar
Joined Apr 2010
Will do. Thanks..
Old Sep 27, 2011, 09:17 PM
bamabaxter's Avatar
Joined Apr 2010
Problem solved......Rx sucked. Thanks again.
Old Sep 27, 2011, 10:53 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
that sucks
Roll Tide!
Toysrme is offline Find More Posts by Toysrme
Sold NEW* Dynam 2.4 GHZ 4ch tx & 7ch rx cardnation Aircraft - General - Radio Equipment (FS/W) 4 Sep 22, 2011 04:57 PM
Sold NEW* Dynam 2.4 GHZ 4ch tx & 7ch rx cardnation Aircraft - General - Radio Equipment (FS/W) 4 Sep 14, 2011 07:15 AM
Sold (2) JR R700 72mhz Rx & Futaba 2.4 FAAST R6106HFC Wing&aPrayer Aircraft - General - Radio Equipment (FS/W) 6 Sep 05, 2011 09:35 AM
Discussion Stereo Vtx, 1,2/2,4/5,8 GHz Kaspers1 Video Piloting (FPV/RPV) 4 Apr 14, 2011 06:17 PM
For Sale JR 9303 Spektrum 2.4 ghz module, 72mhz synthesized module, Xtremelink 2.4 ghz module twohsieh Aircraft - General - Radio Equipment (FS/W) 8 Aug 31, 2008 11:51 PM
