Old Sep 27, 2011, 12:12 PM
Gamerjoe is offline
Find More Posts by Gamerjoe
Gamerjoe's Avatar
United States, CA, Diamond Bar
Joined Jul 2011
E-Flite Apprentice - Wing Hold Down Rods Suck
I was given an E-Flite Apprentice 15e trainer plane to have some fun with, and it has never been flown. However, it is 3 years old, and it has been sitting in my Uncles garage gathering dust.
The original rubber bands were weak and dry, so I ordered a new E-Flite replacement set and re-mounted the wing with the new rubber bands. Took the plane out to fly and it is an excellent flying aircraft, but there is a huge quality issue with this plane. The Wing Hold Down Rods that essentially hold the rubber bands and the top wing together, they decided to just snap off on the entire left side of the aircraft, right where the cap is glued on. The caps did not come off, which is what E-Flite indicates as a quality issue, no, the rod itself snapped off. I was only doing a banking turn at maybe 20 miles per hour.
This resulted in the wing swinging around and shearing off the tail section prior to flying off completely, then the fuselage did a nice nose dive from 100 feet to the ground! With lots of epoxy and some new parts, she will fly again.
Upon inspection of the Wing Hold Down Rods, I find that they are extremely cheap, thin, hard, plastic rods, that easily snap with pressure. Has anyone else experienced this, and what is a good alternative to using a plastic toothpick to hold the wings on?
Gamerjoe is offline Find More Posts by Gamerjoe
Old Sep 27, 2011, 04:44 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Mine was newer than yours, now sold, and as I recall mine had sturdy wooden rods with plastic caps. A cap came loose but was easily glued back on. No loss of rubber bands. BTW, any office store sells LARGE bags of bands, choose your size, for cheap!
dkrhardy is offline Find More Posts by dkrhardy
Old Sep 27, 2011, 10:17 PM
Gamerjoe is offline
Gamerjoe's Avatar
Joined Jul 2011
That's good to know that the later ones have sturdy rods, so I will order the replacements from E-Flite. Thanks for the tip on the rubber bands.
Old Sep 28, 2011, 12:00 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
I personally don't like to trust wooden or plastic dowels like those. The only way I feel safe is if its either carbon wrapped aluminum, or a solid piece of steel.
Xpress.. is offline Find More Posts by Xpress..
Sold E-flite Apprentice - PNP - Central FL AugieDog Aircraft - Electric - Airplanes (FS/W) 1 Sep 05, 2011 11:47 AM
Wanted Bolt size for wing hold down for Cermark Breeze 2 vmaxmasonrya Aircraft - Sailplanes (FS/W) 2 Jun 19, 2011 04:45 PM
Question Photon Wing Hold-Down Bolts glidermang Hand Launch 2 Apr 07, 2011 11:39 AM
Wanted Spar for E-flite Apprentice Wing fred_n Aircraft - General - Miscellaneous (FS/W) 2 Oct 04, 2010 06:53 PM
Wanted E-Flite Apprentice Wing Bohh33 Aircraft - Electric - Airplanes (FS/W) 2 Apr 23, 2009 05:21 PM
