Joined Sep 2011
Alright well I couldn't find 'loctite' brand, but I did find a similar product as well as some grub screws! Got it all secured up, and after 24 hours waiting for it to dry took it out this morning for some good flying
There was a Typhoon on the way here in HK so it was blowing like a whore out and it was definitely a white knuckle experience, but everything held up nicely and I had a blast ![]() Thanks again guys!
Richmond B.C. Canada
Joined Sep 2004
Spaceman,if you are interested there is a over 500 page thread in the
Foamies(kits) section on this site for the AXN Floater Jet,lots of information and tips,keep a eye out on the motor magnets,a common problem is them working loose.I have just finished building a floater as a rtf,had to buy all the electronics seperate,unfortunatly looks like they are expecting mainly rain here for the next 2 weeks. James |
Joined Sep 2011
I have read that entire thread and love all the information I gathered from it Unfortunately I wasn't quite able to work out my problem with the information in that thread alone, and that's why I made this one. Thankfully it wasn't a big deal as you can read, and I was able to get it all worked out OKYou are from Richmond? Vancouver is my Canadian home Glad to see the rain still hasn't stopped yet in the 604 XD
![]() I have my AXN in possession, but I have too much going on to assemble it for now; so I'm doing my late night reading ![]() BTW; I LOVED visiting Hong Kong (several times for business). What a awesome experience to view the waterfronts at night! |
Joined Sep 2011
Haha I didn't have much else to do while waiting for my AXN to arrive I'm sure we all know the feeling of purchasing something and then going stir crazy while waiting for it to arrive. To quote Homer Simpson "Five days?! But I'm mad now!"I do love the views in Hong Kong, my apartment is overlooking the ocean and I can see the fireworks from HK disney every night just a mile or so away. It's a great place to live! ![]() Feel free to check out my other thread going over my initial observations of my AXN as well as the Dynam Hawk Sky I purchased at the same time. You probably won't learn anything from it, but meh, senseless promotion by myself here Keep an eye on those damned grub screws though!http://www.rcgroups.com/forums/showthread.php?t=1513952 |
You don't NEED or WANT 2 grub screws in the motor mount. That's a faulty design. Using 2 makes the bearing shaft kind of suspended on the points of the screw. Should one get loose, by definition the other one is now loose also.
A single screw forces the bearing shaft against the radius of the mount. This provides a larger surface area of contact and is more secure. BEWARE-a motor that has spun like than can have damaged the wires coming out of the motor (common problem). If the motor will not run PROPERLY AND IMMEDIATELY upon trying, STOP!. If you don't you will burn out your ESC to add to the problem. |
Joined Sep 2011
. When I noticed the single grub screw, I secured it nice and tight, and while running the motor on the bench it started to spin slowly and that's when I noticed the wires tightening as it rotated. I stopped the motor before they were too tight to cause any damage (noticeable damage at least). Afterwards I checked my hawk sky and it had 2 grub screws in the motor. Since installing the second grub screw the motor hasnt moved a bit, after 3 flights now. What you are saying makes sense to me, but I am confused as all my problems have disappeared thanks to the addition of the second grub screw......can anybody else with the AXN verifiy how many grub screws their motor mount has??
What flydiver says is correct, strange as it may seem, there is a thread somewhere on here where this is explained in detail. Flydivers post jogs my memory and I believe the posters name was jackerbes.
You may want to research this and actually flatten the shaft where the screw contacts with a file or dremel to further assist the holding power. 2 screws actually work against each other but if you leave it as is, I like he idea that the 2 screws are close together as in your design. Opposing screws just cause a problem. Read up and make your own decisions on your design. Protect the motor from filings with a plastic bag if you do this. |
| Thread Tools | |
| Discussion EasyStar or AXN Clouds fly? | bigalbert | Video Piloting (FPV/RPV) | 69 | Mar 13, 2012 04:39 AM |
| Wanted Axn floater jet "clouds fly" fuse | eaglescry24 | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 05, 2011 07:07 AM |
| Discussion AXN Floater "clouds fly" | rlpolo | Beginner Training Area (Aircraft-Electric) | 3 | May 04, 2011 10:29 AM |
| Mini-HowTo Big wings AXN Floater-Jet (aka Clouds Fly) | saucisse | Foamies (Kits) | 10 | May 20, 2010 12:43 PM |
| Wanted AXN Floater jet/Clouds fly wings | ram0207 | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 25, 2009 11:55 AM |
