Old Sep 26, 2011, 09:06 PM
stilv is offline
Find More Posts by stilv
stilv's Avatar
United States, FL, Miami
Joined Sep 2011
DJI-M controller on x650 Frame (build up)
now ESC and motors, which would you get for this type of setup ?
Build up Starts post 14+ w/ pics
stilv is offline Find More Posts by stilv
Old Sep 26, 2011, 09:08 PM
stilv is offline
stilv's Avatar
Joined Sep 2011
load will be 1pound or less video cam w/ FPV setup
Old Sep 26, 2011, 09:22 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
The Avroto M2814-11S Short Shaft 770KV motors are good and will work. You can use 25a ESC's. John sells the motors but everyone is out of stock right now till Oct 10th.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Sep 26, 2011, 09:47 PM
stilv is offline
stilv's Avatar
Joined Sep 2011
what you think of these? http://montorc.com/cobrac-281420brushlessmotor.aspx
Old Sep 26, 2011, 10:05 PM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
They look like they put out more watts and are supposed to be good motors. Maybe someone will chime in that have used both motors.
Site Sponsor
Old Sep 27, 2011, 12:02 AM
johnIn2SonAZ is offline
Find More Posts by johnIn2SonAZ
Tucson,AZ
Joined Dec 2007
Originally Posted by stilv View Post
Just to let you Know you will have to move the Shaft on those Motors.
So they would not be plug and play for UAV Applications.
-John W.
johnIn2SonAZ is offline Find More Posts by johnIn2SonAZ
Site Sponsor
Old Sep 27, 2011, 03:06 PM
stilv is offline
stilv's Avatar
Joined Sep 2011
what you think is a good motor/esc ?
Old Sep 28, 2011, 05:58 PM
stilv is offline
stilv's Avatar
Joined Sep 2011
also i like to see some images x650 and DJI setup, wondering where to put the gps
Old Sep 28, 2011, 09:43 PM
chris24g is offline
Find More Posts by chris24g
United States, CA, Hayward
Joined Apr 2006
depends on the camera, simple gopro setup or heavier point and shoot or camcorder?
chris24g is offline Find More Posts by chris24g
Old Sep 28, 2011, 10:00 PM
dckiteboards is offline
Find More Posts by dckiteboards
Joined Mar 2011
what are planning on lifting with the x650 frame will not take too much weight at all
dckiteboards is offline Find More Posts by dckiteboards
Old Sep 28, 2011, 10:05 PM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
Where did u find that info? What is too much weight? I wasnt aware of a big weight limitation on the X650 frame.
Site Sponsor
Old Sep 29, 2011, 12:20 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
+1. This vendor tested the frame to lift AUW 2.5 kg. Should be just fine for gopro and fpv stuffs.
fajar is offline Find More Posts by fajar
Old Sep 29, 2011, 05:20 AM
leopold1 is offline
Find More Posts by leopold1
Belgium
Joined Sep 2010
Will the ESC's fit in the provided space on inthe arms?
Interesting setup;
leopold1 is offline Find More Posts by leopold1
Old Sep 29, 2011, 11:15 PM
stilv is offline
stilv's Avatar
Joined Sep 2011
swapping out the motors and esc later, just want get it built and setup.
Old Sep 29, 2011, 11:19 PM
stilv is offline
stilv's Avatar
Joined Sep 2011
cam i will be using is: PowerShot ELPH 300 HS 12.1-Megapixel Digital Camera
w/ FPV
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
Cool Karbonic-XXL 50CM DJI WooKong-M frame superdave42 Multirotor Talk 12 Mar 09, 2012 10:01 AM
