Old Sep 26, 2011, 08:57 PM
FreakFlow is offline
Find More Posts by FreakFlow
MicroHeliPilot III
FreakFlow's Avatar
Florida
Joined Aug 2010
Ultra Cheap HobbyKing Shopping List for 1st time QuadBuilder
It 8 bucks.
http://www.hobbyking.com/hobbyking/s...1_-_539mm.html
I am BRAND NEW never before done it kinda quad builder
thanks for any help for a brand newbie
FreakFlow is offline Find More Posts by FreakFlow
Old Sep 27, 2011, 08:37 PM
MicroHeliPilot III
FreakFlow's Avatar
Florida
Joined Aug 2010
So far I am thinking....
Motor - http://www.hobbyking.com/hobbyking/s...nner_10g_.html
Control Board - http://www.hobbyking.com/hobbyking/s...ega168PA_.html
ESC - http://www.hobbyking.com/hobbyking/s...ontroller.html
Now need to figure out what propellers to use, and what battery...Anyone have any suggestions?
thank you!
Old Sep 27, 2011, 09:36 PM
OLDTOM is offline
Find More Posts by OLDTOM
OLDTOM's Avatar
United States, TX, Waxahachie
Joined Jun 2011
You should rethink your choice's, when you put those motors with the esc's and the flight controller you will not have much left for battery. The total thrust from all four motors should be at least double your total weight or you cannot stop going down when you descend... You need enough battery for about 8-10 min flight min, which will add weight quick. Look at working examples that others have built and follow which you like instead of jumping into the unknown at first.
Have fun and keep smillin...
OLDTOM is offline Find More Posts by OLDTOM
Old Sep 27, 2011, 10:58 PM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
check my blog for the mini quad I built and a quick vid of it. I have listed everything that I used
braindead4554 is offline Find More Posts by braindead4554
Old Sep 28, 2011, 12:51 AM
rocketheli is offline
Find More Posts by rocketheli
Quad is the new black
Australia, NSW, Sydney
Joined Jun 2011
I have the same (quite commonly used) power components on my miniquad (with 5x3 props and a 610 mah batt) and it flies fine indoors (+ outdoors on a totally calm day). Sure, it won't fly for 8 minutes but it does have a thrust to weight ratio of more than 2 times (if the HK numbers are correct).
Freakflow, the HK frame you link to is probably far too large for this motor. Plus I don't think the bolt holes are compatible. You need to decide whether you want an indoor or outdoor quad and then there are plenty of build posts that can help you decide on components.
braindead - that's a nice frame! Really have to build me a CNC soon!
rocketheli is offline Find More Posts by rocketheli
Old Sep 28, 2011, 12:53 AM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
>>[QUOTE=FreakFlow;19440498]So far I am thinking....
Now need to figure out what propellers to use, and what battery...Anyone have any suggestions?<<
Do you realized that the frame may be called a mini quad but there is nothing mini about it?
539 mm wide so that meant the distance from motor to motor is around 20".
You need some 180 watts motor to fly that thing.
Mini quad is around 12" or below from motor to motor.
You need motors in this range:
http://www.hobbyking.com/hobbycity/s...F20%5F22L.html
10 X 4.5 or 10 X 4.7 propellers.
18 amps Turnigy Plush speed controller
3 cells 2,500 mah battery pack at 30C or higher discharge rate.
Here is a quad around the same size. It is heavier than the Hobby King wood frame but the size is similar.
I am using a higher kV motor so I am using 8" props.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Sep 28, 2011, 02:23 AM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
@ rocketheli Thanks!! I will have some available really soon
@ seismicCWave You are very correct. I didn't see the frame he had posted on the first page. Those motors you listed are awesome little motors and are very popular.
@ freakflow Those motors that I listed in the other thread and the ones you have linked here work great on a mini quad that is very light and small. I would say 9 in. or less.
Old Sep 28, 2011, 04:27 PM
MicroHeliPilot III
FreakFlow's Avatar
Florida
Joined Aug 2010
Thanks everyone!
http://boingboing.net/wp-content/upl...9/RTR2RLZF.jpg
Question Hobbyking Quadcopter Build Thread! Cody S Multirotor Talk 144 Sep 20, 2012 08:05 PM
Wanted QuadCopter - Frame Dialfonzo Aircraft - Electric - Multirotor (FS/W) 2 Sep 24, 2011 06:57 AM
