Old Sep 26, 2011, 07:12 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
HK Bonsai Wing
Has anyone tried this wing? The comments on HK's site seemed promising, but I couldn't find anything on RCG about it. My setup will be a 3s 1000mah battery, 15amp esc and a 2400kv motor. This should give it some juice to have fun and yet fly in a tight area.
For the camera I"ll probably use a cheap board cam on pan and either a 100 or 500mw vtx.
thanks
ash
ashdec87 is offline Find More Posts by ashdec87
Old Oct 22, 2011, 11:44 AM
Herishi is offline
Find More Posts by Herishi
United Kingdom, England, Harwich
Joined Jul 2011
Bonsai FPV
I have done an FPV video with the bonsai, hope it helps :-)
Hobbyking Bonsai FPV flight, LQ (1 min 28 sec)
Herishi is offline Find More Posts by Herishi
Old Dec 19, 2011, 02:53 AM
KenChin is offline
Find More Posts by KenChin
NewFlyer
KenChin's Avatar
Kuala Lumpur, Malaysia
Joined Aug 2006
Here's mine... Using 2S 500mAh, keychain camera to balance the CG.
Bonsai VOB @ BNO (Bagan Nakhoda Omar - Sabak Bernam) (3 min 15 sec)
KenChin is offline Find More Posts by KenChin
Old Dec 19, 2011, 01:22 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
yep I got mine in the air. Good stuff
Wing Maiden FPV (3 min 11 sec)
Old Dec 19, 2011, 08:20 PM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Harden
Joined Aug 2008
Gosh these things are so small, I built one for a freind and did wonder about the fpv of one ... but i guess if you can FPV a Fox u can FPV anything!
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Old Dec 19, 2011, 09:01 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ya its tiny, but it kinda makes it fun. They're fast and agile.
Old Dec 30, 2011, 04:12 PM
Icanthackit is offline
Find More Posts by Icanthackit
Joined May 2011
Built mine this week and maiden flight was yesterday, and im very impressed
All built with HK's recommended equipment and flying on a 500mah 2S had no dramas throwing it in the air and I was off, CG worked out quite well and had dual rates programmed as full throws made it a twitchy devil!
Some things to note for anyone else looking to build one, The battery holder bay at the front (Plywood with velcro strap) is prone to falling out (badly glued) so do something about that! (I cable tied it in). And in the instructions it says to just heat shrink the control rods to the angled end pieces... make sure you also use some CA glue because they will pull out at a bad time. Apart from that though, very happy with how it flew! Got around 10 mins from each battery and slow speed was a happy crawl through the sky and full throttle had enough speed for a beginner like me to be happy!
Icanthackit is offline Find More Posts by Icanthackit
Old Jan 03, 2012, 10:56 AM
kenstogie is online now
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Mine is coming with the stock Motor and a NanoTech 480 2 cell. Will let you know. I love the small planes that fit in the front seat so this is a win if it is all they say.
Has anyone tried the GOOP Glue thing that they mention in the Flighttest report??
http://flitetest.com/articles/tek-sumo-and-bonsai/
Flite Test - Tek Sumo and Bonsai - Review (12 min 58 sec)
kenstogie is online now Find More Posts by kenstogie
Old Jan 03, 2012, 12:30 PM
Bear_Pants is offline
Find More Posts by Bear_Pants
United States, NJ, Manchester
Joined May 2011
http://youtu.be/RD1b3Z7K2bE
hmm
Bear_Pants is offline Find More Posts by Bear_Pants
Reply With Quote  (Disabled)
Old Jan 04, 2012, 02:45 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I used goop for the leading edge. It works very well and helps a LOT in hard landings
Old Jan 05, 2012, 09:15 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
That's +1 for the GOOP. Anyone else??
Old Jan 15, 2012, 09:54 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
here's my latest.
Wing FPV (2 min 41 sec)
next flight will be at a park and i'll try to fly under a covered picnic area
Old Jan 18, 2012, 08:18 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Still waiting on mine, not sure if the recommended motor will do what I want but it's a start I guess.
Someone recommended this motor for a more spirited Bonsai, but I have never seen a flight with one. Probably would require a higher rated esc too.
http://www.hobbyking.com/hobbyking/s...Outrunner.html
Old Jan 18, 2012, 04:20 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
honestly, the motor i'm using (recommended for 3s) gives it VERY good performance. It climbs like nothing else, and seems to be pushing the plane to its max stable speed. Much faster (dive) and it gets a little sensitive and wiggles..lol
Old Jan 18, 2012, 05:09 PM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
What do you have? (Link maybe) if you throw a 2s pack is it as floaty?
Discussion Where to buy steel wing joiner? Crash Prone Scale Sailplanes 12 Sep 13, 2011 12:38 AM
Discussion Where to buy? jfuller17 Dock Talk 0 Sep 11, 2011 01:18 PM
Question where to buy electric brushless motor 10 or more kW vrabec Electric Motor Design and Construction 1 Sep 10, 2011 09:14 AM
Discussion Where to buy this SARCFAN Racing Boats - Electric 11 Sep 07, 2011 07:55 AM
Discussion Where to buy Laser Cut Wing kits for Slope & other sailplanes? 8thelephant Slope 0 Jun 28, 2011 01:18 AM
