Old Sep 26, 2011, 03:52 PM
superfastwrx is offline
Find More Posts by superfastwrx
United States, WA, Port Orchard
Joined Sep 2011
Need help on a motor/esc combo for my trainer.
Hey guys I have a few questions for some of you experenced guys. I just bought a tower hobbies 40 size trainer for a whoping 50 bucks , well the motor in it is locked up and everything i own is electric so i figured this would be a perfect canidate for a conversion. I was wondering what you guys would suggest for a good motor/esc combo that doesnt break the bank. I dont want to spend a bunch into this plane because its a learning platform but i want to be able to keep it and fly it whenever. here are the specs of the plane that i know.
Wingspan: 62" (1575mm)
Wing Area: 698 sq in (45sq dm)
Wing Chord: 11.25" (285.75mm)
Weight: 5 lb (2268kg) assembled
Wing Loading: 17 oz/sq ft (52g/sq dm)
Fuselage Length: 51.5" (1308mm)
Airfoil: Flat Bottom High-Wing
Center of Gravity: 3-1/2" (89 mm) Back from the wing's leading edge
at the fuselage
Thanks everyone. and if anyone has anything forsale let me know im in the market haha
superfastwrx is offline Find More Posts by superfastwrx
Old Sep 26, 2011, 09:00 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Rules of thumb give you a ballpark range
5lb AUW @ 100W/lb = 500W
.40 glow equals ~ 800W
If you want to use 4s... this would do
http://www.hobbyking.com/hobbyking/s..._46_Glow_.html
If you'd prefer 5s then get the lower Kv version.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 26, 2011, 09:39 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
I have a 650KV on 6S running a 13x6 prop
plenty of power when i need it!
lipoflyer is offline Find More Posts by lipoflyer
Old Sep 27, 2011, 01:47 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
At >300g this is certainly a very big .46 motor (a Dualsky 4250 [.46 size] is only 200g!).
Maybe one can exceed the 40A rating!
Discussion motor-battery-ESC combo - Help ! bmblb Power Systems 6 Sep 22, 2011 10:22 AM
Discussion please help with motor/esc/batt combo for flyduspider. imdone Multirotor Talk 2 Sep 08, 2011 05:54 PM
Discussion Need your opinion on this motor/esc combo. jake95 Dock Talk 7 Sep 08, 2011 01:12 AM
Question motor, esc, and battery combo need help please!! mcbride152 Electric Plane Talk 2 Aug 06, 2011 01:54 AM
Discussion I need help picking a motor/esc combo for slash 2wd would like to run 2200mah 3slipo nicolasr1 Off-road Cars 7 Jul 30, 2010 01:53 PM
