Old Apr 18, 2012, 03:18 AM
TGKconnectors is offline
Find More Posts by TGKconnectors
United States, TN, Smyrna
Joined Sep 2011
How long of a rudder do I need? I'm thinking 110mm to 130mm.
Let me know
TGKconnectors is offline Find More Posts by TGKconnectors
Old May 16, 2012, 10:00 PM
Joined Sep 2011
Any ideas on the rudder length? I just received the stinger that I ordered and I also received the motor mount from hobby king. More pictures to come.
Old May 16, 2012, 10:45 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
This one will work fine: http://www.offshoreelectrics.com/pro...prod=ose-80050
scorpion1 is offline Find More Posts by scorpion1
Old May 17, 2012, 01:41 PM
Joined Sep 2011
Motor Mount
Here is the new motor mount just sitting inside the hull. It does not fit any suggestions other then cutting the rails to make it fit? Also how far back should it be?
Old May 18, 2012, 01:19 AM
Joined Sep 2011
Right now I have more questions then answers. What is the differences between the leopard motor 4082 1500kv, 1600kv, and the 2000kv? The motors are almost 40mm wide and the motor mount I have is only 35mm wide but it is the one that is in all the photos of other boats.
I need some help.
Old May 18, 2012, 04:52 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
For the 4082 you need this mount. http://www.offshoreelectrics.com/pro...prod=ose-80600
Chances are the mount you have now is the 540 mount for 36 mm cans.
On the different kv of the motors, you really need to decide how many cells you will be running and amke your decision based on that. I didn't see a 1500 kv 4082 listed http://www.offshoreelectrics.com/pro...o-4082&cat=148
If you are planning to run 6s I'd suggest the 1250 or 1600 kv motor. Try to stay away from the "D" winds as they tend to run hotter and pull more amps.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old May 19, 2012, 10:36 PM
Joined Sep 2011
Just ordered a lot of the parts from hobbyking. The only thing left to order is the motor and the speed controller. Any one used the leopard comparable motor from hobbyking?
Old May 21, 2012, 02:35 PM
Joined Sep 2011
update
Here are a few pictures covering the top of the boat and the canopy I made for it.
Old May 21, 2012, 02:37 PM
Joined Sep 2011
more pictures
more pictures
Old May 30, 2012, 12:47 PM
Joined Sep 2011
I used great stuff to fill in the canopy and shaved it off with a kitchen knife. Then I sheeted the bottom of it over the weekend and now it is ready for sanding.
The new 40mm motor mount came in last week with a bunch of the handware, so the next step is to start adding the hardware to the boat.
Old May 31, 2012, 07:48 PM
Joined Sep 2011
I sanded down the canopy today and sanded the top of the hull. Made the wife mad when I blew sawdust all over the floor of the room.
I also drilled and tapped (2) 1/4-20 holes to screw the canopy down in the back. Next I will work on pinning the front of the canopy.
Any comments on what I have been doing?
Old Jun 02, 2012, 05:42 PM
Joined Sep 2011
I have finished installing the pin that will hold the front of the canopy down. It is a strong hold on that canopy and I think it will work quite well. I have questions on the stuffing tube and where the motor mount should be located. Is anyone still watching this build thread?
Old Jun 02, 2012, 07:20 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Just sent you a reply to the pm. I'm still watching, but "quietly".
Old Jun 03, 2012, 07:33 AM
lilleyen is offline
Find More Posts by lilleyen
Still showing up for breakfast
lilleyen's Avatar
Ontario Canada
Joined Mar 2009
Me too, carry on.
I'm facing some of the same problems you are, so I'm learning along with you.
Nice work, BTW.
lilleyen is offline Find More Posts by lilleyen
Old Jun 03, 2012, 01:42 PM
Joined Sep 2011
Bill has been kind enough to answer my questions so far, so as I learn I'm progressing.
Thanks Bill
Charlie
Build Log 72" Mono Wood Frame TGKconnectors Dock Talk 9 Oct 03, 2011 10:16 PM
For Sale reduced again RTF 1:2.5 scale CNC-modellbautechnik Ka-1 MTT Aircraft - Sailplanes (FS/W) 0 Sep 11, 2011 02:49 PM
For Sale 1/72 scale desron48 Boats (FS/W) 0 May 15, 2011 12:07 PM
Discussion 1/72 Scale 2.4Ghz Full Proportional Throttle and Steering Control Conversion EQMOD Micro Cars 9 Apr 24, 2011 11:07 PM
Sold (2) 1/72 scale Custom Made Spitfires Butters Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jan 30, 2010 03:15 PM
