Old Feb 17, 2012, 01:46 AM
TGKconnectors is offline
Find More Posts by TGKconnectors
United States, TN, Smyrna
Joined Sep 2011
The baby came on the 14th, Valentine Baby, so the boat is sidelined for a little bit. I was able to build a canopy for it and everything has wood filler on it. Just need to get it sanded down
I also took strips of heavy fiberglass and fiberglassed down the entire center seem. I started polyurethaning the whole inside as well.
TGKconnectors is offline Find More Posts by TGKconnectors
Old Feb 17, 2012, 04:51 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
coriolan is offline Find More Posts by coriolan
Old Feb 19, 2012, 11:31 PM
Joined Sep 2011
Im going to be sanding the canopy down tomorrow when it warms up here in tennessee. It snowed today but will be 60 tomorrow.
Old Feb 23, 2012, 07:48 PM
Joined Sep 2011
Fiberglass
I fiberglassed the inside of the hull where the seem is in the middle. I also sprayed the inside with polyurethane completely. I sanded down the canopy, pictures to come.
Old Feb 24, 2012, 12:50 PM
Joined Sep 2011
Do you guys think I need more foam in the front or am I ok to seal up the top of the boat?
Old Feb 25, 2012, 04:00 PM
DepthsofHell is offline
Find More Posts by DepthsofHell
.... But you can call me Dave
DepthsofHell's Avatar
Medford, OR
Joined Nov 2010
I would put foam in every pocket that will not be utilized for equipment, but that's me. If those are little air pockets down the seam, you will want to get rid of those. Other than that, looks like she is coming along nicely, good job!
And congratulations on the new member of the family!
DepthsofHell is offline Find More Posts by DepthsofHell
Old Feb 26, 2012, 12:31 PM
Joined Sep 2011
ok I will put more foam in the front and put more epoxy in those air pockets. More pictures to come.
Old Feb 28, 2012, 10:44 AM
Joined Sep 2011
More Foam
I have packed the front with as much foam as I can. Now it is time to seal up the front.
Old Apr 11, 2012, 04:39 AM
Joined Sep 2011
part ordered
Hey everyone I just ordered the stinger for this boat. Check it out.
I am wondering how would I know how long to get the flex shaft in?
How is it measured? Overall length, or the length that is just the flex shaft part that does not run through the stinger?
Talk to you guys soon
Old Apr 11, 2012, 06:53 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Best thing to do is order it long and cut it to length after you see how much is needed. I usually get the motor placed along with stuffing tube. Put the prop dog on the prop shaft and slide it all the way in. Measure the distance from the back of the stinger to the front of the prop dog. Subtract 3/16" from that and cut that amount off the front of the cable.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-14 Tomcat Build
Old Apr 11, 2012, 02:27 PM
Joined Sep 2011
How do you cut it and keep it from fraying? Also does it need a square on the end of it?
Old Apr 12, 2012, 05:31 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I use a dremel with a cut off wheel to cut them. Haven't seen one fray so far. After I get the right length, I do add a little silver solder to the end. If you are using a typical electric motor coupler it does not need a square end.
Old Apr 12, 2012, 07:46 AM
Joined Sep 2011
ok so I think it is going to be about 7" from the transom. If I order a 17" flex cable I can just cut it done to size and silver solder the end of it.
Old Apr 12, 2012, 10:01 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I think you're thinking in the right direction.
Old Apr 18, 2012, 03:38 AM
Joined Sep 2011
Still waiting on the stinger to arrive, it should be here any day now.
Build Log 72" Mono Wood Frame TGKconnectors Dock Talk 9 Oct 03, 2011 11:16 PM
For Sale reduced again RTF 1:2.5 scale CNC-modellbautechnik Ka-1 MTT Aircraft - Sailplanes (FS/W) 0 Sep 11, 2011 03:49 PM
For Sale 1/72 scale desron48 Boats (FS/W) 0 May 15, 2011 01:07 PM
Discussion 1/72 Scale 2.4Ghz Full Proportional Throttle and Steering Control Conversion EQMOD Micro Cars 9 Apr 25, 2011 12:07 AM
Sold (2) 1/72 scale Custom Made Spitfires Butters Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jan 30, 2010 04:15 PM
