Old Oct 08, 2011, 01:00 PM
TGKconnectors is offline
Find More Posts by TGKconnectors
United States, TN, Smyrna
Joined Sep 2011
I will see what I can find today.
TGKconnectors is offline Find More Posts by TGKconnectors
Old Oct 08, 2011, 09:08 PM
Joined Sep 2011
I found the pink 2" foam board in a 4x8 sheet and it cost $30.00 from the Home Depot.
I bought a couple of different glues to find one that wont eat it up.
Old Oct 08, 2011, 11:23 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
I use some random brand of foam safe CA, the thick and gap filling 10-25 second type of CA.
cyberhoops is offline Find More Posts by cyberhoops
Old Oct 09, 2011, 12:18 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
"I bought a couple of different glues to find one that wont eat it up"
Epoxy,Elmer white glue do fine on foam. No need to glue the whole surface for foam-to-foam gluing and don't glue near the edge that will be Hot wire cutted or sanded.
coriolan is offline Find More Posts by coriolan
Old Oct 09, 2011, 12:37 PM
Joined Sep 2011
I think I am going to be sanding the excess foam away so your right in not gluing the edges. Maybe I will get to work on it today some and post some more pictures.
Old Feb 05, 2012, 02:06 AM
Joined Sep 2011
Well it has been 4 months and the boat has been kind of sitting on the shelf while I started working at my new Home Depot here in Tennessee. I have been pushing to get it sheeted and fiberglassed so that my friend could get it painted up. He is starting his own painting business and I am trying to help him out with some r/c clients.
Old Feb 05, 2012, 02:16 AM
Joined Sep 2011
Updated Photos
Here are a few pictures of the pink foam I found at Home Depot.
Old Feb 05, 2012, 02:18 AM
Joined Sep 2011
Sheeted Pics
Here is the bottom sheeted up.
Old Feb 05, 2012, 02:38 AM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Coming along well now.
I know how you feel. I've had a couple of boats on hold for over a year now & just can't seem to find the time to get stuck into them.
All the best.
Paul.
785boats is online now Find More Posts by 785boats
Old Feb 05, 2012, 02:41 AM
Joined Sep 2011
I have a second daughter on the way, wife is due in 2 weeks. Dont know how much time there will be for building. I have to build as much as I can now! lol
Old Feb 05, 2012, 07:07 AM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Mtrchs,
Nice build!
I'm sure you've thought of it, but make sure the wood inside is sealed with epoxy before the foam goes in the you add the deck.
After all, it is a boat and moisture is going to find it's way inside...
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Feb 05, 2012, 09:12 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
scorpion1 is offline Find More Posts by scorpion1
Old Feb 05, 2012, 01:02 PM
Joined Sep 2011
I have never built a boat so no I did not think about putting epoxy inside, maybe I will be able to pop the foam out because it is only tacked in there.
Old Feb 05, 2012, 01:03 PM
Joined Sep 2011
Also I had a question about balance, when and if I need to worry about it. When I pick the boat up by the middle bulk head it is tail heavy. Is that usual?
Old Feb 05, 2012, 02:44 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Epoxy sealing is necessary with glow IC power using high nitro% fuel, for electric you can seal with WB polyurethane varnish which is water proof when cured, cheap and easy water cleaning of your brushes. It also smell almost nothing while using
As for the CG, it will be better set when the boat is complete and motor/esc,hardwarw instaled.
Build Log 72" Mono Wood Frame TGKconnectors Dock Talk 9 Oct 03, 2011 11:16 PM
For Sale reduced again RTF 1:2.5 scale CNC-modellbautechnik Ka-1 MTT Aircraft - Sailplanes (FS/W) 0 Sep 11, 2011 03:49 PM
For Sale 1/72 scale desron48 Boats (FS/W) 0 May 15, 2011 01:07 PM
Discussion 1/72 Scale 2.4Ghz Full Proportional Throttle and Steering Control Conversion EQMOD Micro Cars 9 Apr 25, 2011 12:07 AM
Sold (2) 1/72 scale Custom Made Spitfires Butters Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jan 30, 2010 04:15 PM
