Old Sep 26, 2011, 03:18 PM
TGKconnectors is offline
Find More Posts by TGKconnectors
United States, TN, Smyrna
Joined Sep 2011
Build Log
1/2 Scale 72" Mono
I found a set of plans for a 72" Mono hull which everyone said noone had built yet, so I decided to have the plans scaled down to 50%. I am going to build this boat leading up to building the bigger one.
I started cutting out the frame today.
TGKconnectors is offline Find More Posts by TGKconnectors
Old Sep 26, 2011, 08:24 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
scorpion1 is offline Find More Posts by scorpion1
Old Sep 27, 2011, 10:57 AM
Joined Sep 2011
Yes the over all length is going to be about 36" I hope. Unless fedex messed up during the scaling down.
Last night I traced out a few more frame members.
Old Oct 03, 2011, 01:40 AM
Joined Sep 2011
I worked on the frame pieces a little bit more today.
Old Oct 03, 2011, 01:41 AM
Joined Sep 2011
I ordered a bunch more wood, as well as a bunch of pieces from Hobbyking.
Old Oct 07, 2011, 02:50 AM
Joined Sep 2011
I glued the frame together tonight and was missing one piece so sheeting the bottom will be the next step.
Anyone have any comments?
Old Oct 07, 2011, 08:40 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Old Oct 07, 2011, 12:49 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Looks very good to me. Are those 1/8" thick bulkheads? You did a nice job with the cut outs. Those are always a challenge for me. It looks like you drilled a set of holes and linked them together. The last time I tried a Dremel tool with a spiral cutter bit. It was pretty effective but hard to control accurately. (Where is that laser cutter when you need it.)
I guess I have two questions: Are you going to use the "wood over foam" method and what thickness of wood are you planning for the sheeting?
cyberhoops is offline Find More Posts by cyberhoops
Old Oct 07, 2011, 01:49 PM
Joined Sep 2011
The bulk heads are actually 1/4" and so are the runners. I think the runners were supposed to be 1/8" because I had to recut everything.
I tried drilling the holes and linking them together but it didnt work to well. So I went to harbor freight and bought a $25.00 mini router and cut them out with that.
I saw a picture where they used foam blocks between the bulk heads and sanded them down to match, I think I am going to have to follow suit because I can not get a noodle down each side.
As for the sheeting, I was thinking about using 3/32" balsa and then fiberglassing it and getting it painted.
Old Oct 07, 2011, 04:16 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Personal opinion: I dislike balsa for boats even when the outside is fiberglassed. Any water getting to the wood will soften the balsa and that caused catastrophic failures in my first two hydros.
I now use 1/32nd plywood for sheeting which also works very nicely over foam. I seal it with 20min epoxy for those cases where I don't use lightweight fiberglass cloth over the plywood.
When possible I always use the a foam block, usually the pink foam insulation, between bulkheads and cut/sanded/carved to shape. It helps make a rigid structure and gives more surface area to attach the sheeting.
I know there are builders who use balsa effectively - but I won't use it anymore.
Old Oct 07, 2011, 08:50 PM
Joined Sep 2011
Where do you purchase 1/32 plywood cost effectively. I also do not know where to purchase the pink foam blocks of insulation.
Old Oct 07, 2011, 09:23 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Depending were you live, you can get pink foam insulation 4'X8'X2" at the "Home depot" for a few $. If you need more tickness you can tack glue several together. For thin plywood you can get some at the LHS, 1/32" or 1/16" doesn't cost much in 48"X24" sheet(would be cheaper and lighter than balsa+Fiberglass/epoxy). I use 1/32" ply for small fast electric but for a 36" hull 1/16" might be better.
coriolan is online now Find More Posts by coriolan
Old Oct 08, 2011, 01:42 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
I order all of my wood for sheeting from National Balsa off the web - it is about $9 or $10 for a 2'x4' sheet of 1/32 or 1/16th plywood. They do have a minimum $25 order, but it is far cheaper than picking up sheets from the LHS. As for pink foam, as Coriolan mentioned I get mine in a 4x8 sheet from Home Depot.
I use 1/32nd sheeting on 1/10th scale electric boats, which are in the 34 to 36 inch range. Where it is backed by foam it is very solid. In open areas on the bottom of the hull I used to use 1/16th, but now I just use 1/32 and glue in some carbon fiber strips for stiffness. It is probably right on the border line of how far you can take 1/32nd plywood, but I am trying to keep the weight down on the hydros.
Old Oct 08, 2011, 03:52 AM
Joined Sep 2011
I dont think my Home Depot carries it, I'll check tomorrow. I also will make a stop at the hobby shop.
Old Oct 08, 2011, 11:36 AM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Blue foam works as well, but since I am building a Miss Renault, I went with pink.
Build Log 72" Mono Wood Frame TGKconnectors Dock Talk 9 Oct 03, 2011 11:16 PM
For Sale reduced again RTF 1:2.5 scale CNC-modellbautechnik Ka-1 MTT Aircraft - Sailplanes (FS/W) 0 Sep 11, 2011 03:49 PM
For Sale 1/72 scale desron48 Boats (FS/W) 0 May 15, 2011 01:07 PM
Discussion 1/72 Scale 2.4Ghz Full Proportional Throttle and Steering Control Conversion EQMOD Micro Cars 9 Apr 25, 2011 12:07 AM
Sold (2) 1/72 scale Custom Made Spitfires Butters Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jan 30, 2010 04:15 PM
