Old Sep 26, 2011, 11:33 AM
Charlescd is offline
Find More Posts by Charlescd
RC Paraglider / Sailplanes
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Discuss 711 4 metre glider
Hi,
Has anyone any experience with this glider from FMS?
http://www.fmshobby.com/rc%20sailplanes-discus.html
I've seen it online but have not found a review.
thanks
Charlescd is offline Find More Posts by Charlescd
Old Sep 26, 2011, 02:54 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
They were quite popular a few years ago. A friend bought one for less than $150. The fuse is fragile and the wings bend. I did a search and found this and I know there are other threads on this glider
http://www.rcgroups.com/forums/showt...ight=4m+ventus
davidjensen is offline Find More Posts by davidjensen
Old Sep 26, 2011, 05:20 PM
Charlescd's Avatar
Joined May 2010
thanks for the reply. I'll poke around the forum and see what i can find.
I saw this glider on ebay and at general hobby. There's a lot of info missing such as what type of servos you need, wiring, can you fit a tow hook, etc..
Old Sep 26, 2011, 07:06 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
That's not a thermal glider, it's a slope glider! At least according to the nmbers given. I calculate a wing loading of almost 19 ounces per square foot, and an average chord of only about 6 1/2 inches. So, if I'm not mistaken the Reynolds number will be approximately 110k at that chord in slow flight, and lower at the tips. That's pretty low. If the airfoil does not get quite thin as the chord gets smaller, it may be a problem.
lincoln is offline Find More Posts by lincoln
Old Sep 26, 2011, 09:27 PM
Charlescd's Avatar
Joined May 2010
That burst my bubble !! I'm looking for a glider to be towed and search for thermals. Maybe 4m is a bit too big.
Any suggestions - (fiberglass kit preferably).
Old Sep 27, 2011, 09:58 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
A high wing loading does not necessarily stop you from thermalling well but it will train you to stop pulling on the elevator
At higher loadings, the model will need to be flown faster but it will still thermal if you, the pilot, are capable.
A high wing loading and small chord will make it difficult to fly but not impossible. It would likely be a bear to winch or hi-start launch but you can get away with a lot with an aerotow launch.
tk
tkallev is offline Find More Posts by tkallev
Old Sep 28, 2011, 08:56 PM
lincoln is offline
Joined Dec 2001
4 meter is not too big for thermals. Usually, the bigger they are the better they fly. I just think it's a little heavy for the narrow wing. A 4 meter with more wing area might be just the ticket.
Unfortunately for you, I'm not familiar with many scale jobs, which I gather is what you want. If it doesn't have to be scale, I'll bet the Super Ava Pro* would be a superb floater, since the old, regular Ava was. There are many thermal duration gliders which are very good in thermals too. For instance, the Supra or the Explorer. (ANd there's a 4 meter Explorer.) Of course, all of these are fine on the winch, too. OTOH, they're all more expensive than the one you mention.
Of those listed, if the larger Ava flies like my old Ava, it will be very easy to fly.
*Does anyone actually make money by flying all these gliders called "Pro"?
Old Sep 28, 2011, 09:42 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
I've flown one of them. Slopeflyer33 from here at RCGrous has had a couple. The wingloading is probably up there, but it flew fairly well on the slope.
slopemeno is online now Find More Posts by slopemeno
Old Sep 29, 2011, 12:05 AM
iflytailies is offline
Find More Posts by iflytailies
aka Schleppmeister
PA
Joined Feb 2006
it flies great for what you pay for. Mine does not like wind over 12mph. It thermals amazingly well! Does also well at slope:
4m Discus First Flight at Slope (4 min 4 sec)
iflytailies is offline Find More Posts by iflytailies
Old Sep 29, 2011, 03:54 PM
Charlescd's Avatar
Joined May 2010
Hi Iflytailies,
Can you tell me what you are using as servos and hardware? Standard servos, mini, slim, etc... Do you have a tow hook installed and where? Center of Gravity also.
thanks
Great video!
Old Sep 29, 2011, 05:17 PM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Is that on the Susquehanna by the Rt 30 bridge?
1967250s is offline Find More Posts by 1967250s
Old Sep 29, 2011, 09:19 PM
aka Schleppmeister
PA
Joined Feb 2006
HS-85MG's in the wing. Hitec HS-311 rudder. Futaba S-3150 elevator. HS-625MG tow release. Tow release Z-323 is in the nose: http://www.iflytailies.com/store/tow-releases/
Don't remember CG.
Yes, that's the Susquehanna river.
